Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Nov 8, 2017 at 5:44 PM
    #701
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My man. :thumbsup:
    yota243 and PapaBear[QUOTED] like this.
  2. Nov 8, 2017 at 5:45 PM
    #702
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Definitely want to see some videos
    PapaBear[QUOTED] likes this.
  3. Nov 8, 2017 at 5:49 PM
    #703
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Im also hoping that, with the tuning portion taken care of, that we see some more off the shelf turbo parts start popping up for this motor
    Torspd and PapaBear like this.
  4. Nov 8, 2017 at 6:02 PM
    #704
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    @OVTune can you set up a discount code for local pick up that will eliminate the shipping fee ? I live 5 miles from you...
    12TRDTacoma and PapaBear like this.
  5. Nov 8, 2017 at 6:29 PM
    #705
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    It will be a couple months, but I'm piecing together parts. Truck needs some work first, timing chain, timing chain gasket, power steering. I've seen it done before, I've followed @Torspd 's build for as long as I've been on. I don't want to stroke it like he did but I do want to make sure the engine can take it. There's lots of hoops I'll have to jump through but I'm willing to make it work. I was going to go LT but decided to cut back, go MT, and spend the money elsewhere. I'm going to go lean first with boost when I get to that point, the engine's already running with 105k miles. Once I can settle and have it run smooth with low numbers, I'll probably build the engine for more. Overbore, sleeve and go as close back to stock displacement, and go from there.
    Torspd[QUOTED] and GT7[QUOTED] like this.
  6. Nov 8, 2017 at 7:09 PM
    #706
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Don't forget a bigger heat exchanger, too. You know, just for more overkill.
    PapaBear likes this.
  7. Nov 8, 2017 at 7:10 PM
    #707
    GT7
    Grant
    Phoenix
    2013 DCLB
    In time Jason, I gotta slow my self down or find a sugar momma
  8. Nov 8, 2017 at 8:29 PM
    #708
    Jtaoj0
    Jtaoj0 Well-Known Member
    @OVTune What is the HP and Torque increase for a naturally aspirated 4.0? Looked on the ste and can’t see it. Thanks.
  9. Nov 8, 2017 at 9:38 PM
    #709
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I would say the hand held tuner will be good for most people...
    If you want the most out it yeah you have to self tune, but need to be good at tuning or get some dyno time..
    For me it's also my hobby, I like tuning and can't wait to go through the maps of the Tacoma. I all ready have a bunch of ideas I want to try out...
    Plus I can spend a lot more time fine tuning it the way I like.
    I will say either way you can't loose...
    wicycletester and PapaBear like this.
  10. Nov 9, 2017 at 10:51 AM
    #710
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Stuff is Happening
  11. Nov 9, 2017 at 11:56 AM
    #711
    lynchpin911
    lynchpin911 Member
    2015 Xsp-X 4x4
    When will we see the gains from the tunes?
    DanoDavis likes this.
  12. Nov 9, 2017 at 11:58 AM
    #712
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    I plan on doing comparison dyno pulls as soon as possible once I get the hardware. Lead time for my dyno is usually about a week.
  13. Nov 9, 2017 at 12:26 PM
    #713
    OVTune
    OVTune
    as soon as everything is finished up
  14. Nov 9, 2017 at 12:28 PM
    #714
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    HeyI emailed you but havent gotten anything back in about a week, I know you are a busy guy but do you know when you will be able to get to your emails?
  15. Nov 9, 2017 at 1:03 PM
    #715
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ditto
  16. Nov 9, 2017 at 2:38 PM
    #716
    OVTune
    OVTune
    I check my email daily but some stuff I have to get to before others. If it's about dynoing I will get back to that stuff once I have more dyno days locked down.
    As for turbo stuff, definite possibility and we work closely with a company that makes amazing turbo kits.
  17. Nov 9, 2017 at 2:53 PM
    #717
    PapaBear
    Austin
    SIN CITY
    Since you won't be shipping the handhelds anytime really soon, any info on when you'll be shipping self tune kits? Cause I want mine :rofl:
    XPOTRPR and DanoDavis like this.
  18. Nov 9, 2017 at 7:14 PM
    #718
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Ordered...sure hope this thing arrives tomorrow with that promised 100rwhp/10 mpg gains...right???
    Ok, I didn't see any info on the tuning parameters so I'm assuming with the 4.0 TRD sc & flash, 2.7 pulley, cai, long tubes, cat back and 320 pump this tuner is capable of making all those items love each other even more as well as firm up the shifts, remove the speed limiter, bump up the redline a little and get rid of that annoying cel.
    Another 10-15hp and a little better mpg would be great.
    When exactly are these things scheduled to ship???
    DanoDavis and GT7 like this.
  19. Nov 9, 2017 at 7:54 PM
    #719
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Supposed to arrive on 12/25 (conveniently on xmas) to everyone.
  20. Nov 9, 2017 at 8:47 PM
    #720
    Gaunt596
    Matthew
    Central Maryland
    id seriously consider boosting my truck once there is a tried and tested system available, so i wont be spending months tracking down gremlins
