Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Feb 21, 2018 at 7:07 AM
    #1741
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yes 3047300, 3043300, 30A6300
    3045200 is in but not reading so I will check status on that.
    I don't know yet on 3047300, I may end up needing a ecu with this on it
    bobsuruncle and rheath08 like this.
  2. Feb 21, 2018 at 7:34 AM
    #1742
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Going to attempt to pull my ECU again tonight. ECU 30439100.
  3. Feb 21, 2018 at 8:55 AM
    #1743
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Emailed to you last night.
  4. Feb 21, 2018 at 10:05 AM
    #1744
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yes, one would definitely want an ECA or flex fuel sensor running properly for e85. Well, if this truck is your daily... You would need much larger injectors than the TRD 455s. Second, You would need to be tuned on those larger injectors with pump gas first for a base map. Then tune for e85. The question is what max size injector can @OVTune tune for with the stock ecu?
  5. Feb 21, 2018 at 10:12 AM
    #1745
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Makes me wonder what reason OVTune has not yet stated the max capable size of injector that the OEM ECU can run? Maybe he has not performed the calculation to know yet? The answer has been asked many a time.
    Brice and Tn Jeff like this.
  6. Feb 21, 2018 at 10:25 AM
    #1746
    bdbrown
    bdbrown Well-Known Member
    Benjamin
    Canada
    '06 SWB DCSB MT
    lucky rocketship underpants
    255, unless I'm misreading, this stuff is way outta my wheelhouse
  7. Feb 21, 2018 at 10:43 AM
    #1747
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    Yes, I already have an E85 rated pump, so a sensor and bigger injectors.
    As for the talk on max size, there isn't one. There is a max size you can enter in the ECU, but that shouldn't even matter. The ECU doesn't need to know how big the injector is, just how long to turn it on when it needs to. Assuming the impedance is the same the truck will never know the difference, it's all a matter of reducing the fuel values to compensate for the increased fuel flow.
  8. Feb 21, 2018 at 10:47 AM
    #1748
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The size is needed. Just need to know where the 455 s/c injector falls on that 0-255 scale.
    Also, being able to plot the injector dead times is a necessity.
    DanoDavis and TRON like this.
  9. Feb 21, 2018 at 10:56 AM
    #1749
    OVTune
    OVTune
    I do not yet know the limit, because there are 3 ways to add or remove fuel, so the "window" of available possible fuel is huge.
    There is the injector sizing (base) + Fueling multiplier ( baseline 1.0, can be as low as 0.1 or as high as 2.0) then enrichment factor 0-255 ( 0% to 255%)
    So the amount of possible fuel that can be added is huge. You can take a very large injector then edit the multiplication tables to set low, and increase as needed, then enrichment factor for more, or less.
    tuning for E85 and large injectors should not be a problem. I'd say 700, 800cc injectors no problem. above 1000cc there can be issues with min PW and idle
  10. Feb 21, 2018 at 11:27 AM
    #1750
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thank you.
    DanoDavis likes this.
  11. Feb 21, 2018 at 12:07 PM
    #1751
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Will the software/hardware be available for users to tune their own vehicles? I'd very much like to be able to have the ability to read/edit/write my own ROM file.
    I sure miss the OpenECU of my Evo VIII/IX days..
  12. Feb 21, 2018 at 12:08 PM
    #1752
    OVTune
    OVTune
    yes. I am working on a new full editor. Once that is done it will be the current tuner pro / ecuedit is not good for long term.
  13. Feb 21, 2018 at 5:09 PM
    #1753
    Taco Reaper96
    Taco Reaper96 Well-Known Member
    2008 Black Tacoma TRD Offroad
    Fog Light Mod, Kenwood Head
    You F/I guy's make me jealous. Doesn't seem too crazy of a feat to make almost double hp but that 5-6k for the set up even before possible installation labor is a hard pill to swallow. Is it possible to make 300rwhp w/o forced induction that won't drastically reduce engine life?
    JuanitoBonito likes this.
  14. Feb 21, 2018 at 5:13 PM
    #1754
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    N/A to the Max, and your engine will be right under that.
  15. Feb 21, 2018 at 5:15 PM
    #1755
    omgwtfbbq!
    Ohio
    2013 X-Runner
    It's cheaper if you dont pay someone to install it, but yeah, you gotta pay to play. A 300hp NA build would probably be near 5 grand anyway.
    Taco Reaper96 and DanoDavis like this.
  16. Feb 21, 2018 at 5:23 PM
    #1756
    Taco Reaper96
    I imagine CAI, fuel pump, bigger injectors, free-er flowing exhaust, cam gearings?, 93 octane, and most importantly a good tune and wizardry could make that.
    nudavinci64 likes this.
  17. Feb 21, 2018 at 5:27 PM
    #1757
    Taco Reaper96
    :eek::eek:
    Yeah once you round that 4-5 grand number in goodies you might as well saved for a F/I set up.......or maybe..... LSX swap it is! :eek::rofl::burnrubber:
  18. Feb 21, 2018 at 5:29 PM
    #1758
    DanoDavis
    DanoDavis Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    I did most of that, and I can tell you that the truck was fcukin’ quick for an N/A truck, but nowhere near 300WHP.
    You’re talking and easy $4000 worth of work to hit that- internals upgrades-, most likely over $5000, and the power will only be peak, not a nice flat torque curve, and linear HP climb.
    Go F/I if you’re wanting 300WHP. EASILY doable with URD’s supercharger setup. Shit, probably be scratching 400WHP or more.
    Taco Reaper96[QUOTED] likes this.
  19. Feb 21, 2018 at 5:47 PM
    #1759
    Taco Reaper96
    Probably going to save for f/I soon then. Makes me wish that the tundra 5.7's were easily swappable. I'd bet a lot of people on here would of been all over that. S10 v8 swaps are still the king of cheap speed and fun. Still love my 4.0 though!
  20. Feb 21, 2018 at 10:24 PM
    #1760
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Looking to purchase a handheld. Does anyone know if 304A4000 calibration file is working?
    Truck is a 2015 X-runner but ECU Calibration comes back as a 2015 Prerunner
