Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 16, 2018 at 7:54 AM
    #1681
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @OVTune , have you determined what the largest size injector is, that the OEM ecu can support?
    loginfailed and WOODEX M.E. like this.
  2. Feb 16, 2018 at 7:57 AM
    #1682
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    which batch will 30473000 be in?
    @D-Rose
  3. Feb 16, 2018 at 10:32 AM
    #1683
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Same question I have.
  4. Feb 16, 2018 at 10:37 AM
    #1684
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Any dyno numbers yet???
  5. Feb 16, 2018 at 12:42 PM
    #1685
    Taco Reaper96
    Taco Reaper96 Well-Known Member
    2008 Black Tacoma TRD Offroad
    Fog Light Mod, Kenwood Head
    Kind of a side question but do you guys think the 4.0 will gain as much or more hp/tq as the 3rd gens with this tuning? Probably too early to tell. I'm sure @OVTune is putting the majority of his time with this project into ecu support. Curious though.
  6. Feb 16, 2018 at 12:54 PM
    #1686
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That TRD radiator cap probably helps too !
  7. Feb 16, 2018 at 1:52 PM
    #1687
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Seriously...the TRD radiator cap adds 40 horsepower
  8. Feb 16, 2018 at 1:55 PM
    #1688
    Taco Reaper96
    50 hp with it on backwards!
  9. Feb 16, 2018 at 1:57 PM
    #1689
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I really don't understand why anyone would waste 5k on a supercharger for 50hp when some TRD bedside stickers, TRD shift knob, TRD floor mats, TRD intake, TRD exhaust, TRD radiator cap and a few well placed TRD badges is easily like 100hp
  10. Feb 16, 2018 at 3:11 PM
    #1690
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    You have to remember that the power is coming from the big TRD logos molded onto the supercharger
  11. Feb 16, 2018 at 3:13 PM
    #1691
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    A 4.0 supercharger with a TRD logo no longer exists though...
  12. Feb 16, 2018 at 3:34 PM
    #1692
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Hey man, Thats why dealers were sellin them for 15k when there was only a few left
    tblizzard likes this.
  13. Feb 16, 2018 at 3:40 PM
    #1693
    ThomasMore66
    Dallas/Fort Worth & Durango
    Only the non-boosted unwashed masses would mock the TRD supercharger. Away infedels!
  14. Feb 16, 2018 at 5:02 PM
    #1694
    Old School
    Old School You are ignoring covfefe by this member.
    Does anyone remember/know if the tune allows speedometer adjustment for oversized tires?
    Also, can shift maps be adjusted?
    When I'm pushing the truck a little hard, frequently doesn't want to upshift 4-5.
  15. Feb 16, 2018 at 5:10 PM
    #1695
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    No on the speedo, that’s not controlled by the ECU.
    Old School[QUOTED] likes this.
  16. Feb 17, 2018 at 12:53 AM
    #1696
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    My speedo was off a good amount so I looked around for something to fix it. There are a few options to get it corrected. I grabbed the Hypertech tool. I hesitated due to the cost for a bit but wanted my speedo corrected. Uses a simple program plug in origonal gear ratio and tire size and new gear and tire size. It mounts to the speedometer inline. ECU still reads regular but speedometer etc reads correct. I mounted it left the USB attatched and zip tied under the dash. Any gear or tire changes just plug in and program updated setting.
    would be dope if you could do it all in one tool.
    https://www.carid.com/hypertech/in-...-module-mpn-730117.html?singleid=4602643&url=
  17. Feb 18, 2018 at 3:06 PM
    #1697
    noncontributingzero
    noncontributingzero Member
    2015 Tacoma TRD Off Road
    Ditch the automatic and get a manual.
  18. Feb 18, 2018 at 5:35 PM
    #1698
    ThomasMore66
    Wow! One comment today. I figured this weekend a bunch of you would get your Tune on and report back. Or bitch about something...
  19. Feb 18, 2018 at 7:02 PM
    #1699
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    :cheers:
  20. Feb 18, 2018 at 7:57 PM
    #1700
    mattvan
    mattvan Member
    Im getting mine next week. If my ecu is already on there I will try to do a detailed report for everyone. 2014 trd offroad with bolt ons running 91.
    Roostfactor and TegoTaco like this.
