Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Jan 13, 2019 at 11:35 AM
    #3841
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I think for supercharged trucks we would like a few things:
    -Ability to delete smog pump chk engine light
    -delete o2 sensor chk engine light (long tube headers)
    -different pulley size tunes here are the most common i believe:
    3.0(stock)
    2.85(you dynoed my truck on this)
    2.7
    2.5
    Also I know a lot of the guys with supercharged trucks are starting to mess around with methanol injection, me being in that group also.
    With going to 2.7 and smaller pulley it is recommended to go to bigger injectors (61 lb injectors) it would be nice if you could tune for that.
    It is too bad you are not in Cali anymore, because I just ordered a quick change pulley system so I can swap pullies in a few minutes. Going to the 2.7 pulley, and also getting a methanol kit soon.
    If you were still out here I would order the 61 lb injectors so you could work out a tune for those.
    Hopefully if you get your software for youe v3 cable ready soon you will still be able to develop tunes for these.
  2. Jan 13, 2019 at 12:01 PM
    #3842
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Fully on board with all of this, great post!
    Murphinator[QUOTED] likes this.
  3. Jan 13, 2019 at 1:00 PM
    #3843
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Hopefully he reads it. I think if he developed all those tunes he wouldn’t have to do much custom tuning for everyone, that pretty much covers everything. I know some run a 2.6 but that would be enough to push them to a 2.5 or a 2.7 tune
  4. Jan 13, 2019 at 1:04 PM
    #3844
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    Yes I noticed that too on the V2 calibration. I also noticed that it's shifts a lot faster and hold gears much better. I'm on 35s on stock gears. With the regular trdtune I was only able to get up to 95 miles an hour with the OV tune my truck can past 110 now.
    Norton[QUOTED] likes this.
  5. Jan 13, 2019 at 1:07 PM
    #3845
    rockporttaco
    Henry
    Rockport
    S/C 4x4
    I used this guy his name is Steve in Lewisville TexasScreenshot_2019-01-13-15-07-06.jpg
  6. Jan 13, 2019 at 2:01 PM
    #3846
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    @OVTune +1 on this ☝
  7. Jan 14, 2019 at 11:49 AM
    #3847
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    Would love to see an NA map for an FBO setup and 93 octane come to fruition.
    StuckinOhio and Master Z like this.
  8. Jan 14, 2019 at 7:59 PM
    #3848
    ThomasMore66
    Dallas/Fort Worth & Durango
    Nice. I live in Flower Mound.
  9. Jan 20, 2019 at 12:37 PM
    #3849
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Put a couple hundred more miles on the V2 tune. Throttle is definitely more responsive and gas mileage is up about 10%.
  10. Jan 20, 2019 at 12:48 PM
    #3850
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I'll make a strange request, I'd like to see a high idle feature, if that's possible. It would be helpful for the guys running winches and heavy electric loads, as well as improving Ac performance in the summer. It also helps warm the truck up a lot faster in the winter.
    EdinCincinnati likes this.
  11. Jan 20, 2019 at 3:48 PM
    #3851
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Maybe a higher idle only in D / R , but stock in N? This can be done. But a high idle all the time will eat gas a lot faster than you'd think
  12. Jan 20, 2019 at 6:11 PM
    #3852
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Great Idea!!
  13. Jan 20, 2019 at 6:14 PM
    #3853
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Can you do a higher idle in P or in N? Personally I would prefer in N.
  14. Jan 21, 2019 at 6:30 AM
    #3854
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    -smog pump delete alone would be reason enough for many to spend the cash.
    -tunes for regular, premium, fuel econ, and towing (NA and S/C)
    -ability to move into a supercharger and other future mods without fuss
    -happy to do it all on my shop laptop
    Atlas86 and Norton like this.
  15. Jan 21, 2019 at 6:45 AM
    #3855
    OVTune
    OVTune
    yes it can be set higher in P/N only
    Regarding deleting any emissions component, due to the EPA we will not likely be offering that directly. It is something we can offer for off road trucks to do on their own with i0Tech.
  16. Jan 21, 2019 at 7:14 AM
    #3856
    Gaunt596
    Matthew
    Central Maryland
    I'm aware of the gas consumption. It would be really slick if it could work like the GM diesel trucks, when in park pushing the cruise control button enables it, and you hold the "accelerate" position on the stalk to raise the idle.
  17. Jan 21, 2019 at 4:44 PM
    #3857
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    So @OVTune when do you predict us 4.0 drivers will experience some of these added benefits we’ve just been discussing?
    Norton and Wild Crow like this.
  18. Jan 21, 2019 at 5:05 PM
    #3858
    Purple-taco
    Purple-taco Member
    2013 Silver Tacoma xsp-X
    Are you guys able to eliminate the speed governor at 110mph? Kinda want to out run my friend’s charger
  19. Jan 21, 2019 at 8:25 PM
    #3859
    ThomasMore66
    Can I install the software on more than one computer? I want the software and I want my tuner to have the software.
    Torspd likes this.
  20. Jan 22, 2019 at 4:33 AM
    #3860
    OVTune
    OVTune
    I0Tech or our flash kit?
