Tacoma Fuel Economy
Discussion in 'Technical Chat' started by 007Tacoma, Feb 1, 2007.
What Engine + Mileage Does Your Tacoma Have (Average)?
  1. 4cyl <16 MPG
    18 vote(s)
    0.5%
  2. 4cyl 16-20 MPG
    186 vote(s)
    5.1%
  3. 4cyl 20-25 MPG
    369 vote(s)
    10.1%
  4. 4cyl >25 MPG
    80 vote(s)
    2.2%
  5. V6 <16 MPG
    415 vote(s)
    11.4%
  6. V6 16-20 MPG
    2,121 vote(s)
    58.0%
  7. V6 20-25 MPG
    448 vote(s)
    12.3%
  8. V6 >25 MPG
    18 vote(s)
    0.5%
  1. Mar 30, 2011 at 1:42 PM
    #501
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    after almost 10,000 miles im still getting over 19 mpg.
  2. Apr 3, 2011 at 8:10 AM
    #502
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    I put some heavier tires on the truck and gas mileage went way down, 2 mpg. The tires are about the same size that came stock on the truck, there is just so much more tread. Because of the extra weight I noticed a decrease in response as well when I need to really get down the road. Good tires though...
  3. Apr 3, 2011 at 9:06 AM
    #503
    52419
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    why am i only getting 15mpg i mean is my lift and tires killing me that bad?
  4. Apr 3, 2011 at 12:30 PM
    #504
    Old Soul
    NC
    ^ Yup, for every pound increase in tire/wheel weight, it's like putting a few pounds in the bed of the truck and driving around with it in there
  5. Apr 4, 2011 at 6:22 AM
    #505
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Oh yeah! my96 dropped about 4mpgs when I went from alloy to steelies and c to E load tires in one switch, which was like a 30 pound increase per corner. I think you're doing good to be getting 15 with 35s.
  6. Apr 30, 2011 at 4:49 AM
    #506
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Edit: response to an old post, but I didn't see it anywhere.
    It will adjust.
    If you don't want to sit through the whole boring lecture stop reading now - and of course if I screw something up, I trust someone to point it out. What I believe:
    The ECU adjusts to what the sensors tell the ECU, not to any particular driver or even style of driving. There are typically two types of learning involved - Long Term and Short Term.
    Long Term is a data value that changes gradually in response to sensor values based on conditions: fuel oxygen content (i.e., ethanol, cold air intake, etc.), engine wear, air leaks, fuel pressure, altitude, etc. This data is stored in a nonvolatile location in the ECU and is not erased even when the engine is shut down. This information is used during warm up and wide open throttle conditions - also known as Open Loop mode.
    Short Term values produce near instantaneous correction values determined from sensors such as the oxygen sensor. Under normal conditions it cycles rapidly around the 0 percent correction value and is only functional during closed loop operation (note: if you watch the operation you can predict oxygen sensor failure by the slow down in response time). This mode is used only during closed loop operation (when engine is up to temp & sensors all report good - NO check engine flags set).
    I have no idea how Toyota implements it, but when the short term values, plus or minus, exceed what the ECU expects by some margin, say 10%, it begins to influence the long term stored values, changing them to be closer to optimum. On some ECUs I've seen there is also a three cycles of Cold to Hot requirement before the change is moved into the nonvolatile memory - screwing with these numbers based on a single engine run is not typical.
    There are absolute limits to how much the ECU can adjust engine performance given the parameters of the specific engine. That is why, for example, you couldn't switch from gas to 100% ethanol (even if the mechanical parts could handle it).
  7. May 1, 2011 at 7:26 PM
    #507
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    hahaha nice one! Good joke for a first post :)
  8. May 2, 2011 at 12:30 PM
    #508
    Airun
    Aaron
    Show Me State
  9. May 2, 2011 at 10:41 PM
    #509
    lowzone
    lowzone Well-Known Member
    Ron
    Earth aka NJ
    2010 MGM AC 2.7L 5 spd SR5
    future plan of 2" drop and any type of rim thats not a steelie. grille and BHLM mods, maybe....
    got back from a trip from NJ to NC and back. my wife (130lb), kid (68lb) 8 yr old, and myself (230lb) with TWO Isuzu 4x4 manual transmissions (175lb each++), and camping gear (tent, air mattress, sleeping bags and cooler with food + clothing). bed was loaded in every square inch, even the pockets in the bedsides were filled. 28.26 mpg going down and 31.09 coming back without the transmissions but with a ARB bumper for my 4x4 in their place......i get 22 around town now, sometimes 20-21 but rarely. i love my Tacoma
  10. May 4, 2011 at 11:20 AM
    #510
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Extra rotational mass in the tires is a lot different than extra weight in the bed.
    I got similar results as you on a recent road trip. 30.0 MPG's on the way down hauling outdoor furniture. 28.5 on the way back empty (but with more traffic and more speed :p). ~570 miles one way.
  11. May 10, 2011 at 9:10 AM
    #511
    ScottyDaug
    ScottyDaug Active Member
    2011 Regular Cab 2.7 4X2
    I got 28 MPG on my last tank. 2.7 - 4X2.
  12. May 16, 2011 at 5:00 PM
    #512
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
  13. May 16, 2011 at 5:17 PM
    #513
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    im getting about 18.75mpg with my 2.7 5speed. i put bigger and heavier tire (went from stock steels and HT tires to FJ wheels and ATs) im happy with it i guess. i dont know if the AT are really worth it for around town driving.
  14. May 17, 2011 at 7:08 PM
    #514
    moulin6801
    moulin6801 Well-Known Member
    Hey guys, just come back from a trip to Atlanta and I got 19.6 MPG
    2010 with my TRD Sport, AUTO, 4 doors, Long bed, 20K miles, 4x4. Truck was empty, only me, going 75mph as much as I could.
    Cheers
    David
  15. May 17, 2011 at 7:57 PM
    #515
    Airun
    Aaron
    Show Me State
    20.1, 20.2 and 21.4 last 3 tanks. woo hoo
    mostly 20 mile 55 mph hwy. trips
  16. May 17, 2011 at 10:20 PM
    #516
    lowzone
    Ron
    Earth aka NJ
    still get 21-23 around town. lowest i got was 19 and i was driving around town during Xmas (mall capital of the world Paramus NJ has more malls per square mile....UGH) on winter blend fuel....lots of traffic. 4x2 AC 5 spd 2.7L running full Mobil 1 synthetic 0w20. love the truck!!!!!!!! if i do mixed im getting 24-26 MIXED...straight highway 28- and UP. if i have ANYTHING in the OPEN bed the MPG suffers, but my tonneau cover got me 30+ as seen in my last post. One trip from NJ to NC with a table saw and sheet metal in the open bed, i got 25 mpg. coming back 30 empty no cover, about 300lbs total in bed going down. wind drag plays a major part in MPG on these trucks. Screw Mythbusters saying toneaus dont help....they DO. remember i got 31.09 coming back LOADED with my wife, kid, ARB style bumper and camping gear with the cover ON. i want to see what i get with no weight in the bed, cover on.
  17. May 31, 2011 at 3:57 PM
    #517
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    I got 16.33 MPG last time I put gas. I have 3 inch lift with 33'' duractracs and demello sliders. Magnaflow muffler and drop in AFE air filter. If I wanted great MPG I would've bought a 4Cyl.
  18. Jun 3, 2011 at 11:21 PM
    #518
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    :notsure:My scan gauge said I was getting 9999MPG today when I was coasting down hill off the highway
  19. Jun 13, 2011 at 12:58 AM
    #519
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    My 2011 Tacoma v6 gets worse gas mileage than my 2005 Tacoma v6 did. With the same 20" wheels. My 05 was averaging around 18-19mpg. My 2011 driving like I did the 05 gets 15-16 mpg. Driving it cautiously with some hyper miling thrown in, I'm gettin 17-17.5mpg. :confused:
    Also I think my 05 had more power than the 2011.
  20. Aug 1, 2011 at 7:01 PM
    #520
    RichTaco
    RichTaco Member
    Upstate New York
    '11 SR5 4x4 Magnetic Gray
    Pop & Lock, Extang Trifecta, lighted 4x4 switch, WeatherTech
    Had my V6 6 speed manual for about 3 months now, averaging 18+ in town and 21 on the road........
