Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 19, 2018 at 8:10 AM
    #1701
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    okay guys ECU versions:
    YWG3500
    YWG3800
    YWG4100
    YWG4400
    will be in the update tonight or tomorrow (whichever for europe time zone)
    still working on 04730
    tacooh likes this.
  2. Feb 19, 2018 at 8:15 AM
    #1702
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Can you post Dyno numbers?
    DanoDavis likes this.
  3. Feb 19, 2018 at 8:23 AM
    #1703
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    OVTune - Any guesstimate of when the handheld tuner with pre-set tunes might be available particularly for the non-supercharged trucks? Are you waiting for results from others or your own evaluations? Several months????
  4. Feb 19, 2018 at 8:28 AM
    #1704
    SeniorSpan
    SeniorSpan Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Guys,
    I have a stock 2011 TRD DCSB V6 auto and have followed this thread from the beginning. I've held off ordering til most of the "dust" settles and am wondering if there a way to determine the ECU version installed prior to attaching the hand held tune equipment?
  5. Feb 19, 2018 at 8:29 AM
    #1705
    OVTune
    OVTune
    I'll be back at the dyno tomorrow and find them, I couldn't find them last time but I don't control the dyno software / how they are saved
    i'm not sure what you mean with pre-set tunes
  6. Feb 19, 2018 at 8:41 AM
    #1706
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Got an estimate for 30433300? :D
  7. Feb 19, 2018 at 8:56 AM
    #1707
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Do you have an obd2 reader, scangauge, or Ultragauge? If so you should be able to find the calibration I'd on one of the screens/menus.
  8. Feb 19, 2018 at 10:41 AM
    #1708
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
    I just receiver a BlueDriver OBDII reader; I'll have to get off my butt and check it out. Thanks very much for the reply.
    Really looking forward to getting sub light speeds out of the 4.0.
    Cheers
    Roostfactor likes this.
  9. Feb 19, 2018 at 10:46 AM
    #1709
    TacoSupremeo
    TacoSupremeo Well-Known Member
    Michael
    2005 Tacoma Double Cab 4x4
    @OVTune So where is the facility for OV located in the US? Everything i see on the website is overseas...
  10. Feb 19, 2018 at 12:03 PM
    #1710
    Roostfactor
    TX panhandle
    Socal.
  11. Feb 19, 2018 at 12:18 PM
    #1711
    tblizzard
    tblizzard Well-Known Member
    San Marcos in San Diego County, CA
    TacoSupremeo likes this.
  12. Feb 19, 2018 at 12:19 PM
    #1712
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    USA
  13. Feb 19, 2018 at 1:11 PM
    #1713
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    Earth.
    DanoDavis, dYL0n and Torspd like this.
  14. Feb 19, 2018 at 1:12 PM
    #1714
    omgwtfbbq!
    Ohio
    2013 X-Runner
    Sol system, galactic sector ZZ9 plural Z Alpha. Milky way.
  15. Feb 19, 2018 at 1:16 PM
    #1715
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Probably not on Mars
    DanoDavis, PapaBear and Torspd like this.
  16. Feb 19, 2018 at 2:18 PM
    #1716
    tblizzard
    Check your email @OVTune
    Thanks!
    EdinCincinnati likes this.
  17. Feb 19, 2018 at 2:34 PM
    #1717
    Pigpen
    Dan
    Northwest Montana
    I read some sort of bypass was going in there?
    blu92in99 and omgwtfbbq![QUOTED] like this.
  18. Feb 19, 2018 at 4:12 PM
    #1718
    ThomasMore66
    Dallas/Fort Worth & Durango
  19. Feb 19, 2018 at 4:46 PM
    #1719
    TacoSupremeo
    Michael
    Well, thats some funny stuff. Considering everything i saw said Hong Kong.
    https://www.ovtuned.com/pages/frontpage
    But good, now i know. I am in LA this week for work. I guess i will look them up when i get a trip a little further south.
  20. Feb 19, 2018 at 4:52 PM
    #1720
    Brice
    Brice Turbo Member
    Brice
    Texas
    Mine shipped from socal fwiw
    TacoSupremeo[QUOTED] likes this.
