Tacoma Electric Boost?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raco.the.taco, Oct 28, 2019.
  1. Oct 30, 2019 at 7:04 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Fixed it for you :thumbsup:
  2. Oct 30, 2019 at 7:47 PM
    raco.the.taco
    raco.the.taco [OP] Well-Known Member
    Chad
    Denver, CO
    Locked, Geared & 1/2 Long Traveled
    Pelfreybilt Front Bumper, All-Pro Rear Bumper & Sliders, 35's, Toytect Boss Coilovers, JBA UCA's, DTF SUA Kit w/ E30 Deavers, Wheelers superbumps, Front & Rear Locked, 4.56 Gears
    Yea I was seriously considering 4:88’s. I probably will go to them before I switch to 37’s. The 20% reduction in power at a mile high is brutal.
  3. Oct 30, 2019 at 7:49 PM
    raco.the.taco
    Chad
    Denver, CO
    I would love to but the raptor doesn’t fit on any of the trails in the Rockies. I want the raptor power and suspension in taco size.
  4. Oct 30, 2019 at 7:57 PM
    Bishop84
    Bishop84 Well-Known Member
    Build a Samurai, put it on a trailer. Tow it with a Raptor. Solved.
    I want a Sammy so bad.
  5. Oct 30, 2019 at 8:34 PM
    raco.the.taco
    Chad
    Denver, CO
    I’m kind of stuck in my build now as a daily driver long travel overland setup. If I was starting over, I would build a 1st gen double cab for wheeling and overlanding and then a daily driver that has horsepower :)
    I’ve checked out the sammies but with that wheel base, i’d spend half the time upside down.
  6. Oct 30, 2019 at 9:30 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Really nobody gonna ask about this?
  7. Oct 30, 2019 at 10:30 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    BassAckwards likes this.
  8. Oct 30, 2019 at 11:16 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Uh, it was discussed starting in post #3, did you read the same thread I did?
  9. Oct 31, 2019 at 10:42 AM
    andrew61987
    Yea but I'm not sure if you did, post #3 and beyond reference an electric blower that uses electrical power to force air into the engine. Post #1 seems to describe an electric motor attached directly to the crankshaft via belt, some type of direct electric assist that does not involve air induction. I believe successful operation of the latter would violate some laws of physics without a battery of Tesla proportions
  10. Oct 31, 2019 at 10:47 AM
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    wait for the Ranger Raptor to come out in the US.
    As a side note, not sure but a 48V mild hybrid conversion might not be too expensive and you get a little temporary HP bump from basically a larger alternator/starter motor.
  11. Oct 31, 2019 at 11:03 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Kind of a neat concept actually:
    https://www.enginelabs.com/news/sema-2016-e-charger-bolt-on-hybrid-system-draws-crowds/
    It's just a big motor pulling from a battery system and driving the crank. Good for a boost and Regen braking.
  12. Oct 31, 2019 at 11:20 AM
    tarbal255
    Dave
    19 Taco SR
    Kind of wonder if you could implement that sort of low tech... put a button on your steering wheel that activates the motor and a small power gauge to indicate how much battery you have left.
    Otherwise when you aren't using it, it just runs as an alternator.
    raco.the.taco[OP] likes this.
  13. Oct 31, 2019 at 11:22 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    put smaller, lighter tires on
  14. Feb 19, 2020 at 1:36 AM
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    NoLove likes this.
  15. Feb 19, 2020 at 8:55 AM
    #35
    DG92071
    DG92071 Well-Known Member
    https://youtu.be/7a_J2X88fSE
    Milor likes this.
