Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 14, 2018 at 4:40 PM
    #1621
    ThomasMore66
    Dallas/Fort Worth & Durango
    What years have been uploaded?
  2. Feb 14, 2018 at 5:05 PM
    #1622
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    5 day update...I have a 2014 DC SB...I shift my gears while driving 5th down to 3rd always...occasionally to 2nd...never to 1st.
    In 3rd or 4th with the revised powerband I can easily overtake any car and going uphill, truck will easily accelerate to redline and I’ll need to shift up.
    The 91 tune and running 93 gas has really removed all hesitation the truck had. This truck is now quick getting from 2,800 to redline.
    The truck responds and shifts really well.
  3. Feb 14, 2018 at 5:54 PM
    #1623
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Thats good news. Hopefully I can regain my bottom end that I lost with header back exhaust and no cats. The motor struggles to get up and go below 2800rpm currently with the lost back pressure.
    I've been waiting 2yrs to feel the benefit from all my bolt ons that I found out where worthless, after the fact, without a tune that works in unison with them.
  4. Feb 14, 2018 at 10:00 PM
    #1624
    Taco Reaper96
    Taco Reaper96 Well-Known Member
    2008 Black Tacoma TRD Offroad
    Fog Light Mod, Kenwood Head
    I've held out on bolt ons simply because without a correct tune they would be little more then expensive noise makers plus maybe 5-10 hp. UCON is solid but 3x the price, Bullydog isn't this involved, and unichip seems to have mixed reviews from what I've seen.
    bobsuruncle likes this.
  5. Feb 15, 2018 at 4:29 AM
    #1625
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    No! It isn't because you lost back pressure. Back pressure is always bad. You moved your torque curve because you changed the wave harmonics of your exhaust system and didn't adjust your cam timing. Let the back pressure myth die! :annoyed:
  6. Feb 15, 2018 at 5:01 AM
    #1626
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    The 1gr needs some backpressure as NA.
    The 1gr has variable valve timing on intake only
    I am not sure how one goes about adjusting the timing other than UCON control
    URD offers cam gears for exhaust side to help empty exhaust more but there is not significant information on gains
    Backpressure is always bad for turbo/ supercharged setups
  7. Feb 15, 2018 at 5:34 AM
    #1627
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    YWG2800 yet?
    Pretty please!
  8. Feb 15, 2018 at 5:35 AM
    #1628
    omgwtfbbq!
    Ohio
    2013 X-Runner
    Incorrect. Nothing needs back pressure. Back pressure is always bad. But like I said, if you change your exhaust system harmonic properties, you need to adjust to account for it. The engine was tuned with the OEM exhaust system in place, and the OEM tune works best with that setup. If you change the exhaust and nothing else, of course performance is going to suffer, you've disrupted a major part of the system that Toyota spent years optimizing. That doesn't mean that 'you need backpressure' it just means if you buy a more freely flowing exhaust you need to compensate for it.
    I understand why the myth persists, exhaust design is a lot more complicated than most people realize. We're talking advanced fluid dynamics and acoustics. People get doctorates in subsections of gas interactions that have to be accounted for when designing an exhaust. That being said, if you'd like to learn more, swing by your local library and check out this handy little book. It's not an exciting read, and it's definitely a little dated but it touches on the fundamentals of good exhaust design without getting insanely technical.
    Of course if you wanna keep spouting uninformed nonsense then I can't stop you, and since this is wildly off topic if you'd like to discuss it further please send me a PM. :cheers:
  9. Feb 15, 2018 at 5:41 AM
    #1629
    BillDaCat8
    Jake
    PHX
    Eager buyer here. Buy it back from him, make sure it works ok and sell it to me. I can pick it up in person in Vista mid March.
  10. Feb 15, 2018 at 6:33 AM
    #1630
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    I'm a believer that some back pressure is needed for optimal performance, but like you said that's for the way Toyota has engineered and tuned this motor. Taking all the cats out was a bit too much for NA. For FI, hell yeah no cats, open er up! Let that sucker breathe! Either way, I'm not making any more modifications to my exhaust unless it's a resonator. It seems once vvti kicks in, 2800rpm or so, it rasps a lot. DTLT, URD comp Y, and mbrp can, 2.5" header back.
    StuckinOhio likes this.
  11. Feb 15, 2018 at 6:41 AM
    #1631
    omgwtfbbq!
    Ohio
    2013 X-Runner
    You're wrong and I can prove it with math! ;)
    Roostfactor, Brice and Taco Suave like this.
  12. Feb 15, 2018 at 6:43 AM
    #1632
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Never claimed to be right, just what I believe. I've been wrong before. :bowdown:
    Roostfactor, Brice and Torspd like this.
  13. Feb 15, 2018 at 6:51 AM
    #1633
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    OH, don't do that, my brain may explode. :D
    I do agree with you on the back pressure myth though. Back pressure is nothing more than the measure of how much restriction there is in the exhaust. Best way that I have found to settle this in my mind is that your concern needs to be exhaust gas velocity, as at low speed you want high velocity (smaller pipe) to enable exhaust gas scavenging from the cylinders. At high engine speed, you still want high velocity, but to enable that you need a larger pipe. Exhaust system design, pipe size and "devices" in the stream, is a compromise between the two with optimization for low, mid, or high rpms (notice OR here, pick one to optimize).
    Brice and bobsuruncle like this.
  14. Feb 15, 2018 at 7:12 AM
    #1634
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    https://youtu.be/jjPeP_Nn2B4
    Check this video out on back pressure by an engineer. Ok ok lets get back on topic :D
    builder, Brice and Norton like this.
  15. Feb 15, 2018 at 8:56 AM
    #1635
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    URD Supercharger! I'm in
  16. Feb 15, 2018 at 12:54 PM
    #1636
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    4.0 NA AT. Have not done any freeway or offroad yet but so far it feels the shift points are different. Truck holds out a tad longer before shifting. Once it gets into the mid band of the RPMs it has a nice feel. Shifting seems smoother. Still lags like a MoFo but again that is from my heavy ass tires. Tried playing around with readings on my OBDII sensor but no replacement for a Dyno.
    @bobsuruncle you were soo close. =p
    bobsuruncle and EdinCincinnati like this.
  17. Feb 15, 2018 at 1:14 PM
    #1637
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    DanoDavis likes this.
  18. Feb 15, 2018 at 1:24 PM
    #1638
    nudavinci64
    Robert
    ha nice! looks like it worked out. You get it installed yet? Were heading to the Mojave Desert next week. I may try the 91 tune for that trip.
  19. Feb 15, 2018 at 1:30 PM
    #1639
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    If the people just now ordering get their tune before me I'm gonna be seriously butt hurt.
    omgwtfbbq! likes this.
  20. Feb 15, 2018 at 1:46 PM
    #1640
    nudavinci64
    Robert
    Were you at least able to download your map and send it to him for the tune? If so you should get it soon. Took me a couple weeks but sounds like if the ecu is on there you should be good.
