Tacoma, Goodbye Forever
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mdean1107, May 6, 2024.
  1. May 6, 2024 at 12:34 PM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
  2. May 6, 2024 at 12:36 PM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Bye Bye
    jackn7 likes this.
  3. May 6, 2024 at 12:42 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Looking through your post history, it seems one taco you bought at 70k then it was nearing 200k, I’m curious if this was the same truck you are speaking about which you also filled the engine to 11 quarts because you drained the transmission?
    Go buy a ford and be done with it these trucks are honestly junk!
    FlyingWolfe, jackn7 and Frog4aday like this.
  4. May 6, 2024 at 12:42 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I got bad news about the rest of your options then lol
    jackn7 and Gdeyarmond like this.
  5. May 6, 2024 at 12:44 PM
    TacoTuesday1
    SD CA
    happens a lot with German cars
    what cost you money?
    “I paid for $1000 oil changes”
    Did you avoid the known shit option and get the known good one?
    “No”
    unfortunately there is evidence of Toyota starting to go downhill in the modern era with US offerings but at least you get capability
    vs many other vehicles, you never get any capability
  6. May 6, 2024 at 12:46 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    since 88 i have had one and it rotted out after 10 years
    99 rotted frame after 11 years, toyota bought it back for 150% BBV
    my 2009 rotted out frame not covered after 13 years, replacing frame as the new ones are so much money and the 3.5 winds up too much for my liking
  7. May 6, 2024 at 2:13 PM
    Texas
    Texas Well-Known Member
    All Toyota had to do was treat the frames properly for long term durability but they didn't. It isn't an issue for me since I live in South Texas but gosh....one should be able to own a truck longer than 10-15 years if they want to without it breaking in half.
    Williston likes this.
  8. May 6, 2024 at 2:17 PM
    Gdeyarmond
    Gdeyarmond Well-Known Member
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    OP and Elon Musk are on the same plan when it comes to vehicle quality control R&D.....
  9. May 6, 2024 at 2:20 PM
    Tiger109
    Tiger109 Well-Known Member
    Louisiana
    2020 TRD OR
    My brother has a Dodge Dakota for sale cheap. If you want a high quality truck.
    Junkhead, Williston and Steves104x4 like this.
  10. May 6, 2024 at 2:29 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    High quality for sure. :drevil:
    Check the values of these two comparable model year trucks, both in access-cab size w/ largest available engine, with the same region/ZIP code selected. Things that make you go "hmmmmm."
    Frog4aday likes this.
  11. May 6, 2024 at 2:38 PM
    Tiger109
    Louisiana
    2020 TRD OR
  12. May 6, 2024 at 2:42 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Sorry you’re not happy!
    Bye bye :cheers:
  13. May 6, 2024 at 2:42 PM
    GilbertOz
    GilbertOz Driver
    CA
    Roger, Roger.
  14. May 6, 2024 at 2:52 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  15. May 6, 2024 at 3:37 PM
    #35
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    My last Dakota (98) had a 318 in it. It would pass anything but a gas station! It wouldn't get 13mpg if you dropped it out of a C-130! That truck ate it's trans @ 131k, A/C clutch went bad shortly after, taking the seal to the compressor with it. Otherwise, it was OK.
    My first Tacoma (06 DCLB V6) had 199k on it when I traded into my 3g. At that point, besides normal maintenance, I had to replace the axle seals, rebuild the driveshaft and replace the fuel pump. I thought it was a pretty fair truck and really didn't owe me a thing.
  16. May 6, 2024 at 3:41 PM
    #36
    OldSchlPunk
    Rich
    East Central Wisco
    Hey Mikey @Mdean1107, I wish you a lotta luck with your Ranger. I hear they're phenomenal trucks. Maybe a Colorado/Canyon...funny, I don't see any of them on the local trails...
    jackn7 likes this.
  17. May 6, 2024 at 3:46 PM
    #37
    GilbertOz
    GilbertOz Driver
    CA
    Out here, in my pretty-minimal forest trail explorations, so far I see about 80% Toyota, 20% Dodge/GMC. Tacos and 4runners mostly, the occasional land cruiser or FJ cruiser.
    And I've yet to see a Honda Ridgeline on any ridge lines. Maybe one day.
    CrazyCrewChief, ridefreak and jackn7 like this.
  18. May 6, 2024 at 3:56 PM
    #38
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  19. May 6, 2024 at 4:20 PM
    #39
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  20. May 6, 2024 at 4:23 PM
    #40
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    Sir, today is Monday. Not Friday.
