Tacoma Engine and transmission work
Discussion in '1st Gen. Tacomas (1995-2004)' started by hunterman5, Apr 1, 2016.
I am trying to put a motor and transmission from a 1996 Toyota Tacoma 2.7 automatic into a 2001
  1. all
    0 vote(s)
    0.0%
  2. all
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Apr 1, 2016 at 6:35 PM
    hunterman5
    hunterman5 [OP] New Member
    Freddie
    2001 Toyota Tacoma
    I am doing an engine and transmission swap. I want to take a 1996 Toyota Tacoma 2.7 with automatic transmission and put it into a 2001 Toyota Tacoma that had a 2.7 straight gear. I'm trying to find out if the 1996 set up including the wiring harness and computer will work.
    I am wanting to put a 2.7 liter engine, automatic transmission, wiring harness and computer out of a 1996 Toyota Tacoma into a 2001 that had a straight gear. Does anyone know if this will work?
  2. Apr 2, 2016 at 1:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Like any swap you will have to merge the engine harness to the cab harness unless your planning to swap the entire wiring harness from 96 into the 2001
    There are always going to be little problems on any swap that come up
    If your looking to hear this is going to be plug and play most likely not but like anything else it can be done
  3. Apr 2, 2016 at 5:40 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    You will likely have to swap everything. The '96 motor will have a distributor, while the 2001 will be a coil over plug setup. So expect to have to swap all of the wiring and some other bits as well to make it work.
    On the transmissions, your speed sensor will be electronic on the 2001, while the '96 will be cable driven. I'm not sure how that will work. I've put the transmission from a 2001 into a '96 before and made it work by using the speed sensor off the '96, but I don't know if it will work the other way around because the '96 ECU and wiring will not be set up for an electronic speed sensor. You might have to run a speedo cable.
