Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 15, 2018 at 6:11 PM
    #1661
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    No worries I can catch ya up to speed, what do ya want to know?
    Here’s some commom Q’s I get a lot in my PMs:
    Yes I was on the stock TRD tune
    My mpgs have not changed much and I think when I go back to summer gas they will improve
  2. Feb 15, 2018 at 6:13 PM
    #1662
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I never understood people wanting a supercharger yet worry about mpg
    Roostfactor and loginfailed like this.
  3. Feb 15, 2018 at 6:13 PM
    #1663
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    That's what turbos are for ;)
    DanoDavis likes this.
  4. Feb 15, 2018 at 6:14 PM
    #1664
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You have a build thread? Curious what your mods are.
    Mine gets a pretty consistent 13.5 MPG. Is that good? :D
  5. Feb 15, 2018 at 6:15 PM
    #1665
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I thibk once people put on their heavy offroad tires, bumpers, sliders, bed racks etc they want to get anything they can. I agree for to get the best mpg you are basically driving the truck with out the supercharger..
  6. Feb 15, 2018 at 6:16 PM
    #1666
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    No build thread but I should probably start one. At the time of the dyno this is what I had:
    Bypass jet removed
    AFE air intake (dry)
    Urd 2.85 stealth pulley
    Jba shortie headers with stock cats welded on
    Banks 3” catback
    Stock ypipe
    Deatschwerks 255 lph fuel filter
    I think that’s everything.
  7. Feb 15, 2018 at 6:17 PM
    #1667
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    What?! Nobody supercharged gives a shit about fuel economy. Its all about the power!
    That said you should do like an AEM meth kit, larger injctors, and the 2.7 pulley and get tuned so I can get a copy of your tune from OVTune and then move on with my life lol.
  8. Feb 15, 2018 at 6:19 PM
    #1668
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I’m probably going to put together my own meth kit, just gonna inject it at the throttle body instead of tapping into the supercharger.
    I might do 2.55 or 2.7 pulley haven’t decided which one yet, and will probably get my stock injectors reflowed instead of buying one that requires an adapter. Time will tell :D:spending:
  9. Feb 15, 2018 at 6:22 PM
    #1669
    WOODEX M.E.
    Corey
    Maine
    Well get on that cause i want some of the good stuff. And im tired of figuring it out on my own.
    If i could just do the 2.7 and a tune and get, i dunno 35hp id call it a day and leave the truck as is. Its been pretty reliable and ive been boosed for about 92,000 miles. Id like another 90k before major problems start showing.
  10. Feb 15, 2018 at 6:25 PM
    #1670
    WOODEX M.E.
    Corey
    Maine
    Who am i kidding i want 50hp, but i dont want to sound greedy and unreasonable.
  11. Feb 15, 2018 at 6:41 PM
    #1671
    tacooh
    tacooh Active Member
    Brad
    SW Ohio
    '10 S/C Prerunner TRD Sport
    Purchased 11-7. Still some what patiently waiting for calibration ID to be added (3YWG3500). Hopefully soon!!
  12. Feb 15, 2018 at 6:44 PM
    #1672
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine is running fine with the UCON but for the sake of simplicity it would be cool to just run the stock ECU only.
    Would need it to run 640cc injectors, disable some of the DTCs relating to catalytic converters and losing the secondary air injection would be a nice bonus.
    Curious how much dyno time would be needed to make it run correctly.
    Roostfactor likes this.
  13. Feb 15, 2018 at 6:52 PM
    #1673
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    He can tune for bigger injectors, I’m not sure if 640 is the trd injector size I was just assuming
  14. Feb 15, 2018 at 7:06 PM
    #1674
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think trd is 525cc? Can’t remember.
    With the TRD injectors my data logs at WOT were like 85% duty cycle for the main 6 and 40% for the 7th.
    I think the 640cc would be enough.
    Murphinator[QUOTED] likes this.
  15. Feb 15, 2018 at 7:15 PM
    #1675
    ThomasMore66
    Dallas/Fort Worth & Durango
    I’m really thinking this is the answer. What is the deal with all the different ecu’s? I’m still confused by this.
  16. Feb 15, 2018 at 7:22 PM
    #1676
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    455 I believe is closer.
  17. Feb 15, 2018 at 7:22 PM
    #1677
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Every year toyota does updates and the calibration id changes. Sometimes multiple time per year. Trd tune are also considered another calibration.
  18. Feb 15, 2018 at 8:04 PM
    #1678
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    The TRD/Magnuson sc injectors are 455cc.
    loginfailed likes this.
  19. Feb 16, 2018 at 7:42 AM
    #1679
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    When are more ECU versions going to be added? Even though we've been told its a matter of time, I haven't seen the green light to update the handheld for the other versions. Is this still waiting on the 3rd party Italian company to commit the changes in the repository? Or has another hiccup occurred?
    I'm still waiting on YWG2900 before I can do a thing.
  20. Feb 16, 2018 at 7:44 AM
    #1680
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    no hiccups, waiting on the next update
    ecus going in are
    89663- YWG35
    89663-YWG38
    89663-YWG41
    89663-YWG44
    YWG2600 is in already,
    YWG2900 is in the next batch
