Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 5, 2018 at 5:50 PM
    #1401
    Taco'09
    Taco'09 Well-Known Member
    I will buy it just to defeat that rotten thing. Secondary air injection valves stuck recently and left me out in the boonies in limp mode...I was about as mad as they come.
    04TacoRunner and Atlas86 like this.
  2. Feb 5, 2018 at 6:19 PM
    #1402
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    Oh shiiiiiiiiiiiiiit!
  3. Feb 6, 2018 at 5:27 AM
    #1403
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'd buy it just to disable the intake cam cel. Especially now that things are up and running.
    Brice, RedLantern and Lucario Runner like this.
  4. Feb 6, 2018 at 8:23 AM
    #1404
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2011 D-CAB Black TRD Sport, JBL with Sat
    leveling kit, Cooper 255/80R17 tires on 4Runner rims, Leer cap, Ovtuned (not yet working), K&N filter, TRD catback, Riderite air bags
    @OVTune, if I remember correctly on the 2016+ threads, you had trouble with tune over time due to the learning process. I believe your solution was to disable the learning? If so, are you going to disable the learning in the 4.0L also? the reason I ask is: I have been chasing a loss of MPG lately. I cleaned my air filter, changes the PCV valve and reset the computer with a half hour battery disconnect... my MPG's jumped up to acceptable for one tank then went back into the toilet. the moral of the story is it is possible the learning could impact our tune like it did the 3.5L
    Carl
  5. Feb 6, 2018 at 3:25 PM
    #1405
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    The 4.0L does not have learning in the ECU like the 3.5L. The only learned things that are stored in the 4.0L are ignition trims (knock feedback) and fuel trims. No shift learning, no torque management learning or any of those complexities
    Brice, DanoDavis, Norton and 4 others like this.
  6. Feb 6, 2018 at 6:24 PM
    #1406
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    It’s been hours since someone bitched. Is it all working? Supercharged guys happy?
  7. Feb 6, 2018 at 6:48 PM
    #1407
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    Please let me know when 30473000 is ready @OVTune, thanks
  8. Feb 6, 2018 at 6:52 PM
    #1408
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :rofl:
    Brice and TRON like this.
  9. Feb 7, 2018 at 3:31 AM
    #1409
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Mat @OVTune is still building the tuning file for the 4.0 NA ECU. He said he expects to send the file out to handheld users Friday.
    So nothing to bitch about...just gotta have patience.
  10. Feb 7, 2018 at 2:37 PM
    #1410
    ThomasMore66
    I'm just waiting for all you guys to be happy and then I'll make my Ucon/OV decision.
  11. Feb 7, 2018 at 2:45 PM
    #1411
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im happy enough
    jojotoo likes this.
  12. Feb 7, 2018 at 4:07 PM
    #1412
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    ha I just asked him about that. Good to know. I did not get ECU not found so just waiting on N/A maps to be sent.
    bobsuruncle likes this.
  13. Feb 7, 2018 at 9:58 PM
    #1413
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Hahahahehehe....NO.
    Brice and Torspd like this.
  14. Feb 8, 2018 at 8:00 AM
    #1414
    ThomasMore66
    Honestly, how is it going? Did you have the TRD tune first? I've got a TRD tuned 2013 and I'm debating OV vs UCON.
    Norton likes this.
  15. Feb 8, 2018 at 8:23 AM
    #1415
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    UCON + Stock ECU here.
    AFe intake, 2.55 pulley, 7th injector, URD Header/Ypipe/exhaust, no cats, IPT trans.
    No problems.
    TacoCat and cdelgado14 like this.
  16. Feb 8, 2018 at 9:11 AM
    #1416
    ThomasMore66
    I thought you were going Ucon.
  17. Feb 8, 2018 at 10:33 AM
    #1417
    GT7
    Grant
    Phoenix
    2013 DCLB
    It says ucon before anything else
    We have both been ucon since batch #1
    nudavinci64 and loginfailed like this.
  18. Feb 8, 2018 at 11:13 AM
    #1418
    ThomasMore66
    Duh! Supposed to be working...slip over here and scan the headlines.
    loginfailed and GT7[QUOTED] like this.
  19. Feb 8, 2018 at 5:51 PM
    #1419
    dbs1
    Dan
    I'm counting down the months, er, ah days till I can actually load a tune, then see what it does.
  20. Feb 8, 2018 at 5:56 PM
    #1420
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Well just imagine your truck with an extra 20 hp. No mystery there. Wait over.
