Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Jun 27, 2019 at 4:32 AM
    #4181
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Found it, it's an issue we have at the moment with zendesk, tickets are not populating properly.
    yes we can upgrade N/A ECUs to TRD + tune
  2. Jun 27, 2019 at 10:30 AM
    #4182
    livpool14
    livpool14 Well-Known Member
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    aFe CAI Momentum GT Power Package, aFe POWER 76mm Throttle Body, aFe headers, aFe Y-Pipe, TRD Exhaust, VFTune, LCEngineering Dual Comp Clutch - Kevlar, Tilton 6000 Series HRB, URD quickshift, Icon Stage II, Icon Delta Joint UCAs, ECGS bushing, Cooper Discoverer at3 255/75/r17 115T, FN f(x) Pro 17" Matte Black, Ice Gray Katzkin, RCI front skid, Optima Yellow Battery, StopTech Sport Slotted Cryo rotors w/ TRD Brake Pads, Morimoto XB HYBRID LED HEADLIGHTS AMBER DRL, Anzo L Bar Taillights, BAKFlip MX4, 3rd Gen Side Decals, Plasti Dip badges, Cab LEDs, redline hood struts
    @OVTune same boat as @TacoSupreme2012, I sent updated data about 2 weeks ago. This is regarding Order# 4287
    Request# 6117
  3. Jun 27, 2019 at 10:35 AM
    #4183
    OVTune
    OVTune
    We are working on this, we have a problem with zendesk tickets, you do not need to resend, we are waiting for them to fix it.
    livpool14 likes this.
  4. Jul 1, 2019 at 4:06 PM
    #4184
    TacoSupreme2012
    TacoSupreme2012 Member
    Johnny
    @OVTune
    Will it be much longer? You have my data in the PM.
  5. Jul 1, 2019 at 4:49 PM
    #4185
    FloridaSon
    FloridaSon Well-Known Member
    White SR Gen 3
    Good for you Matt! Good thing you had plenty of experience being busy. It’s the best! Now your test will be multitasking and balance work/home. Congratulations
  6. Jul 5, 2019 at 10:10 AM
    #4186
    TacoSupreme2012
    Johnny
    6/3 Order placed
    6/10 Order shipped
    6/14 Order delivered
    6/15 System ID info sent
    6/17 Reg. file received
    6/17 Output info obtained from P5flash and sent as per pdf instructions
    6/19 Told I need to download newer version of flasher to check if an update is needed
    6/19 Newer flash software downloaded and update data sent to support@ovtune.zendesk.com
    6/24 No response, so I replied to original ticket with the update data (support+id7937)
    6/26 No response, made forum post above
    6/27 Confirmed, found email/received data
    7/5 No response, still waiting
  7. Jul 5, 2019 at 10:12 AM
    #4187
    OVTune
    OVTune
    We are closed from 3rd to the 8th, but we are still working on finishing pending 4.0L tune files. We did have an issue with our zendesk but this has been fixed.
    For the 4.0L (only 4.0L) some files and ECU versions take additional time for us to build support for, due to the inability / impossibility to gather the BIN data over OBD. This makes tuning them *dependent on your ECU ID* a bit slower.
  8. Jul 5, 2019 at 10:18 AM
    #4188
    TacoSupreme2012
    Johnny
    Ok. Thanks for the update.
  9. Jul 5, 2019 at 9:49 PM
    #4189
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    X2. I’m still patiently waiting too. I know your a busy guy with a lot of plates spinning.
    Norton likes this.
  10. Jul 7, 2019 at 6:08 AM
    #4190
    OVTune
    OVTune
    Calibration versions for support today (tunes)
    04A51
    04413 (04412 update)
    04681
    04512
  11. Jul 8, 2019 at 11:35 AM
    #4191
    TacoSupreme2012
    Johnny
    Thank you! I received the tunes and upgraded from 04680 to 04681.
    My preliminary impression from a 15mi. drive on the 87 tune for a stock N/A manual 2012 with TRD Offroad package is that it should have come from the factory like this.
    It's easier to start from a dead stop and easier to shift in all gears because of the improved throttle response. It definitely feels more similar to my '96 Tacoma now, in that regard. Accelerating with the A/C on is better (still have to give it the beans...doesn't add power) because the engine feels smoother and sounds happier revving out.
    Overall, I'm happy with it and I'm sure I will become even more pleased with it as time goes on. Having to shift many dozens of times a day, this tune has improved my enjoyment of driving the truck.
  12. Jul 11, 2019 at 12:15 PM
    #4192
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    @OVTune any chance you have already or will be looking at the 1uzfe down the road? Or not a platform you would go after? I'll soon have an older non-vvti ls400/1uzfe I'll be looking to tune.
  13. Jul 11, 2019 at 5:23 PM
    #4193
    OVTune
    OVTune
    Would love to do more platforms but Tacomas alone keep me too busy
    BJR and bobsuruncle[QUOTED] like this.
  14. Jul 13, 2019 at 2:14 PM
    #4194
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    Very interested for my 4.0 1GR. Can it be used to calibrate tire size for speedo? If not can I run a programmer for this and also run the OVTUNED as well?
  15. Jul 14, 2019 at 6:34 PM
    #4195
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    So Iv read the first like 100 pages and then skipped to the last like 60 pages and I still don’t know if this is something I could benefit from. Most of the trucks that have this seems to have different sized pulleys or some kind of exhaust mods and they are s/c that I don’t plan on doing. All I have is a trd exhaust and 285/70/17 nitro ridge graps that weight 49lbs each. Will I benefit from this with my setup?
    I’m mostly looking for increased mpgs and I drive pretty conservatively ranging from 18-17 mpgs mostly highway driving in SoCal.
  16. Jul 16, 2019 at 1:31 PM
    #4196
    rocklobster2008
    rocklobster2008 Well-Known Member
    Jayson
    Fort Worth, TX
    2008 Red Tacoma TRD Off Road
    Brute Force Fab front bumper Dobinsons Snorkel 35" Nittos Bilstein 5100s ICON leaf springs RSI SmartCap Bed Replacement Diode Dynamics lighting Custom built morimoto headlights RCI full skid
    Has there been any N/A guys with tune that have some dyno numbers to share? Or done some just 0-60 times to compare to see improvements?
  17. Jul 16, 2019 at 1:45 PM
    #4197
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I run my tune in 87 octane mode for fuel savings. It's a truck, I dont do stoplight races anymore now that I'm an old man lol
  18. Jul 16, 2019 at 1:49 PM
    #4198
    rocklobster2008
    Jayson
    Fort Worth, TX
    Oh I know I'm not a race truck by any means lol the 0-60 reference was just to see gains. I'm mainly wanting to know hp torque gains to see how worth it it is. I'm up to a 34" and could use the power before I regear
  19. Jul 16, 2019 at 1:50 PM
    #4199
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    @OVTune .....any progress with my custom tune ?
    bobsuruncle likes this.
  20. Jul 18, 2019 at 9:05 PM
    #4200
    TheBlueBeast15
    Kevin
    H-Town
    Did you mpgs go up after installing this?
