Tacoma gas door replacement/fuel door repair due to rust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silver05, Feb 25, 2018.
  1. Sep 30, 2021 at 11:21 PM
    #61
    Sarra
    Sarra Well-Known Member
    2007 TRD Off Road 4.0 6MT
    None yet
    You could paint match your screw/bolt heads, or just paint them black.
  2. Oct 1, 2021 at 5:59 AM
    #62
    woods_24
    woods_24 Well-Known Member
    2009 Black TRD Sport DCLB
    Unfortunately I'm in this boat now, too. Has anybody successfully purchased the fuel door assembly and used their current painted skin by bending the tabs open, swapping panels?
    TACOMA2NDGEN and Maadanchik like this.
  3. Oct 1, 2021 at 1:48 PM
    #63
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
  4. Oct 1, 2021 at 2:04 PM
    #64
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    Mine rusted out last year. I've now got a primer black one. I didn't bother to paint it more than that. By the time this one rusts through, I expect to be over 300K on the truck and have moved on to something else.
  5. Oct 1, 2021 at 2:07 PM
    #65
    Waasheem
    Waasheem
    2007 xrunner
    This sparked curiosity. Wondering if anyone ever tried using a locking gas door parts from a car that came with it, and putting it on to work on their Tacoma. Then it might not be worth the effort since it has a finger notch which someone could stick a screwdriver in to force it open, now you have a damaged door and body body panel. A locking gas cap was my second purchase after getting mine, first being a good alarm.
    Slashaar likes this.
  6. Oct 14, 2021 at 12:19 PM
    #66
    virg144
    virg144 New Member
    Hi there, where did you find a locking gas cap? I’m told by my local auto parts stores that a locking gas cap is not available for a 2020 Tocoma with a V6 engine.
  7. Oct 14, 2021 at 1:51 PM
    #67
    Waasheem
    Waasheem
    2007 xrunner
  8. Oct 14, 2021 at 7:00 PM
    #68
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Absolutely. Bend the 4 tabs and the skin comes right off.
    TACOMA2NDGEN likes this.
  9. Nov 14, 2021 at 5:10 PM
    #69
    Steveb327
    Steveb327 2012 TRD Off-Road DC
    NH
    2012 TRD Off-Road
    Slashaar and others are right. Bite the bullet and do it right. Tacomas, at least 2nd Gens, are notorious for this problem. I just replaced mine on my '12 - thanks to the excellent guidance here - and had the same problem on my old '10. The issue, as I heard consistently from several body guys and dealers, with just prying the tabs and swapping the old door on a new hinge is that the metal tabs aren't rugged enough to handle being bent and re-bent. They'll snap off or, if not, won't hold the door on the new hinge securely.
    Go new, wet-sand, prime, wet-sand, paint or have it painted properly, and oil it. My door was $38 online. I'm sure you have a parts store that will mix a spray can of whatever you need for about $22. I used a local O'Reillys and asked for two-stage paint (separate cans of paint and clear) to allow for wet sanding (to at least 1000 grit) and blending into the quarter panel. You can get away with a single-stage paint if you only need to paint the door and touch up inside.
    BTW, learned the hard way that there were several variants of White (040) in 2012. Learned I had the blue variant. That added a day....
    Slashaar[QUOTED] likes this.
  10. Nov 16, 2021 at 3:41 PM
    #70
    Slashaar
    Josh
    Kansas City, MO
    My local dealer has the door assembly for $15 last I checked. EDIT: I was wrong, $31.
    Steveb327[QUOTED] likes this.
  11. Nov 18, 2021 at 6:57 AM
    #71
    Steveb327
    NH
    2012 TRD Off-Road
    That's more like it! I don't think I could get a cabin light bulb from my dealer for $15, let alone a well-made gas door with a hinge. :)
  12. Nov 18, 2021 at 2:51 PM
    #72
    Slashaar
    Josh
    Kansas City, MO
    I was probably thinking of the gas cap to be honest. Too many parts floating in my mind brain.
  13. Nov 19, 2021 at 6:32 AM
    #73
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    For information: I had a scraping sound when opening the fuel door on my '13. I thought it was dry hinges but 3 in one oil at the pivots did not resolve it. It turns out that the edge of the door on the hinge side was scraping the body when opened. A little bending adjustment with a flat screwdriver fixed the interference. Unresolved, this will lead to rust as there is bare metal now.
  14. Dec 22, 2021 at 12:09 PM
    #74
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    Woohoo, looks like I'm gonna get to join the club. Glad I'm not alone, but what a PIA.
  15. Aug 28, 2022 at 1:26 PM
    #75
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Just posted a brand new in box OEM fuel door for sale in the 2nd Gen Marketplace if anyone needs one. Part number is 77305-04904.
  16. Nov 3, 2022 at 10:18 AM
    #76
    Clanof4
    Clanof4 New Member
    Lee
    2015 Tacoma crew 4x4 longbed
    Easy fix on painting fuel door.
    I went with VINYL WRAP. It's a lot cheaper than paint and it's easy. My color is the metalic grey 1g3. the wrap is a great match. Bought the vinyl online from metrorestyling.com . You don't have to buy it by the roll. They sell in small sheets to accommodate your needs. I bought a 12''x12'' sheet for 4 bucks (ship 6.00). and have enough left to do the door handle wells that the cats have scratched up jumping up on the truck. I also bought a cheap vinyl squeegee kit (8.00) on Amazon and only out 15 bucks total on color. Total job under 75 bucks (with door). watch the vids on youtube on how to use vinyl wrap, very forgiving material, you can't go wrong if you are a DIY'er.
    Hope this helps.
    Later Lee
    JGO, Slashaar and 6 gearT444E like this.
  17. Feb 13, 2023 at 6:01 AM
    #77
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    tagging for future use :D
  18. Feb 13, 2023 at 10:43 AM
    #78
    Parabellum
    Parabellum Well-Known Member
    North Central PA
    2009 Dcab Man. 6spd v6 Tacoma TRD Offroad elocker
    keep some grease on the moving parts an should not be a issue again. thats what i've been doing with mine after is has been replaced not rust so far been over a year.
  19. Feb 13, 2023 at 11:45 AM
    #79
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    Every oil change I put a very small amount of Kroil on the hinges. My rust has gotten no worse and the door works smoothly. I have a paper towel to mop up any over dose.
  20. Mar 7, 2023 at 6:21 AM
    #80
    Mudsock
    Mudsock Well-Known Member
    Indiana
    2010 2.7 4x4
    Lol! I wish I would have known about this issue BEFORE my fuel door hinge rusted.
