Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Nov 12, 2017 at 7:06 PM
    #741
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    Stupid question...
    I take my truck to the dealer for regular service and if there is an update to the ECU, what will happen?
    Do the dealers completely flash on some sort of update or do they "software patch" what is there? Curious if they can/will kill the whole ECU.
  2. Nov 12, 2017 at 7:10 PM
    #742
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Do your own shit. Its rewarding and cheaper. You know whose grubby hands have been on your truck
    Norton likes this.
  3. Nov 12, 2017 at 7:42 PM
    #743
    DanoDavis
    DanoDavis Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    Very, very, very doubtful.
    The handheld tuners can flash-back to factory specs, if you're super worried.
    Flash to OEM for service, flash back to your specs afterwards.
  4. Nov 12, 2017 at 8:53 PM
    #744
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    It will over write your tune. So no need to do updates after you flash the ecu... By now there are no updates that you would really need.
    The tune changes the factoring settings so a factory update would most likely not be needed.
    I'm sure if a dramatic updates would happen OVT will incorporate it in updates, but that's more likely on 3rd gens not 2nd gens...
  5. Nov 12, 2017 at 9:15 PM
    #745
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
  6. Nov 13, 2017 at 7:00 AM
    #746
    anonemoose
    Bill
    Big Pine, Calif
    Thanks all.
    I got 8 more years of free maintenance, that cost a fortune, too old to do that stuff anymore.
    I think I'll flash to stock and then revert after.
    GT7 likes this.
  7. Nov 13, 2017 at 7:01 AM
    #747
    GT7
    Grant
    Phoenix
    2013 DCLB
    Okay right on. I seriously wouldnt worry about it.
    DanoDavis likes this.
  8. Nov 13, 2017 at 8:19 AM
    #748
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    OVtune, is the second gen Tacoma going to be included in your plans? I am interested in seeing the cam control strategy.
  9. Nov 13, 2017 at 8:26 AM
    #749
    GT7
    Grant
    Phoenix
    2013 DCLB
    This is for the second gen tacoma. :confused:
  10. Nov 13, 2017 at 8:34 AM
    #750
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Excited for the hp/mpg results
  11. Nov 13, 2017 at 8:45 AM
    #751
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Where have you been?
  12. Nov 13, 2017 at 8:57 AM
    #752
    Hacktacular
    Robert
    Yes, sorry. I saw the post where it was for 3rd gen. I see now it is for both. I am running Haltech anyway, but still interested in this if it can do what the stand alone can and keep my traction control or VSC light off.
  13. Nov 13, 2017 at 3:17 PM
    #753
    DanoDavis
    Daniel
    Allen Tx
    Wait a tick.. Black Friday will be here before we know it! TunerTime will soon be upon us!
  14. Nov 14, 2017 at 8:28 AM
    #754
    magneticwhite88
    Brandon
    OC, CA
    Really want to get the handheld tuner while it's available but I can't get myself to buy it without knowing the performance/driving benefits
    Norton likes this.
  15. Nov 14, 2017 at 8:31 AM
    #755
    DanoDavis
    Daniel
    Allen Tx
    Check out the 3rd gen tuners he made.
    They’re getting something like 20+ ft lbs of torque gains down low/mid range.
    Obviously it’s a different engine, but I suspect similar results.
    Read this thread:
    https://www.tacomaworld.com/threads/ovt-flash-on-a-2010-tacoma.500463/
    Sounds worth it to me.
  16. Nov 14, 2017 at 8:40 AM
    #756
    magneticwhite88
    Brandon
    OC, CA
    Been reading the crap out of that thread, I'm hoping for better low end torque as well as better shifting between 4th and 5th.
    I think it'll be worth it, just want more power!! :angrygirl::angrygirl::angrygirl: Curious to see how much an N/A with bolt ons will put down!
    PapaBear likes this.
  17. Nov 14, 2017 at 8:44 AM
    #757
    DanoDavis
    Daniel
    Allen Tx
    I’ve got every Bolt-on except a SC (which will be done next year.)
    URD True CAI w/ MAD calibrator, long tube headers, with full exhaust, and a intake plenum spacer. Assuming I can fix my current drivability issue(s) (02 sensor problems, and lagging- may be related.)
    The truck is WAY quicker compared to stock. I’ll be doing a before and after dyno run once I get my handheld.
    Hopefully that will give you the info you need.
  18. Nov 14, 2017 at 9:09 AM
    #758
    magneticwhite88
    Brandon
    OC, CA
    that would be great! I'm also hoping OV comes out with Dyno numbers once everything is completed.
    DanoDavis[QUOTED] likes this.
  19. Nov 14, 2017 at 9:51 AM
    #759
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Exact same thought process I have. The rep is good, but I've seen other well-rep'd vendors that have trouble delivering. Just waiting myself. No disrespect to OP, but, for me, "trust, but verify".
  20. Nov 14, 2017 at 9:55 AM
    #760
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Not a problem at all, and no worries for anyone this isn't our only time we will offer this. This is just our introductory deal to the 4.0 owners. We will be around a long time and will be developing everything we can
