Tacoma Finally Woke UP (Throttle Cut Out Solved)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kustom54lighting, Jun 25, 2017.
  1. Jun 25, 2017 at 1:30 AM
    kustom54lighting
    kustom54lighting [OP] Well-Known Member Vendor
    So I kept having issues with my truck just falling on its face and throttle going out completely and having to restart it to make it run again. Codes I had were for TPS, MAF and Accelerator pedal but at random times. Anyway first I had a code for TPS, replaced it and still had it come on randomly which was ODD, then out of no where I had the Accelerator pedal code come on which was odd because it never came on before. My final conclusion is this Throttle By Wire system got some serious issues, in the end it turned out to be my pedal when I ordered a new one it came with a slightly different and updated part number and now so far my truck has had no cut outs, no RPM hang ups and is actually hauling ass.
    Mods
    TRD supercharger
    Volant Intake
    Exhaust
    I am posting this because I know I seen a lot of people with similar issues and no one could figure it out. If I have issues again it will be due to the ECU or the wiring but for now I'm happy to have a truck that hauls ass.
    JSU, smw62891, TegoTaco and 6 others like this.
  2. Jun 25, 2017 at 4:21 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    This is the first time I've heard of accelerator pedal problems in a tacoma. I had an L-series Saturn before my truck, and the throttle-by-wire was crap. I had to replace the pedal twice in the 3.5 years I had it.
    ChadsPride likes this.
  3. Jun 25, 2017 at 5:52 AM
    grunt66
    grunt66 Well-Known Member
    Vista, CA
    08 Tacoma DBL cab 4X4 off road
    I have been dealing with an intermittent loss of power (engine still running) for approx 1-2 seconds. The best way I can describe it, imagine your foot slipping off the gas pedal. This does not happen all the time and when accelerating easy to moderate. Most recent occurrence I was merging from a highway off-ramp to a 55 mph road and I went to accelerate and the truck stopped accelerating. I can go days without it happening. My Tacoma is a 2008 with 62k miles with the 6 cylinder.
    Where you experiencing the same issues as I am?
  4. Jun 25, 2017 at 6:14 AM
    kustom54lighting
    Yep same exact stuff, almost got me in an accident. Have you ever popped a code? My would do it a lot
  5. Jun 25, 2017 at 6:33 AM
    grunt66
    Vista, CA
    I also forgot to include I am also having an intermittent ABS light illuminating on the dash. I restart the vehicle and the ABS lights does not illuminate on the dash. I need to find a scanner to look for codes. I am thinking the ABS light maybe connected with the loss of power. I have started driving the Tacoma more since I have a work vehicle. On the last occurrence after the throttle loss the ABS light came on. Previous times the throttle loss appeared the ABS light did not illuminate. The more I keep researching I think I may try replacing the brake light switch. I have read another forum member replaced his brake light switch and that fixed his problem with acceleration issues similar to mine.
  6. Jun 25, 2017 at 8:28 AM
    Nazzy
    Nazzy Member
    2000 Toyota Tacoma
    I have a 2000 Tacoma was my dad's he bought it when it had 3 miles on it. He passed away 5 years ago and I have his truck now. I have had it do the same thing lack of power when my foot is on the pedal. It would almost die going around a corner. I changed the spark plugs and it fixed it but it still will lose power like sluggish like your foot slips off the pedal. No codes? And my fule filter is in my tank? It's a base model is what I'm told but if I look my vin up it says tdr off road? It has the 2.7 litter in it? And suggestions? I love my truck.
  7. Jun 25, 2017 at 8:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Thanks for the heads up!
  8. Jul 9, 2017 at 9:42 PM
    kustom54lighting
    So code came back for the throttle seams it only happens when it's cold out. Time to trouble shoot the ECM
    tcjacado likes this.
  9. Jul 9, 2017 at 10:00 PM
    binderline
    binderline Well-Known Member
    2019 TRD OR MT Cement
    Had a Nissan Hardbody in the 90's. Had what sounds like the same issue. After months of it I finally had enough and took it to the dealer. They shafted me, claiming it was the fuel injectors (which I forked out the whopping $800 they charged me to have them replaced). Same issue continued for another few months and then I finally figured out the true source... it was a faulty fuel pump relay the whole time.
  10. Jul 9, 2017 at 10:39 PM
    kustom54lighting
    Really? What's aggravating is it won't throw a true code. First it threw one for TPS so I replaced it when replaced that it started to throw one for pedal, maybe it is a fuel issue I do have a TRD supercharger with stock fuel system. The odd thing is only does it when it's cold outside
  11. Jul 10, 2017 at 7:43 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    What year is that thing, and what code is setting?
  12. Jul 10, 2017 at 8:21 AM
    kustom54lighting
    2009 supercharged. Just got a p2121, so random but I'm going to try something and see. Just filled up and going to see if maybe it's fuel issue sense last night I was low on fuel when it did it.
    Have no clue everything is pointing to ECU and just trying to avoid that
  13. Jul 10, 2017 at 8:23 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Mine does this randomly
    And when it does, my left brake light doesnt work
    So strange, so irritating.
  14. Jul 10, 2017 at 8:31 AM
    Jeffs68
    Stock
    Since you replaced the throttle body and accelerator pedal already, double check the wiring and connectors.
    Also, did you use an OEM throttle body or aftermarket/rebuilt?
  15. Jul 10, 2017 at 8:42 AM
    kustom54lighting
    Throttle body OEM refurbished, pedal brand new from Toyota
  16. Jul 10, 2017 at 8:55 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Have you checked the brake light switch to make sure it's working properly? I have had them get worn before and if the ecu thinks you're trying to brake and accelerate at the same time it'll cause all sorts of weird issues.
  17. Jul 10, 2017 at 8:59 AM
    kustom54lighting
    I have not, I will test it. I'm just cracking up at this point because the issue is so odd lol
  18. Jul 10, 2017 at 9:00 AM
    ChadsPride
    Dang it man, I have not.
    It works fine when the ABS light is not on (which is basically always)
    But for whatever reason that light comes on in the dash, the brake light wont work.
  19. Jul 11, 2017 at 5:10 PM
    BeardedMonkey09
    BeardedMonkey09 Member
    2009 Tacoma TRD
    I don't have a supercharger but my 2009 had a similar issue with no throttle response, sputtering, and / or complete stall. Thought it was bad gas, cleaned the MAF, and engine treatments. Dealership thought I was crazy, finally they experience it for themselves. Ended up being the ecu.
  20. Jul 11, 2017 at 5:27 PM
    kustom54lighting
    Yeah I think it's the ecu now. It was fine for two weeks after I changed the pedal and now it's back and doing it everyday. Really annoying.
    You couldn't just reflash? Or was it actually just a bad ecm?
