Tacoma Fuel Economy
Discussion in 'Technical Chat' started by 007Tacoma, Feb 1, 2007.
What Engine + Mileage Does Your Tacoma Have (Average)?
  1. 4cyl <16 MPG
    17 vote(s)
    0.5%
  2. 4cyl 16-20 MPG
    186 vote(s)
    5.1%
  3. 4cyl 20-25 MPG
    369 vote(s)
    10.1%
  4. 4cyl >25 MPG
    80 vote(s)
    2.2%
  5. V6 <16 MPG
    414 vote(s)
    11.3%
  6. V6 16-20 MPG
    2,121 vote(s)
    58.1%
  7. V6 20-25 MPG
    448 vote(s)
    12.3%
  8. V6 >25 MPG
    18 vote(s)
    0.5%
  1. Aug 16, 2009 at 11:19 PM
    #261
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    I'm lucky to get 15 MPG... maybe like 275 miles out of a tank...I have the stage 2, 6" pro comp lift with 33x12.5 tires. I take it real easy and it still gulps gas. At least its not $80 fill ups like last summer
  2. Aug 18, 2009 at 11:50 AM
    #262
    007Tacoma
    007Tacoma [OP] I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I use RoadTrip for the iPhone for the past 5 tanks. I have averaged about 17.3 MPG over the past 1,300 miles. Mostly towing a 400lb trailer with furniture on it and moving a cab and bed full of stuff in town.
    Right now I have a CEL for my Mass Air Flow sensor. I am sure that is royally screwing with my fuel economy as well as my fuel mapping. I can't find my multimeter right now, but once I do I will get it tested. That's a $200 part that I don't want to replace.
  3. Aug 18, 2009 at 11:57 AM
    #263
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I got my best mileage to date with this morning's fill up. 21.6 mpg.:)
  4. Aug 19, 2009 at 9:01 AM
    #264
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    I had weird result today. Filled up and calc'd mileage at 17.7. I have been averaging 19.4. Engine sounds and feels fine. I did an oil change mid-tank and did the oil change reset. Don't think I was driving unusually aggressive this tank. Probably just an anomaly.
    Ideas?
  5. Aug 19, 2009 at 9:05 AM
    #265
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    It happens. That's why to get true average fuel economy, you must check it regularly. Maybe, you got some weak gas or something. Just keep an eye on it.
  6. Aug 19, 2009 at 9:32 AM
    #266
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Averaged over 10 tanks of 93 octane, my stock 2009 DC Sport w/ tow package and 4.0L auto has received 18.11 mpg.
    I have a heavy foot too!
    I track it on a spreadsheet but can't attach it to a post. Any ideas and I'll share my results. I may start using Fuelly.com.
  7. Aug 19, 2009 at 9:46 AM
    #267
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    I just started using fuelly.com. It's pretty cool how it tracks your fuel economy.
  8. Aug 19, 2009 at 9:57 AM
    #268
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    3.4L engine in your 2009 truck? Interesting :rolleyes:
  9. Aug 19, 2009 at 10:59 AM
    #269
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    I felt it would be much better than the 3.0L V5. The extra .6L just wasn't worth the additional cost for me.
    3.4 FTW :D
  10. Aug 19, 2009 at 11:28 AM
    #270
    JasonY
    JasonY Active Member
    Austin, Texas
    09 Access Cab, Prerunner, SR5, Alloys,
    I'm wondering if maybe it has something to do with how different gas pumps behave. When do you consider your tank to be "full"? When the pump shuts off the first time? The second? Or do you fill the tank all the way until gas is coming out of the top?
    If the tank shuts off early then GasCubby (or Fuelly, etc) would think that you hadn't burned as much gas as you had. Similarly, if the pump isn't as sensitive and ends up putting an extra gallon in before it cuts off, then that would affect your mileage calculations on the negative side.
    I always wait for the first click on the gas pump and then round up to the nearest dollar or so. I figure averaged over time that'll give me a pretty good result. The best way is to refill the tank to the exact same level each time, but barring some kind of way to know a consistent "full" level, all of our calculations will be, at best, an estimate.
    How do you all do it?
  11. Aug 19, 2009 at 11:37 AM
    #271
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    If you are checking gas mileage, you should go to the same station every time and try to use the same pump. Let the pump shut off on it's own and don't add anymore fuel. That way you are filling the tank to the same level everytime.
  12. Aug 19, 2009 at 11:42 AM
    #272
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    This will definately have an effect on your calculated fuel economy. If you were to just take one tank at random as a data point you would likely not end up with an accurate number. However, when using a fuel tracking site, you end up averaging tank after tank, and that variation comes out in the averages.
  13. Aug 19, 2009 at 11:47 AM
    #273
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    I use the same pump at the same gas station and stop at the first click.
    I was out of town last weekend and tried to refill past the first click and gas began POURING down the side of my truck. Yeah...I made a mess :rolleyes:
    Always stop at the first click. Deviations in gas pumps will correct themselves on the next fill up. I assume that is what caused the drastic change in MPG for Flatlander.
    Here are my last 9 tanks:
    17.37
    16.62
    17.67
    16.11
    18.86
    17.58
    20.55
    18.51
    19.76
    (ranges from 16.11 - 20.55)
  14. Aug 20, 2009 at 5:12 PM
    #274
    King Powers
    King Powers Seasoned
    SW Florida
    05 PreRunner V6 SR5 Double Cab
    I'm on my 3rd week of 60(one-way) mile commute and I'm getting high 19's.
    I'm averaging 80 MPH too, so I'm pretty happy with that.:D
  15. Aug 21, 2009 at 8:03 AM
    #275
    Pyro-Rob
    Pyro-Rob Active Member
    North of Denver, CO
    09 DC TRD Sport Mag Gray Metallic
    Ideal Turn-Key Clamp (to secure tailgate), On Anytime Fogs, DTRL, Hood Scoop Running Lights, more in the works
    Wow, that sounds like how I drive, but I don't get 19 mpg. My last batch of fills are:
    17.2
    18.1
    16.4
    17.4
    16.8
    15.4
    17.4
    17.1
    17.6
    18.3
    17.6
    16.9
    My driving style doesn't differ much from tank to tank although those 17's following the 15 were from when I was on vacation driving through the flatlands of eastern WY and southern SD. I see you're in FL so that might have something to do with it, there's a lot of air down at that altitude, not much at over 5,000 feet.
    I wonder what winter time will do to my mileage :)
    --->Rob
  16. Aug 21, 2009 at 8:12 AM
    #276
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    ^ your average is 17.11.
    For a manual-shift, that seems low.
  17. Aug 21, 2009 at 10:36 AM
    #277
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    I average between 20 - 21 mpg. v6 auto. have been using premium gas since around 3k on the vehicle, almost 9 k on it now, synthetic put in at 5k, run the tires around 36 to 39 psi. still stock everything, looks like lifts and bigger tires suck it up.
    a recent road trip to PA from NC resulted in the best mpg so far, 24 on the way up and 23.5 on the way back. 300 pounds in the bed plus a passenger. nice
    I have put 70 pound nerf bars on and a 40 pound bed mat in the back, plus I just put my 180 pound tool box back on the truck so the mpg will go down a little with the box on there.
    considering getting the artic bull bar from avid off road also, 60 or 70 pounds, so mpg will go down more from that...
    edit.. I also try and keep it below 2k rpm during stop and go driving and when taking off from a complete start. 0 to 60 in 1 minute, lol
  18. Aug 21, 2009 at 1:25 PM
    #278
    Pyro-Rob
    North of Denver, CO
    Yep, that's what I have thought. I chalked it up to the higher speeds.
    --->Rob
  19. Aug 21, 2009 at 9:20 PM
    #279
    CalFred
    CalFred Member
    Lancaster, Ca
    Tacoma 2.4L
    My 2003 2.4 XCab 2wd gets an average of 22.4 mpg with a range of about 20 to 28 mpg. Usually about 25-27 on the freeway.
  20. Aug 22, 2009 at 5:58 AM
    #280
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Tacos don't get towed....Datsuns get towed. :D
