Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Aug 27, 2019 at 12:08 PM
    #4301
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    :popcorn::popcorn::popcorn:
  2. Aug 27, 2019 at 12:15 PM
    #4302
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I'm no turning guru but the 87 tune has worked well for me. Mpg gains and very nice driveability improvements
  3. Aug 27, 2019 at 1:13 PM
    #4303
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    @OVTune any update to the 91 or 93 tune?
  4. Aug 27, 2019 at 1:17 PM
    #4304
    TacomaSport86
    I have both but havent tried the 93 yet. 91 is a nice bump in performance
  5. Aug 27, 2019 at 2:58 PM
    #4305
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    when you say both...are they tune version UPDATES from the file I have previously been running?
  6. Aug 27, 2019 at 4:22 PM
    #4306
    TacomaSport86
    When I got the handheld there was not a 93 tune. I requested it and Mat sent me the file.
  7. Aug 27, 2019 at 9:46 PM
    #4307
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Did you gain more MPGs with the 91 tune or just about the same with the 87 tune?
  8. Aug 29, 2019 at 7:13 AM
    #4308
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Depends on your ECU version. If supercharged or automatic with calibrations 2010+ yes
    The MPG tune is one we are working specifically oriented towards increasing efficiency on trucks with minimal modifications, (not really ideal for trucks that have FBO / full exhaust, etc)
    see above
    livpool14[QUOTED] likes this.
  9. Aug 29, 2019 at 3:31 PM
    #4309
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    I tried messaging OVTune on Facebook with my question no response, so will post it here. If I purchased a 4.0 NA tune and later buy a supercharger, how much would it be to upgrade? Thanks Chris
  10. Aug 29, 2019 at 3:40 PM
    #4310
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    i have the n/a and been running it for 4-6 months. i just put a super charger on my truck. i flashed my ecu to stock file and hooked the handheld up to my desktop and cleared all data out of the handheld. then i re-read my ecu with the trd supercharger faile and e-mailed the supercharger stock file to them. im still waiting on a modified file back. but the have not said anything about needed me to pay for an upgrade, yet.
    cytocycle likes this.
  11. Aug 30, 2019 at 10:39 AM
    #4311
    rheath08
    Russell
    Bakersfield, CA
    @OVTune any update of the file for my supercharger calibration file? zendesk #9400
  12. Sep 7, 2019 at 3:44 PM
    #4312
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    @OVTune Mat, I’m just about set to put the custom 2.7 pulley tune you sent me on August 12th into my truck. I have a quick important question before I start the supporting mods........
    Do I need to do the “boost reference” FPR mod? I’ve done some research and have gotten advice to add fuel by doing this to not lean out. I am on the TRD 455 injectors still with no plans to switch them, I do not believe I’m in the area of maxing out. Im also at 600 ft above sea level.
    If the tune you sent me richened it up a little to take this into account and you don’t see the need, I won’t do it. Or if you feel just do it for a piece of mind please let me know either way......
    Juan Gomez
  13. Sep 7, 2019 at 4:17 PM
    #4313
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    If you have a wide band afr, run it with the fpr mod first, if you're numbers are too rich to your liking try without it. Always better to start to rich than the alternative
  14. Sep 7, 2019 at 4:30 PM
    #4314
    OVTune
    OVTune
    things like this specific to your tune really need to be sent via our zendesk email.
  15. Sep 7, 2019 at 4:42 PM
    #4315
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Zen desk sits and waits with no response. Had multiple emails sitting for a month now. This is why we resort to anything to get you to respond with some sort of customer service.
  16. Sep 7, 2019 at 4:59 PM
    #4316
    OVTune
    OVTune
    Don't know your email or what the situation is but that's rarely the case. I normally cycle through all my tickets every 7-10 days.
    Regardless, specific things regarding your specific tune needs to be sent through the appropriate channels.
    In 99 percent of cases we get back to people quite quickly. But when it comes to some things. I.E. having a new tune / ecu version loaded to you handheld, having changes to tunes via handheld, etc or pretty much anything "handheld" it's a slow turn over rate because the software, hardware, etc is controlled by a 3rd party.
    Also we are closed holidays and weekends.
    Torspd likes this.
  17. Sep 7, 2019 at 5:06 PM
    #4317
    zippsub9
    Halfmoon, NY
    14 DCLB
    @OVTune . Sure thing Mat, just sent another email 5 minutes ago. I won’t post up all the traffic but not the case on ticket #6481. Plenty of long delays and negative response. Third email sent tonight after you asked for a shipping address a month ago. No item received or confirmation of anything ever shipped. Thanks for your help.
    @ToyotaBurrito
  18. Sep 7, 2019 at 5:09 PM
    #4318
    OVTune
    OVTune
    Ahh ok. This is regarding the replacement handheld for the one that was sold to a 3rd party. I will get back with you via your ticket during normal business hours.
    zippsub9[QUOTED] likes this.
  19. Sep 7, 2019 at 5:49 PM
    #4319
    OVTune
    OVTune
    Also I want clear a few things up because I think our product is getting some unfair criticism due to the new HP Tuners stuff / DIY things going on.
    Our product is to provide you a finished calibration for your truck, and our product does what our product does.
    With the exception of Adding ecu IDs, our tunes have been virtually issue free since release.
    Feedback from our customers are 95+ percent positive, especially AT NA guys who enjoy the new shifting parameters.
    What I think is a little unfair is the criticism regarding updates to tunes, or new features. Especially after seeing what people with HP Tuners is now doing.
    So let's be clear. Most things you see that are being played with in the DIY realm, we did on your tunes well over a year ago.
    That includes shift tables. Torque converter tables. Fuel mapping. Throttle per gear mapping. Air-load mapping. Throttle limit mapping. Valve timing, ignition timing, etc.
    So some of the stuff people are now playing with with HP Tuners, we did in these calibrations well over a year ago. To attack us for not updating something we already did, because you see DIY guys now doing it, is a bit unfair.
    We still sell 4.0 tunes every so often and they include everything we've already provide over the last 16+ months. Our calibrations have a set goal, and that's what we provide.
    If you're looking for a solution that's constant tinkering based off what other DIY realm is doing, this is not that, and it's not an accurate comparison.
    All of our current updates we have provided, or will provide if you don't already have it.
    Updates are not continual tweaking of stuff we already mapped and works well, nor tuning stuff we already did because you're now seeing it in the DIY realm.
    Thanks
  20. Sep 7, 2019 at 5:55 PM
    #4320
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1! You can't go wrong running a little rich while you confirm AFRs, @JuanitoBunito. The FPR Mod is one of the easiest to "install" and remove. Go with it until/unless empirical data tells you to remove it.
