Tacoma falls when take off from dead stop as well as break issue plz advise
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999tacotrd, Apr 22, 2009.
  1. Apr 22, 2009 at 7:52 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Tacoma just falls when i got to take from a dead stop it like cuts out then takes off what could cause this? If its a rolling take off it doesn't do it only from a dead stop. Also my breaks are staying on even after releasing the pedal and causing a load on the motor and loss of power as well as burning up the pads! would the power booster be causing this? I'm about to go buy a booster from the parts yard but i want to make sure that's it first before doing this.
  2. Apr 22, 2009 at 7:56 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The brakes sticking would cause the loss of power at a dead stop. Your booster is what gives you "power" brakes. I think it is you master cylinder that is bad.
  3. Apr 22, 2009 at 8:00 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    before you go buy anything, take apart your calipers and make sure there not sticking..Lubricate all the moving parts, and see if it still does it.
  4. Apr 22, 2009 at 8:41 PM
    1999tacotrd
    OK will do that tomorrow im thinking i will get the whole truck off the ground and put it in N and push the brakes then turn the wheels by hands and see which ones is locking up then i will know.
    But the brakes sticking that would cause it to cut out at take off?
  5. Apr 23, 2009 at 8:47 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Fix one issue at a time. The brakes should be an easy problem to diagnose and fix. If fixing the brakes first doesn't fix the cut-out, then we will tackle that next.
  6. Apr 23, 2009 at 3:38 PM
    1999tacotrd
    Ok i checked them out today it seems only the fronts stick the backs dont so what could cause this? i even went to advance auto and they said it was a bad caplier so i bought one for the passanger side and it still has the same issue :( i wasted 58 bucks on that thing :mad: so it has to be eather the booster or master clynder and ideas?
    UPDATE went to autozone and they said it was something like a Break Compstive Value or something like that and it was a little box thing located under the master cyl do u guys know what im talking about?
