Tacoma feels like it's braking when downshifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Young Ginger2007, Sep 13, 2021.
  1. Sep 13, 2021 at 6:23 PM
    Young Ginger2007
    Young Ginger2007 [OP] Member
    Hey yall. I noticed today that when Im driving and I let off the gas, when my mph hits about 30, it feels like the truck has a sudden drag. Kind of like when you downshift a fourwheeler and your speed is to high. And when the mph hits about 10mph, the engine will rev itself up and the truck gets a little boost. Why is this happening?
  2. Sep 13, 2021 at 6:42 PM
    hogfan1978
    hogfan1978 Well-Known Member
    Nacogdoches, TX
    08 TRD Sport 4x4 DC LB
    Are you going down an incline when this is happening?
  3. Sep 13, 2021 at 6:44 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Knowing a bit more about the truck will help. Year, engine 4X4, etc. Under certain conditions the truck will downshift to slow you down. At least my 2007 does. Newer versions may work a little differently.
    Nalpak99 likes this.
  4. Sep 13, 2021 at 6:47 PM
    dTed
    dTed Well-Known Member
    2013 DCLB SR5 4x4 MGM
    This happens with my Tacoma as well. It seems like a shift point is right at 30mph, where you often drive in town. I have always found it to be normal.
    If I’m doing a lot of driving in town, I will shift to S4 so that it’s not always trying to shift into overdrive.
  5. Sep 13, 2021 at 6:49 PM
    cookiedough
    cookiedough Well-Known Member
    Phx, Arizona
    02 DCSB OR, 19 DCSB OR
    '02 - No mods. '19 Blue Friday - GFC, RXT S1, Bilsteins
    Even my 1st gen does when coasting downhill - engine/transmission braking perhaps? Although, the 2002 vs the 2013, on flat pavement, the 2002 will out-coast the 2013, is this part of the fuel management? ie. the 2013 essentially cutting off fuel, making the engine coast vs the 2002 releasing the torque converter but the engine still consumes fuel to keep itself running?
    (yes, I still have both trucks, I just couldn't sell the 2002, sentimental cuss that I am)
  6. Sep 13, 2021 at 6:49 PM
    Young Ginger2007
    Its a 2007 tacoma prerunner 2wd. It does it all the time. It just feels like it slowd down all of a sudden when it goes down to 30, and around 10 it revs up a little bit and it gets a little boost.
  7. Sep 14, 2021 at 5:37 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    My 2008 Sport does that, and did it really hard when I first got it. Shortly after I bought it in 2008 there was a TSB that came out for this issue. Toyota service reprogrammed the transmission shift points to lessen the effect of the downshift at no cost. Maybe yours was never done?
  8. Sep 14, 2021 at 8:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its normal. The truck goes into fuel cut which increases engine braking feel, and right around the 30mph mark there is a downshift point which will further increase engine braking feel. Ill bet if you coast in this mode down to about 20mph (without touching gas or brakes) you will feel like someone bumped you from behind when the motor starts to get fed fuel again.
    Young Ginger2007[OP] likes this.
  9. Sep 14, 2021 at 9:56 AM
    Young Ginger2007
    Yea. But also around 10 mph it revs up about 200 rpms. All by itself. Why is this?
  10. Sep 14, 2021 at 9:58 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Probably jumps into first gear. Ive noticed substantially better coasting with the 3* camshaft gears.
  11. Sep 14, 2021 at 10:49 AM
    nd4spdbh
    SoCal
    Yup stock downshift into 1st occurs right around 10mph as well
  12. Sep 14, 2021 at 12:39 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My base model will downshift by itself when I haven't used the throttle in a while but I've hit the brakes a couple times. I believe this is a safety feature but I also believe this is not what the OP is describing. So maybe this "braking feel" is caused by DFCO? It's a pretty distinct feeling when the injectors cut out.
  13. Sep 14, 2021 at 4:56 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    A little different scenario, but I recently took a trip up to the White Mountains in Maine and noticed a similar phenomenon on my 2014 AT. Lots of climbing up the passes with the the usual steep downhills after on curvy, steep Forest Service roads. Nothing too outrageous though. I learned (here) that it's just the AI transmission doing its job sensing lots of steering input (curves) frequent brake applications (to control speed: steep grade), and it senses this input and begins to downshift to supply brakeing assistance. It's a great feature once you realize what's going on. (and normal). Genius. When I got through those the areas with those conditions and returned to the flats, it gradually adjusted and "forgot everything" and went back to normal. (no downshift everytime I hit the brakes) I would assume on up-hill climbs, especially towing, it will figure that out too and adjust accordingly. It would be interesting someday to experience the "anti-sway control" software that's built into the Toyota stability control and included with the towing package. But honestly, I can live without that. I "found religion" one day when a semi went by me at high speed and the sway "wagging the tail" started. Weight distributing-hitch with the old analog friction sway control and manual override with the trailer brake control on the dash. Got thru it, but definitely picked up gray hair in the process. (Vehicle: 1986 Chevy 1500 with Camper Special pkg.) No slouch that truck.
  14. Sep 15, 2021 at 8:57 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I never thought twice about this but since I read this thread, just this morning on my way to work I noticed at the 30mph mark in some traffic my truck 'braked' on its own. Seems normal.
