Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 25, 2019 at 12:48 PM
    #3981
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Does your name start with a "J"? If so I am doing it right now eta 5 mins
  2. Feb 25, 2019 at 1:03 PM
    #3982
    OVTune
    OVTune
    Call them back, you'll be good.
  3. Feb 25, 2019 at 1:11 PM
    #3983
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Awesome thanks.
  4. Feb 25, 2019 at 1:22 PM
    #3984
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Hi Mat, any update on the issue I'm having with p5flash?
  5. Feb 25, 2019 at 1:25 PM
    #3985
    OVTune
    OVTune
    what's your ticket number? no idea who you are sorry
    RacecarGuy[QUOTED] likes this.
  6. Feb 25, 2019 at 1:28 PM
    #3986
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    3092 is what's listed in the email chain, not sure if thats the ticket number or not.
  7. Feb 25, 2019 at 3:02 PM
    #3987
    MyCarneAsadaTaco
    MyCarneAsadaTaco Well-Known Member
    Alex
    OC/IE/LA
    2014 TRD Sport Supercharged 4x4
    TRD SuperCharger URD 2.8 Pulley URD performance Y-Pipe OVTuned TRD Exhaust
    I emailed you any left?
  8. Feb 25, 2019 at 3:02 PM
    #3988
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    :thumbsup:
  9. Feb 25, 2019 at 9:22 PM
    #3989
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I contemplated getting that tune many years ago but it was very aggressive. Not positive but I think a couple engines were damaged by that tune. And by that time APR was on the way out and only one person really knew how to tune it properly.
    I still think e85 is a good choice tuned right with an ECA. Remember e85 is like 115 rated octane and has 3 times the cooling effect of gasoline.
    The question is. Can @OVTune control an ECA injunction with the stock ECU.
  10. Feb 26, 2019 at 4:40 AM
    #3990
    OVTune
    OVTune
    Flex Fuel is being worked on for these ECUs already by us with a special patch.
  11. Feb 26, 2019 at 10:35 AM
    #3991
    ThomasMore66
    Dallas/Fort Worth & Durango
    I still want to know if we can manage the 322 g/s air-flow issue with OV.
    How much hp do you think our little engine can handle?
  12. Feb 26, 2019 at 10:38 AM
    #3992
    OVTune
    OVTune
    From looking at the ECU the stock MAF curve ends at 323 g/s
    Scaling for a larger intake diameter, the maximum G/sec that can be put in the MAF scale (limit of 16byte 65xxx) is 511 g/sec
    TodayWasTHeDaY likes this.
  13. Feb 26, 2019 at 10:51 AM
    #3993
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    511 g/s * 1.18 = 603 crank hp
    Sounds good to me
  14. Feb 26, 2019 at 11:41 AM
    #3994
    TRON
    Stock internals definitely can’t stand anything north of 400 rwhp. Regardless, the TRD setup couldn’t get that high anyway. I think a heavy modded TRD setup with an excellent e85 tune could get around 385 rwhp.
  15. Feb 26, 2019 at 11:45 AM
    #3995
    TRON
    Care to elaborate?
    Murphinator likes this.
  16. Feb 26, 2019 at 11:46 AM
    #3996
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Looking forward to this.
    If I took my truck to delicious tuning could they adjust the tune you made me for bigger injectors/smaller pulley, or would they have to make a completely new tune?
  17. Feb 26, 2019 at 11:55 AM
    #3997
    ThomasMore66
    So, what are you envisioning for larger intake diameter? Maybe I’m stupid here. I’ve got an aftermarket intake. The inlet diameter of the throttle body is fixed. Inlet diameter of the supercharger is fixed.
  18. Feb 26, 2019 at 12:00 PM
    #3998
    OVTune
    OVTune
    The diameter of the maf tube. Same way rescaling MAF on any car.
  19. Feb 26, 2019 at 12:08 PM
    #3999
    ThomasMore66
    Oh. That’s like changing the diameter of an orifice in a plate-type meter. Ok, so a Tundra maf has a bigger port or something like that. I don’t think there is an after market one.
  20. Feb 26, 2019 at 12:17 PM
    #4000
    ThomasMore66
    @Torspd, @TRON, thoughts on this? Is there another maf sensor that can be used? I think we touched on this before but I didn't understand.
