Tacoma Frame Remedies
Discussion in '1st Gen. Tacomas (1995-2004)' started by NickyRaz93, Apr 13, 2025.
  1. May 16, 2025 at 7:26 PM
    #41
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I mean there are some spots where I'm sure it comes off faster than others but it seemed to stay on there the couple years I've done it.
    Black97v6MT[QUOTED] likes this.
  2. May 17, 2025 at 8:24 AM
    #42
    NickyRaz93
    NickyRaz93 [OP] Member
    Nick
    Philadelphia
    2004 Toyota Tacoma 2WD 2.4L 4cyl
    Is the POR15 what my mechanic used here’s that’s making the frame look black? Should I try to wire brush or remove that some other way before applying the fluid film?
  3. May 17, 2025 at 8:26 AM
    #43
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It’s very hard to remove once applied and cured. It’ll take a grinder with a flap disk to remove it.
  4. May 17, 2025 at 8:46 AM
    #44
    NickyRaz93
    Nick
    Philadelphia
    so you think I should just apply over the POR15?
  5. May 17, 2025 at 8:49 AM
    #45
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I don’t think you have much of a choice at this point. Apply over it. Concentrate on the internal boxed section to get that coated well. Also soak the joints where the frame laminations are.
  6. May 17, 2025 at 12:51 PM
    #46
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    Yep, I'm not sure what you should do with it. Pics? I ended up stripping all the Por 15 off my truck. Then applied waxoyl. Looks like the Por was applied on new metal in that case it might be fine. Apply over top. PoR falls apart when applied over rust. Make sure to do the inside of frame.
  7. May 17, 2025 at 4:25 PM
    #47
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    POR-15 is junk
    Just stay away from it
  8. May 17, 2025 at 7:16 PM
    #48
    ztwatson
    Milwaukee, WI
    It’s probably just black spray paint. Just apply fluid film from over it.
