Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Jun 27, 2017 at 11:55 AM
    #161
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    @OVTune
    Hey guys, you have a nice web site. I dig the background images, however it makes your FAQ page really difficult to read.
  2. Jun 27, 2017 at 12:13 PM
    #162
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    You bought LT and didnt tell me...... wtf man!
    12TRDTacoma likes this.
  3. Jun 27, 2017 at 12:35 PM
    #163
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I don't know what you're talking about and shut your mouth it's a secret.
  4. Jun 27, 2017 at 1:06 PM
    #164
    nd4spdbh
    SoCal
    Thats it... calling your mom now to tell on you, then ill call you later n we can hash this out..... i feel betrayed.
  5. Jun 30, 2017 at 3:00 PM
    #165
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Any chance with what you can now manipulate in the ECU...could incorporate a way to change the ECU to accept a 5th Tire Pressure Sensor?
    Using TechStream I can only input 4 sensor codes but the 5th (spare tire) slot is visible but you can't register a 5th code to monitor the pressure in the spare.
    Torspd likes this.
  6. Jun 30, 2017 at 3:49 PM
    #166
    black240ct
    black240ct Member
    Jay
    2012 tacoma trd sport
    Interested in this for sure. what can we expect on a "stock" engine set up. any throttle control or MPG increases
  7. Jul 2, 2017 at 9:56 AM
    #167
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Here Mat. 89661-04C61. This is my 2007 Tacoma manual trans 4x4 1GR. This particular ecu has been reflashed with the TRD tune for their supercharger. I can get you the calibration number next week if that helps. It's not the plastic version you mentioned. It's aluminum on one side and tin on the other. I was able to sneak my phone in there and grab a picture of the backside without having to remove the ecu at all. Took 5 minutes.
    I'm very interested in a way to tune this ecu. Solving the super annoying rev hang thing it does as well. Would like access to ignition and timing maps at all manifold pressures. I mention that because I've read that with the TRD tune, as soon as you get into positive manifold pressures, the ecu basically goes open loop and is just operating off a super rich, super safe 2D map.
    I would LOVE an autotune type option using an output from a wideband afr setup. My particular wideband also employs a failsafe feature that will ground a wire if the afr (Or boost) steps out of my preset parameters. Would be unbelievably awesome if I could use that output to trigger a soft ignition kill type condition in the ecu. Perhaps a sort of hot trigger for the stock rev-limiter?
    I'm sure guys with more hardcore mods would like the ability to adjust for larger injectors and such. The X-Runner crowd would certainly be all over these abilities as well.
    IMO, this tune for the 03-15 1grfe. Tacomas, 4runners, fjcruiser would be huge. Literally millions of vehicles out there. Over a ten year window of dang near identical powertrains. And a rabid interest in customizing by a large portion of owners.
    Sign me up.
    XPOTRPR and Aw9d like this.
  8. Jul 6, 2017 at 8:40 AM
    #168
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup: I see you're in Az too. There are a few of us boosted guys here in Az waiting to see what comes of this and are gong to try and get together to tune/diagnose if it happens.
  9. Jul 6, 2017 at 8:46 AM
    #169
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Any updates on this?
  10. Jul 6, 2017 at 8:51 AM
    #170
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    They're just getting the 3rd gens dialed in so I'm sure they haven't been working on any other new products just yet.
    Incognito[QUOTED] likes this.
  11. Jul 6, 2017 at 9:07 AM
    #171
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Reading manifold "pressure" will be difficult, since there is no MAP sensor. Pressure could be extrapolated based off of the load from the MAF sensor. You are correct that after certain set points are met, it goes into open loop.
  12. Jul 6, 2017 at 12:54 PM
    #172
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    Question: I have a friend who has a Tundra and he drove it up into the Colorado Rockies for a couple weeks. While he was up there he noticed that he was getting better mileage. When he got back to Oregon he told his dealer this story and the Dealer told him that its all in the tuning. He said that they could tune his Tundra so that it would get better mileage such as when he was in the higher altitudes but it is actually illegal for them to do so... would we be able to duplicate tuning that the dealer was referring to so we can get better mileage?
  13. Jul 6, 2017 at 12:57 PM
    #173
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Add this to the "dealers are idiots" list.
  14. Jul 6, 2017 at 1:44 PM
    #174
    Dragons Taco
    Derek
    Cary/Raleigh NC
  15. Jul 6, 2017 at 2:01 PM
    #175
    nd4spdbh
    SoCal
    better mpg due to less air resistance mainly, also less pumping losses through the motor due to thinner air. Happens with every vehicle.
    dealer cant tune shit.
    bluezzy[QUOTED] likes this.
  16. Jul 6, 2017 at 2:40 PM
    #176
    dcash68
    dcash68 New Member
  17. Jul 6, 2017 at 9:38 PM
    #177
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I completely agree, that the "dealer cant tune shit." Also, while it "happens to every vehicle," the effect can be mitigated with forced induction.
    While air resistance is less at altitude, that's less of a factor (at "normal" driving speeds) than the fact that less air equates to less gas being pumped into the engine. Both point to better gas mileage and inversely worse performance.
    Torspd likes this.
  18. Jul 6, 2017 at 10:17 PM
    #178
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ooh burn @nd4spdbh missntiu buddy
  19. Jul 6, 2017 at 11:42 PM
    #179
    BillDaCat8
    Jake
    PHX
    I'm in.
    C'mon Mat. What say ye? We're the tip of the iceberg. I know you're busy on other stuff. But, we're out here. And there's a LOT of us. I believe most have given up on a way to tune the oe ecu. You're offering, even teasing, that you can do it.
    Pretty please. With sugar on top!
    Does that help?
    XPOTRPR[QUOTED] likes this.
  20. Jul 7, 2017 at 1:42 AM
    #180
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    I am definitely interested, just wondering if this programmer could trick out the rear O2 sensors for those running either high flo cats or no cats at all to prevent ODB errors and loss of performance.
    I am planning to replace my whole exhaust line in the near future, and would definitely go that way with added benefits. If not URD would still be a viable option with their rear O2 sensors simulator.
