Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 10, 2018 at 2:05 PM
    #1481
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    What are the settings you have for boosted applications? I personally would prefer not to increase my engine redline more than 500rpm.
  2. Feb 10, 2018 at 2:11 PM
    #1482
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    That seems like some pretty decent praise.
    DanoDavis likes this.
  3. Feb 10, 2018 at 2:15 PM
    #1483
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Rev limit is not extended on SC tunnes.
    It's also only a maximum of 300 rpm on NA flashes
    Norton and Roostfactor like this.
  4. Feb 10, 2018 at 2:19 PM
    #1484
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Yessir
    Roostfactor likes this.
  5. Feb 10, 2018 at 2:21 PM
    #1485
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Mine red lines at 5500 still, anything over I think isn’t safe with boost
  6. Feb 10, 2018 at 2:26 PM
    #1486
    WOODEX M.E.
    Corey
    Maine
    That makes me feel much better.
  7. Feb 10, 2018 at 2:29 PM
    #1487
    WOODEX M.E.
    Corey
    Maine
    Out of curiosity, was this tuner able to firm up shifts in any way? Im avoiding doing the valve body upgrade if i dont have to. I know they cant really be equated to eachother, but sometimes the easy way is just enough for the application. I thought last time i looked our mods were fairly similar.
  8. Feb 10, 2018 at 2:36 PM
    #1488
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    When I had the tune installed @OVTune said he could do some things to make it shift firmer but that it wouldn’t be as good as the valvebody. I never had him modify the shifting as I installed the valvebody upgrade a few weeks later.
  9. Feb 10, 2018 at 2:39 PM
    #1489
    WOODEX M.E.
    Corey
    Maine
    Hmmmmmm. Guess ill have to look into it when the time comes and these are out for sale again. Im at the point now where my shifts literally depend on the weather. If its around -20 to +30f it hangs up on the shifts (i assume from the extra boost) but when its warmer out its usually not an issue. I am thinkng this mod would the the straw that pushed it over the edge.
  10. Feb 10, 2018 at 3:05 PM
    #1490
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    Just out of curiosity, what would happen if I put a 91 NA tune in my truck and accidentally
    put 87 in the tank?
    Carl
  11. Feb 10, 2018 at 3:32 PM
    #1491
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    (You have insufficient priveledges to reply here.)
    Thread Status: Not open for further replies.
    :D
  12. Feb 10, 2018 at 5:12 PM
    #1492
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How valuable is your engine?
    Norton, PapaBear and Roostfactor like this.
  13. Feb 10, 2018 at 5:13 PM
    #1493
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Man I hope you guys make a economical reliable tube for the 4.0.
  14. Feb 10, 2018 at 5:22 PM
    #1494
    mercerc
    Carl
    Palmyra NY
    Valuable enough to be concerned about wife/son using the gas they have used for 6 years.... by accident...
  15. Feb 10, 2018 at 5:23 PM
    #1495
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    91 Minimum Sticker on gas cap, perhaps?
  16. Feb 10, 2018 at 5:25 PM
    #1496
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Ed, Any chance you could share a performance mods list on your NA truck?
    I have been following this thread since start-up to see if performance pans out on NA.
    Do you have any plans to dyno?
  17. Feb 10, 2018 at 5:44 PM
    #1497
    mercerc
    Carl
    Palmyra NY
    Who are you? Ovtune's Secretary? It's a simple question anyone who purchased a handheld should be asking? I meant no disrespect to ovtune. Since I paid for my handheld and i am evaluating what tune to use I will ask more questions.
    Carl
  18. Feb 10, 2018 at 5:47 PM
    #1498
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I would put my truck in a tube to avoid door dings :D
  19. Feb 10, 2018 at 5:55 PM
    #1499
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    As long as you are NA, it MIGHT knock real bad and hopefully that would give your uninformed drivers an alert to notify you. At that point you let them know to drive really mellow until they get get to the nearest quickmart to purchase some octane booster.
  20. Feb 10, 2018 at 6:00 PM
    #1500
    OVTune
    OVTune
    This is actually an important question and something important to understand. The ignition is calibrated to maximize power and efficiency for the expected octane, the 91 octane tune has ignition advance targets that are not safe to run with 87 octane. It's *unlikely* that you will cause permanent damage, BUT the truck will detonate (ping,knock) very heavily and the ecu will reduce the ignition advance multiplier to the lowest possible level. This will put the ECU into it's safe maps and you will get worse performance than stock.
    It is important that you use the required octane that the flash calls for, or higher.
    For example on a 91 map you can use 91,92,93, etc. But not lower than 91.
    On an 87 map you can use 87 or higher, but not 86/85. I know in some states with high elevation like colorado and utah there is 85 at the pump, I do not recommend using this even on a stock truck. I lived and tuned in colorado for a number of years and know for a fact that the elevation is not saving you from knock with 85 octane. Especially since these states do get quite hot in the summer.
    Norton and Brice like this.
