Tacoma Frame Rot
Discussion in '1st Gen. Tacomas (1995-2004)' started by RustyYota, Dec 4, 2009.
  1. Dec 4, 2009 at 9:38 PM
    RustyYota
    RustyYota [OP] Active Member
    Dave
    Rust Belt, NY
    TRD Auto
    Toolbox in the summer tenau in the winter, 3in toytec lift, 33'' BFG muds, Tint
    I'm new to this forum thing and excuse my ignorance to the system if i am once again posting in the wrong place... Living here in the rust belt I have a 2000 tacoma with pretty bad frame rot. It is primarily on the inside of the frame from about 6 inches in front of the cross member for the drive shaft to about halfway down the gas tank. It is nearly rotten the whole whole height of the frame. My hammer pops right through it wherever i have room to swing! I plan on driving the old girl thru the winter. I want to make sure that I get a buy-back and not a repaired frame, as I have a leaky main seal and a cold engine rod knock. I will post pictures of the frame tomorrow.
    Thanks, Dave
  2. Dec 4, 2009 at 9:53 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Pretty sure you'll be part of the buybacks. Have it checked with your local dealer to be sure.
  3. Dec 5, 2009 at 5:13 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Your in the same boat as me. It would be a buy back on the 2000, NOT a frame replacement. My frame sounds just as bad as yours, but I'm going to wait until Spring to take mine in.
  4. Dec 5, 2009 at 5:17 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    The sooner you go in, the higher the 1.5 bluebook value.
    Also, if the frame is in that bad of shape, a thinking man would probably take it in sooner rather than later so as to be actually still be around (alive, not maimed, etc) to collect the buyback cash.
  5. Dec 5, 2009 at 5:47 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I had a 2000 4WD Reg Cab, and they bought it back in October. I had had it inspected about 18 months ago and it passed, but failed this time when I took it in, as a "just in case" precaution before I put new shocks, brakes and tires on.
    I bought it used in 2004 with about 80K on it for $10,500. When the bought it back, it had 171K on it, many usage dings, and rubber on their last revolutions.
    They paid me $10,740 for it. So...they paid me $240 to drive it for 5 years! They added a couple of bucks for the after market trailer hitch I had added, calling it a "tow package".....So I would recommend that anyone who has the frame rot, to get it inspected as soon as possible...it is to your advantage.
    Another friend of mine had a 00 Access Cab, 4WD, V6, auto....and he got over $15K for his....pocketed about $3K, and bought a 2000 Tundra....now that may be bought back for the same reason!
    Bottom line: Don't wait! Get it inspected as soon as possible!
  6. Dec 5, 2009 at 6:24 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    I haven't owned my truck for 6 months yet.
  7. Dec 5, 2009 at 7:28 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    i have had mine for 2 weeks. :D But my frame is NICE!!! :D Maybe by the cut off point it may be shitty. By then I may be done clearing the property off and not need a beater truck. :D
  8. Dec 5, 2009 at 8:00 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I inspected mine when I had owned this Tacoma for only 10 months. I'm on 14 months now.
    The Tech at the dealer said he would pass it this year, but it will not pass after another winter in the Shelburne/South Burlington salt.
    Bottom line, I thing you just need to get it inspected at least a year after the previous owner did. So see if you can find out when the previous owner got it inspected, if he/she did at all. If they didn't, than go get her recalled.
  9. Dec 5, 2009 at 1:43 PM
    RustyYota
    Dave
    Rust Belt, NY
    TRD Auto
    Heres the deal guys, I bought the truck about a year and a half ago. To my knowledge it hasnt ever had the frame inspection done. The holes are pretty clear in the image and I can actually enlarge the hole just pushing with my fingers. I called my local dealer and they said to just bring it in. I am just paranoid that I will bring it in and the mechanic there wants to try out his new MIG and i end up with a repair and not a 2003 TRD...If i bring it in I dont think i will be able to say "no, dont fix it i want to keep driving it until i am eligable for the money". Also does anyone know if that money is towards a new toyota product or just a check to me. I will be shocked if these pictures actually work, im not so internet savvy
    Thanks a lot
  10. Dec 5, 2009 at 3:34 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Get that shit checked out and wait for the check from Toyota, your truck will definitely not pass the rust inspection.
