Tacoma Factory LED Bed Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tanabersx, Dec 4, 2016.
  1. Dec 4, 2016 at 6:37 PM
    tanabersx
    tanabersx [OP] Well-Known Member
    Miguel
    Puerto Rico
    2016 Tacoma TRD Sport, 3/1 Lift Kit, Bilstein 5100's
    So, I ordered the factory led bed lights for the Tacoma/Tundra, part number 00016-34089. Got them off ebay for $65. The kit comes with everything you need. Connnectors, wiring harness, wire taps, etc. You do have to drill holes in the bed liner. Three per light, one about 1/2" for the light harness, and two 7/64" for the holding screws. Tapped them to the factory bed light circuit so they light up together. I used the attached instructions. The instructions are pretty straight forward. The only PITA is routing the harness all the way to the driver kick panel. I cut the excess harness and re-terminated the ends, the instructions tell you to leave all excess underneath the truck and zip tie it. The lights output is really good, it is cool white(the pic looks yellowish). I can finally see sheit in my bed at night plus my bakflip fibermax is on its way. I will post more pics tomorrow with daylight. Enjoy!
    IMG_7867.jpg IMG_7871.jpg image.jpg IMG_7824.jpg IMG_7826.jpg IMG_7827.jpg IMG_7829.jpg
  2. Dec 4, 2016 at 8:09 PM
    Buckeye88
    Buckeye88 Active Member
    Nate
    Columbus, OH
    2017 Inferno TRDOR DCLB
    Looks great man. I'm often digging for tools in the dark and this will be super useful. Thanks for the info!
  3. Dec 4, 2016 at 11:49 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    are you in an access cab?
  4. Dec 5, 2016 at 1:41 AM
    tanabersx
    Miguel
    Puerto Rico
    Nope, double cab. But the access cab is included in the instructions.
  5. Dec 5, 2016 at 4:31 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    That looks fantastic. Love that it's OEM too.
    ChadsPride likes this.
  6. Dec 5, 2016 at 5:06 AM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    That light output is nice.
  7. Dec 5, 2016 at 5:20 AM
    GoRideToday
    GoRideToday Member
    2016 White DCSB 6-Speed
    Let's go explore
    Looks great! As far as tapping into the right wires on the 3rd gen, was there any confusion because the truck looks like a 2nd gen on the instructions?
  8. Dec 5, 2016 at 5:28 AM
    tanabersx
    Miguel
    Puerto Rico
    Your are right! I edited the original post, the link was for the 2nd gen, I attached the .pdf for the 3rd gens.
    thanks!
  9. Dec 5, 2016 at 8:21 AM
    GamerGuy
    GamerGuy Well-Known Member
    Casey
    Alabama
    2025 4WD TRD Sport - Terra
    Do you still have the original link for 2nd gens handy?
  10. Dec 5, 2016 at 9:02 AM
    tanabersx
    Miguel
    Puerto Rico
    JangoprimeTaco likes this.
  11. Dec 5, 2016 at 9:08 AM
    MojaveMadman
    MojaveMadman Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Silly question, I may have missed it... But how do you turn them on or off? Where is the switch located and is it always hot?
  12. Dec 5, 2016 at 9:12 AM
    GamerGuy
    Casey
    Alabama
  13. Dec 5, 2016 at 9:47 AM
    tanabersx
    Miguel
    Puerto Rico
    If you have a double cab you tap into the bed light circuit on the drivers side kick panel and you use the bed light switch to turn them on or off, if you have a access cab you tap into the dome light circuit in the same place. It is a switched circuit not always hot. There are many ways you can connect this lights.
  14. Dec 5, 2016 at 9:51 AM
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Didn't know I had a bed light switch!? Thanks for the info!
  15. Dec 5, 2016 at 10:40 AM
    Taco Jax
    Taco Jax Active Member
    Barry
    Jacksonville, FL
    Silver 14 SR5 4x4
    Slight lift for function. Mods galore.
    Guys, will these bed lights work on a 2014 model DC? The way it's worded, I'm not sure my truck is pre-wired with the OE harness connectors for a bed light:notsure:
  16. Dec 5, 2016 at 11:09 AM
    tanabersx
    Miguel
    Puerto Rico
    No truck is pre-wired with the harness, you have to run the harness from the kick panel to the lights
    Taco Jax[QUOTED] likes this.
  17. Dec 5, 2016 at 12:18 PM
    Taco Jax
    Barry
    Jacksonville, FL
    Silver 14 SR5 4x4
    I didn't understand it then. I appreciate it, pal. It should work for a 2012-2015 if this is the case. I wonder why it only says 2015-16 models. Oh well
  18. Dec 5, 2016 at 12:32 PM
    tanabersx
    Miguel
    Puerto Rico
    The kit includes a wiring harness( that you have to route and install) that goes from the bed lights to the driver side kick panel were you tap that harness into an existing harness in your truck.
    It is the same kit for all years what changes is the connection point. This is the link for 2012-2015.
    https://cdn.shopify.com/s/files/1/0...8_TA_TOYOTA_MCDONOUGH.pdf?6492033332345436988
    Hope this helps
  19. Dec 5, 2016 at 12:56 PM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    just bought one for my 2017 I would guess the wiring is identical....?
  20. Dec 5, 2016 at 1:07 PM
    tanabersx
    Miguel
    Puerto Rico
    Yes it is
    dusman[QUOTED] likes this.
