Tacoma general snow handling.
Discussion in 'Off-Roading & Trails' started by John4x4, Jun 12, 2015.
  1. Jun 12, 2015 at 7:46 PM
    John4x4
    John4x4 [OP] Active Member
    Bucks County, Pennsylvania
    2015 DCSB 4x4 V6
    2.25 inch procomp leveling kit
    I was born and raised in central Florida I recently move to philly because better paying job, either way. I got talking to a friend about the snow and he was wondering weather ass-end ( bed ) would slip all over with most the weight being in the front, I know tire's are a factor but I was just wondering in general how does it handle in the snow I have a 2 gen 2015 Tacoma.
  2. Jun 12, 2015 at 7:49 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    do you have 4wd? either way, if you're nervous get some snow tires and add some sand bags to the bed and you'll be fine
  3. Jun 12, 2015 at 7:54 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    If you're 4x4 you can get around in some fairly deep snow. I had a 2011 2.7 4x4 with and the cheapest tires they put on Tacoma - Dunlop AT20's. No locker, or ATRAC and got around pretty well in 10"+ snow. As stated above, I did use sand bags. Truck handle snow really well though.
  4. Jun 12, 2015 at 7:57 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    I have a 2000 tacoma 4x4 with just a camper shell and it handle very well. Even in 2 wheel drive it did good. Just add some weight in the back and your golden.
  5. Jun 12, 2015 at 8:10 PM
    John4x4
    2015 DCSB 4x4 V6
    It is 4x4, and thanks for the advice you 3 on the sandbags and sadly I also have Dunlop at20's also lol.
  6. Jun 12, 2015 at 8:21 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My 04 is much better in the snow than my 2 nd gen Tundra. You will be fine.
    Just remember one rule. If you wonder if roads are bad enough for 4 wheel drive? Put it in 4 wheel drive. Also remember a little bit of snow is more dangerous than a lot of snow. People have to slow down for a lot of snow, they don't, on general, slow down for a little snow.
  7. Jun 12, 2015 at 8:22 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Fuck, man ... it's the middle of June and you're already talking about snow ?!
    :canada:
    KN and TALLNDIRTY like this.
  8. Jun 12, 2015 at 8:22 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Wow. Really early in the year for this conversation. One thing that hasn't been mentioned is the traction control system in the newer Tacomas. It's not like driving an older rwd vehicle where you need to be careful going up hills and around corners that you don't overdo the throttle or drop a gear accidentally and spin out, kicking you sideways. The traction control system makes it almost impossible to lose your back end (fish tailing) unless you disable the system. As soon as one tire loses traction and starts to spin, the vehicle limits the power to the spinning wheel so that it doesn't go faster than the other, non-spinning wheels.
    As with any rear wheel drive vehicle you just have to drive it as such. Added weight is great advice. Better tires if you can afford to upgrade them as well. A lot of people upgrade tires pretty quick and sell their take-off stock tires.
  9. Jun 13, 2015 at 5:39 AM
    Pigpen
    Dan
    Northwest Montana
    The Dunlops are okay in snow for the first year they are on the truck. After that, any traction lugs are gone and they suck - mostly when you apply the brakes. Get a second set of cheap wheels and good tires for winter. Also, if the roads are slick at all (or even wet in winter) do the quick push on your trac button. This will engage auto LSD before ABS when the rear slips a little. I engage it every time I start the truck in the winter because slick spots can show up without warning. With good tires you'll notice that the ABS and E-LSD don't engage anywhere near as often as it does with those shitty Donlops. They're just fine in warmer temps though.
    Rear weight helps too - a shell is good multi-function weight.
  10. Jun 13, 2015 at 5:49 AM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    If you live and drive in the city you'll probably rarely need four wheel drive. I think I used it once or twice last winter and that was only because I had it - not that it was truly needed.
    My biggest winter challenge has been getting up my driveway.... :)
  11. Jun 17, 2015 at 9:57 AM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    Extra weight in the bed will help but the DCs already have way better weight distribution than the xtra cabs.
  12. Jun 17, 2015 at 10:01 AM
    John4x4
    2015 DCSB 4x4 V6
    I didn't think about the double cab helping, makes sense though originally I just got it for extra space but that's a cool added benefit also! Thanks
  13. Jun 17, 2015 at 7:30 PM
    EatMyTacomaDust
    Good point.
  14. Jun 27, 2015 at 8:33 PM
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    In my experience tires make the biggest difference. I had Goodyear Silent Armour tires on my last full-sized truck and the thing was a tank in the snow (accelerating and stopping!).
    John4x4[OP] likes this.
