Tacoma for high elevation rockies?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cantstoplt021, Sep 24, 2019.
  1. Sep 24, 2019 at 6:29 PM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    I’m going to say it because we’re all thinking it. These trucks have a shit power train for high elevation mountainous highways. :crapstorm:
    Get something with a turbo at that elevation. Another vote for a Subaru here.
  2. Sep 24, 2019 at 6:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Get some type of a Subaru with a turbo. Absolute best vehicle for your conditions.
    Junkhead likes this.
  3. Sep 24, 2019 at 6:37 PM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Yup my sentiments exactly about the CCT. The MT Subi is where it’s at :rasta:
  4. Sep 24, 2019 at 7:56 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I wouldn't recommend a SC just because it can't compensate for elevation change. You'll be overboosting if you go to sea level.
  5. Sep 24, 2019 at 7:59 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    No you won’t, not with a properly designed aftermarket or any factory built supercharged vehicle.
    Boghog1 and Jasonstacoma like this.
  6. Sep 24, 2019 at 8:01 PM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    It runs the same boost, just like a turbo does, they go to a certain preset lbs of boost, unless using a boost controller, which stock cars don't have.
  7. Sep 24, 2019 at 8:14 PM
    Syncros
    Syncros Well-Known Member
    Volkswagen Golf Alltrack.
  8. Sep 24, 2019 at 8:19 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    A turbocharged Subaru...
  9. Sep 24, 2019 at 8:28 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Apparently some people replying in this thread have never driven NA above 10K feet. It sucks. Who was talking about a dtereo for fucks sake? Elevation, snow, shit weather. Well I guess he can listen to some tunes while he's stuck.
    Junkhead, Navigator1 and Boghog1 like this.
  10. Sep 24, 2019 at 8:29 PM
    Reh5108
    Idaho
    Your boost is rpm dependent. That same speed is going to build more pressure at sea level than it will at 10k. I've never heard of anything regulating pressure on a SC, only rpm. Hence why you don't hit peak boost until redline.
  11. Sep 24, 2019 at 9:26 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I’ve been up and through Breckinridge for a week in last nov. At the time I had a 18 off road. It handled fine. However a 4Runner or Jeep jlu might be what would fit you better.
  12. Sep 24, 2019 at 9:50 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    The Tacoma (part time 4x4) is a no go as a daily driver for you... Sabaru Outback (AWD) will best fit your articulated needs.
    Junkhead and El Chivo Norteño like this.
  13. Sep 25, 2019 at 8:47 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I live at 7000' in Colorado, the Tacoma is the highest HP vehicle I have ever owned. No worries about holding Smode and 5500rpms up any mtn pass. Easy peasy, done.
  14. Sep 25, 2019 at 8:59 AM
    SUZETACO
    SUZETACO Member
    I live at 9600’.Get a turbo car unless you enjoy going really slow. My Tacoma sucks at elevation.
    Navigator1 likes this.
  15. Sep 25, 2019 at 9:00 AM
    #35
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I just went on a trip with a couple of 1st gens and a couple of 2nd gens. I was fully loaded down with camping gear and supplies, as were the other vehicles. My 3rd gen had plenty of power to deal with high mountain passes, and I always got 2 mpg or more better than the 2nd gens. So, I don't necessarily agree that the 3rd gen Tacoma has a crap powertrain for high altitude. I did similar road in a 2nd gen, and there's really not much difference. The 1st gens have a smaller tank, so they needed to fill up quite a bit more.
    Anyway, the 4Runner JBL system in my wife's 4Runner sounds really good. From reports on here, not sure the Tacoma JBL is quite as good. Without a cap, sleeping in a Tacoma might be a bit iffy. I'm thinking a 4Runner would be a good choice for your needs.
    Junkhead and eurowner like this.
  16. Sep 25, 2019 at 9:05 AM
    #36
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    4x4 4runner
  17. Sep 25, 2019 at 9:06 AM
    #37
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  18. Sep 25, 2019 at 9:30 AM
    #38
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I've had my Taco in the Rockies a few times. It's just fine for the elevation... hell, I got better gas mileage driving around the enchanted circle than I did here in Louisiana. I've had the Taco in Icy weather and it did fine.
    I think it will meet your needs, but it's a matter of what you need. I need a truck bed that I can throw dirty stuff in (I have a camper shell). A 4runner just wouldn't work for me.
    I have a Subaru as well. It's a great car, but given the choice, I'd take the Taco. It's just more capable.
  19. Sep 25, 2019 at 10:49 AM
    #39
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Quite hilarious that Subaru spews all this BS about being environmentally friendly and caring so much about the world yet they sell shit tons of models that burn oil. Wait sorry, "consume" oil as they call it. My friend has a 16 Impreza and needs to put 1 qt of oil in her ride every month. Shes complained but just gets the "consumption" talk at the dealer. Still nothing else wrong reliability-wise but pretty shiesty of Subaru and their sappy ass commercials.
    Jasonstacoma likes this.
  20. Sep 25, 2019 at 11:03 AM
    #40
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    All cars burn oil to some capacity, I think their focus is on emissions. So while their engines burn more oil than the average car they consistent have lower emissions that vehicles that don't. IDK though.
