Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Nov 8, 2017 at 9:13 AM
    #661
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Handheld tuner - plug and play option that allows you to flash our tunes, that we develop for the engine and transmission. The handheld will hold 5 tunes, with different settings (like 87 octane tune, 91 octane tune, towing tune, etc)
    Handheld tuner "SC" - Exact as above but tunes developed specifically for the TRD Supercharger
    DIY Tuning Kit - Software + OBDII USB Cable that allows you to open your stock ECU file, edit maps as you wish, and tune the car yourself. Adjust your own ignition, or fueling, datalog the results, make changes you need. Comes with your OEM tune and we can provide a few helpful base files.
    DIY Tuning Kit - Custom tune option - not yet listed, but we can use the same kit and make the tune for you.
    The big difference here is the handheld comes with our Plug and Play style tunes for the engine. No additional work necessary, no datalogging, no back and forth.
    DIY option is not a handheld.
    PapaBear and SonnyBones like this.
  2. Nov 8, 2017 at 9:15 AM
    #662
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    When you say TRD supercharger, you also mean Magnuson SC as well correct?
  3. Nov 8, 2017 at 9:16 AM
    #663
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    If it matters the website only lists the handheld tuner, not one for NA and one for SC, but I imagine that'll be sorted when you contact us for details and all that.
    They're the exact same hardware so yes.
  4. Nov 8, 2017 at 9:17 AM
    #664
    OVTune
    OVTune
    Yes it's practically the same.
    Torspd likes this.
  5. Nov 8, 2017 at 9:18 AM
    #665
    OVTune
    OVTune
    Doesn't matter right now. As part of our intro offer SC and NA folks get the same special deal. In the future there will be a dedicated SC handheld but it will cost more (there is a lot more work involved in the tune)
  6. Nov 8, 2017 at 9:21 AM
    #666
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    My bad sorry about the repost
  7. Nov 8, 2017 at 9:29 AM
    #667
    Old School
    Old School You are ignoring covfefe by this member.
    Mat
    Can you post links on post #1, that will take us to all the 2nd gen options on your website ?
    I want to order the handheld for n/a 4.0
  8. Nov 8, 2017 at 9:43 AM
    #668
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    YGPM OVTune.
  9. Nov 8, 2017 at 10:17 AM
    #669
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. They are the same.
    SonnyBones[QUOTED] likes this.
  10. Nov 8, 2017 at 10:22 AM
    #670
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Before I order is it possible to use it in two vehicles with one device/license? I have two vehicles with the same 1gr.
    PapaBear, DanoDavis and Torspd like this.
  11. Nov 8, 2017 at 11:11 AM
    #671
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    This probably goes without saying, but people that are thinking about the DIY Tune kit......i sure hope you guys know what you are getting into. Because if you don't, you can possibly turn your 1GRFE into a boat anchor and will be shopping for a spare replacement motor....or have to rebuild your current one.
    Look at it this way... the OVT handheld tuner is like buying on off-the-rack suit from Men's Warehouse. The suit will fit you ok and come pretty darn close to your exact inseam, length, chest and neck width......but it won't be an exact perfect fit. You be pretty happy with they way you look and you'll walk out of the store with your new threads in about 30-45mins.
    The OVT DIY kit is like buying a custom tailored suit from the designer. The tailor will take all of your measurements, chalk it up, and then sew up your suit to your exact specification. Be prepared to stand and sit for hours as the tailor sews the suit so it fits your own body. In the end, Your clothes will look like Brad Pitt walking at the Oscars.
    The difference between the two (handheld/DIY) is pretty substantial. The handheld should have your truck running better than stock in less than an hour. The DIY kit will have your truck running it's very best if you optimize the tune on a dyno.....and then possibly retweak the tune again while finalizing road testing. Custom tuning for optimal performance will require a LOT of man hours. And dyno time around where i live is around $100/hr.
    Sorry if I'm preaching to the choir, but I've read some questionable replies that's making me shake my head. If you have a SC with the TRD reflash and want to use the DIY kit, it's not going to be "press this button and poof....AFRs are all perfect now".
    Buyers: Please be cautious and know what you are doing with EFI if you go with the DIY kit. If not and you still want the DIY kit, then leave the tuning to a professional and reputable dyno tuning shop.
    @OVTune : if anything i said was inaccurate, please correct what i wrote.
    Disclaimer: I've purchased the OVT handheld unit for my truck. And my experience with DIY kit was well over a decade ago with SDS EFI, APEXi PowerFC, TecII, and more recently Megasquirt.
    /off my soapbox
  12. Nov 8, 2017 at 11:16 AM
    #672
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thinking a DIY kit for myself..
    @OVTune gonna try and call you guys later today.
    christhebassman and PapaBear like this.
  13. Nov 8, 2017 at 11:35 AM
    #673
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    so this may be a really stupid question but that is par for the course....
    how do I order? I checked post 1 and no website. if you could point me to the website I think I may order before the first batch is gone.
    Carl
  14. Nov 8, 2017 at 11:36 AM
    #674
    omgwtfbbq!
    Ohio
    2013 X-Runner
    https://www.ovtuned.com/collections/tacoma
  15. Nov 8, 2017 at 11:59 AM
    #675
    mercerc
    Carl
    Palmyra NY
    thanks. I ordered it... Now I have to figure out what I ordered... :)
    I panicked when I saw 10 left... I am just hoping for more response/seat of pants improvements in feel. I would guess since I have a pretty much stock 2011 (TRD exhaust is it) that there is not much to do in terms of HP improvements... but with the throttle response and shift point adjustments I think it could "feel faster".
    Am I on the right track with how I think it works (sorry, I paid much more attention to the 3rd gen thread on this as it was first to show up).
    Carl
  16. Nov 8, 2017 at 12:31 PM
    #676
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All I hear is," get DIY; build engine; Maximum POWA!"
  17. Nov 8, 2017 at 1:42 PM
    #677
    DanoDavis
    DanoDavis Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    @OVTune
    Before I order:
    If mods change on the truck, would you be able to send us a new tune for the handheld?
    I'm going to be supercharging the truck, but I'd like to optimize what I've got on the truck already.
    I know you said it holds 5 tunes.
    And on the flip side, if a tune seems to not mesh well with the truck, I'd imagine that we could somehow log the info, send it back to you, and you could make some adjustments?
    I think that's how I understand it.
    Thanks!
  18. Nov 8, 2017 at 1:47 PM
    #678
    DanoDavis
    Daniel
    Allen Tx
    Aaaaaaaaaaaaand I ordered a handheld.
    This'll be nice.
  19. Nov 8, 2017 at 1:56 PM
    #679
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Mega :puke:
    Lol jk
    All in all I understand the risks, thanks for the post
  20. Nov 8, 2017 at 1:56 PM
    #680
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hang on. There is two versions available? I want one where I can tune the parameters myself. Which one is that one? Count me in if you have where you can do that.
    PapaBear likes this.
