Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 11, 2018 at 9:37 AM
    #1521
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I second that!
  2. Feb 11, 2018 at 9:48 AM
    #1522
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    I don't think we even allowed to call em 'secretaries' any more... not pc. I think it's personal assistant or some shit now
  3. Feb 11, 2018 at 10:55 AM
    #1523
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    My secretary became an Administrative Assistant but still did the same great job.
  4. Feb 11, 2018 at 11:03 AM
    #1524
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  5. Feb 11, 2018 at 11:08 AM
    #1525
    DanoDavis
    DanoDavis Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    I CAN HOLD IT!
    Torspd and Roostfactor[QUOTED] like this.
  6. Feb 11, 2018 at 11:09 AM
    #1526
    DanoDavis
    Daniel
    Allen Tx
    Forreals though, who was his N/A guinea pig? I want to see a dyno sheet.
  7. Feb 11, 2018 at 12:21 PM
    #1527
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Any chance well be able to update the tuner with Mac OS?
    loginfailed likes this.
  8. Feb 11, 2018 at 1:48 PM
    #1528
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    And what will the price be? I don't see myself dropping almost $800 if it's priced the same as the 3rd gen model. It would have to do a lot on a n/a truck to get me to justify spending that much on an older car.
    Don't know what the speed limiter even cuts the truck off at but how fast are you driving it to need that? I've got a car for going fast.
    Norton likes this.
  9. Feb 11, 2018 at 2:18 PM
    #1529
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    114mph tested on a closed course by a professional driver of course :anonymous::burnrubber:
  10. Feb 11, 2018 at 3:19 PM
    #1530
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    Ours were ~500
  11. Feb 11, 2018 at 3:43 PM
    #1531
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Just fyi knock on a stock 1gr is a very worst case senario as the powdered metal rod and hypereutectic pistons are not strong enough to remain in one piece under sustained knocking at load. If you realized you put in 87 for a 93 tune than do not put a lot of load on it and you should be ok. Honestly unless I trusted the person enough to put the right fuel in than either make a note of it or dont let them operate the vehicle. I've seen too many diesel in gas vehicles and too many gas in diesel trucks to many times to count.
  12. Feb 11, 2018 at 4:08 PM
    #1532
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Yeah, ok. I’ve never street raced. That would be wrong.
    Roostfactor likes this.
  13. Feb 11, 2018 at 6:59 PM
    #1533
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Facts hammer.
  14. Feb 12, 2018 at 12:32 AM
    #1534
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If not, there are VM solutions available. Parallels, VMWare and Virtualbox. I personally use Bootcamp for the few Windows apps I still need.
    steezinstangl likes this.
  15. Feb 12, 2018 at 8:35 AM
    #1535
    TTacoSR5
    TTacoSR5 Well-Known Member
    2017 4x2 V6 SR5 Double Cab Black
    Plasti-dip badges & grille Flowmaster 40 series muffler Pittasoft Dash cams SmartShift Pro
    Can someone provide a TL;DR on this? Is there a tuner we can get for our 4.0's?
  16. Feb 12, 2018 at 8:49 AM
    #1536
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Tuner, yes. Canned tune(s) for that tuner, not quite yet.
  17. Feb 12, 2018 at 4:22 PM
    #1537
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    more ECU versions should be available in tomorrow update
    30452000 as well
    thank you guys for being patient I know this part of the process is shitty as hell, (getting ECUs added)....I guess the good part of it they only have to be added ONCE to be available indefinitely.
    Brice, Old School, Torspd and 4 others like this.
  18. Feb 12, 2018 at 4:48 PM
    #1538
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I’m looking forward to hearing from other 4.0 NA owners and their reviews!
    I’m having a ball wasting gas!
    DanoDavis, Torspd and Roostfactor like this.
  19. Feb 12, 2018 at 7:14 PM
    #1539
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Who is the jack wad that's being patient???? Just had to throw that out there. Of my 6 med tests, its 4 down and 2 to go. Wondering which of these fun, patient requiring things will happen first???‍⚕️
  20. Feb 12, 2018 at 7:41 PM
    #1540
    DanoDavis
    Daniel
    Allen Tx
    Is it a big difference?
    I haven’t had a chance to do mine yet, out of town.
    What other Bolt-ons do you have?
