Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Jan 27, 2020 at 6:40 PM
    #4401
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    If I could get a tow haul mode programmed in, where shifting physically into 3rd would allow torque converter lock in 3rd and program the tranny to be stubborn to unlock or shift out of third, I would put a deposit down today.
  2. Jan 28, 2020 at 1:47 AM
    #4402
    rayban1
    rayban1 Well-Known Member
    Seattle
    2015 tacoma sport 4x4
    truck covers usa roll cover, popnlock remote lock, iron cross running boards, p2 trailer Brake, rear view mirror upgrade with auto dim temp and homelink, yakima rack bars , goodyear wranglers, heated side mirrors with directional signal.
    Just loaded the 87 tune,,,on my 2015 4.0L auto....feels like it has better throttle response and better torque.....the shift patterns feel better also.....
    TrailYeti likes this.
  3. Jan 28, 2020 at 7:42 AM
    #4403
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    What made you think the first few tune files didn’t flash properly? I’m curious to know because I’m not convinced my tune worked.
  4. Jan 28, 2020 at 7:44 AM
    #4404
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    he had an issue with his files, not miles
  5. Jan 28, 2020 at 6:38 PM
    #4405
    Styx2015
    Styx2015 Well-Known Member
    Paul
    2008 White Tacoma DCSB TRD Off Road
    Exactly what OV said. When I went to flash the ECU, an error dialog box came back saying that the file was unsupported format or could be corrupt. The flash process never proceeded past that point. Now it works though! Everything flashed successfully and I can definitely tell the difference. My Scangauge has never read such high MPG's.
  6. Jan 28, 2020 at 6:39 PM
    #4406
    Styx2015
    Paul
    Over about a 20 mile 90% highway drive, I was hauling a couch for a friend and doing 55mph on the highway (in the right lane of course). My avg MPG's for that trip was 18.5. And I'm on 33's, stock gearing, with steel front and rear bumper and full steel skids. I was flabbergasted
    TrailYeti and OldManTacoFeels like this.
  7. Jan 28, 2020 at 6:53 PM
    #4407
    TheBlueBeast15
    Kevin
    H-Town
    Nice. Sounds like it’s working.
  8. Jan 28, 2020 at 10:02 PM
    #4408
    da808fokai
    da808fokai Member
    Vance
    Portland
    05' DC Sport, 85' 4runner crawler
    Simple stuff
    For a second there I thought you said hauling a "coach" as in an RV. LOL! I have an inquiry out to OV in regards to an NA tune and towing.
  9. Jan 29, 2020 at 6:21 PM
    #4409
    ToyotaBurrito
    ToyotaBurrito Well-Known Member
    2013 AC Sport MT
    bobsuruncle likes this.
  10. Jan 29, 2020 at 7:58 PM
    #4410
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  11. Jan 30, 2020 at 8:48 AM
    #4411
    ToyotaBurrito
    2013 AC Sport MT
    I wasn't able to use it - my ECU isn't supported and I don't want to get a new ECU from the junkyard nor am I able to send him mine.
    Do people think $400 shipped is a good deal?
  12. Feb 1, 2020 at 12:25 PM
    #4412
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    Here are my experiences so far:
    The tune definitely changed the drivability. With the 91 tune it seems to have more torque down low. When I press the gas pedal it seems to get going better with less throttle and less rpm. First gear holds a bit longer before shifting at partial throttle and other transmission shift settings are different. The other gears hold a little longer before shifting under certain partial throttle load conditions and the shifts are a little firmer. The engine revs a few hundred rpm more before shifting at WOT. As far as WOT power, it's hard to say. Additionally, I haven't done a true mpg test yet but seems about the same.
    I tested the 0-60 times will both the 87 and 91 tune files using a 0-60 timer, but they didn’t drop off any time.
    I put in a request for their updated 93 tune back in November. Still waiting on the files to try them out. Overall, I am satisfied with the drivability. Hopefully there will be more people interested in buying this tune for the 4.0 so more development can be done for our trucks.
    rayban1 and TrailYeti like this.
  13. Feb 1, 2020 at 4:53 PM
    #4413
    da808fokai
    da808fokai Member
    Vance
    Portland
    Simple stuff
    Wade, curious if the power down low is a function of throttle position mapping or truly from changes in the ignition/fuel/valve timing.
  14. Feb 1, 2020 at 6:11 PM
    #4414
    wade9986
    Ross
    Stuart, Florida
    Not sure. Had similar results when adding 93 to the tank on the factory tune though. My ultra gauge shows a bit more timing advance under load at part throttle, such as going up a bridge.
    da808fokai[QUOTED] likes this.
  15. Feb 6, 2020 at 10:43 PM
    #4415
    qjwright
    qjwright Well-Known Member
    Quintin
    2017 trd sport
    The tune causes my truck to bounce off the rev limiter a few time before shift to third at full throttle. Any fix?
  16. Feb 6, 2020 at 10:47 PM
    #4416
    bassbrick
    bassbrick Well-Known Member
    Marcus
    Northern Virginia
    07 DSM Tacoma SR5 Access 4x4
    Falken Wildpeak AT3W 285/75/16 Load E, 3rd Gen Imitation LED Tail Lights, Jones JT2525XL Muffler with axle dump, K&N Cold Air Intake, Ultimate Headlight Upgrade, Baja SAE Fog Lights, 3 inch Toytec lift kit with aal and eibach coils, SPC uca, OVTune Ecu Flash
    If it is at rev limiter and holds then shifts that’s normal as that’s what I’ve experienced for the past year at WOT. Now if it’s truly banging against the limiter as it would if you floored it in neutral than that is a new issue.
  17. Feb 6, 2020 at 10:50 PM
    #4417
    da808fokai
    da808fokai Member
    Vance
    Portland
    Simple stuff
    Stop flat foot shifting :p
    bobsuruncle and bassbrick like this.
  18. Feb 14, 2020 at 8:08 PM
    #4418
    da808fokai
    da808fokai Member
    Vance
    Portland
    Simple stuff
    So I'm actually possibly interested in purchasing. Troubling aspect is that I sent an email inquiry with questions on 1/27 and received an answer to some of my questions on 2/3. Responded with repeating the unanswered questions on 2/3 and have yet to receive a response as of 2/14. Re-sent email with cal ID and summary of questions today. Got techstream and tactrix cable working together and pulled my calibration and it's not on the list of supported thus far. Not sure if there's an updated list. A new customer and hopes of a tune probably has diminished at this point unless I receive a response.
    Calibration # 30430000 - 6MT 2005'
    Zendesk request #12610
    Update: 2/21/20 - No response.
    Reading further it may not be possible to even flash my ecu? Promo for discount is ending soon and I started this question inquiry back on 1/27.
    @OVTune - Sorry for the tag, but not getting responses via email.
    Update 3/2/20 - Still no response. Promo discount has ended at this point. After further reading it looks like my ECU may not be supported. Was willing to send my ECU in, but likely not anymore with the lack of response. Oh well...
  19. Mar 23, 2020 at 2:57 PM
    #4419
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    OV Tune
    Is the 4.0 tune for second gens still available and where can I purchase (link please)???
    My info:
    CAL ID – 30480000 and CAL ID #2 – AOC01000
    2014 TRD Sport double cab long bed. V6, 4.0 L Automatic, 5-Spd Four-Wheel Drive (Link). 33” tires and plan to go to 4.30 gears. No supercharger.
    Goal – Want an 87 tune to try and improve MPGs for normal driving and towing trailer (especially out west with steep grades).
  20. Mar 23, 2020 at 6:15 PM
    #4420
    OVTune
    OVTune
    At this time we will only be offering support for the 4.0L with our tuning software:
