Tacoma grill lights turn on with Stalk in Auto? for LED Harness with grill lights
Discussion in 'FBC Harness Solutions' started by jpagan81, Feb 13, 2024.
  1. Feb 13, 2024 at 2:44 PM
    jpagan81
    jpagan81 [OP] New Member
    Question will the grill lights turn on 100% of the time when you have the stalk in Auto instead of on, since the signals are combined with the diode on the 3 position AMP connector from the Park and DRL, I would think not?
    If not any configuration to have the grill lights on 100% of the time with the provided harness, other than with the stalk in on?
  2. Feb 13, 2024 at 2:50 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Not Dave (obviously), but I can help. The grille light does combine DRL and Parking lights, so it does only turn on when one of those signals is present (auto, parking, or low beams). If you wanted them to come on whenever the truck is on, you will need to grab an ignition controlled circuit. The most common way of of doing that for grille lights is a fuse tap under the hood. Unfortunately nothing in the headlight is live when the stalk is set to off.
    Edit: just reread and not sure I did answer. The grille lights WILL be on anytime the stalk is in auto, parking lights, or low beams. The grille lights will NOT be on however when the stalk is set to “off”
  3. Feb 13, 2024 at 2:50 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    On whenever stalk is not in Off. that’s the easy way to remember it.
  4. Feb 13, 2024 at 2:51 PM
    daveeasa
    David
    PNW
    some of us like having a way to go dark / stealth. Good for driving situations where you want to attract the least attention possible.
  5. Feb 13, 2024 at 3:05 PM
    jpagan81
    Sorry for the dumb follow up question so the Auto position on the stalk is considered on then? Meaning grill lites will be on?
    I ussually keep my lights in this AUTO setting unless i just want to turn everything off. for the stealth mode!!!
  6. Feb 13, 2024 at 3:12 PM
    daveeasa
    David
    PNW
    Exactly right. Auto means either DRL (ambient light detected) or parking lights and low beams (dark outside). Then park is parking lights (and DRL). Low beams is parking lights and low beams, no DRL. And high beams is on top of that.
  7. Apr 23, 2024 at 7:35 AM
    jpagan81
    Morning need some help, bought the harness for the tacoma for the LED conversion with grill lights and the grill lights will not come on once connected to the harnees, tested then directly to battery and they turned on.
    Headlights work perfectly love it just the help with the grill lights!
    Did try all the position on the light swith and lowering the parking brake and all after connected
