Tacoma Grille Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kpage6702, Aug 16, 2020.
  1. Aug 16, 2020 at 1:29 PM
    Kpage6702
    Kpage6702 [OP] Member
    Kyle
    2016 Metallic Gray Tacoma TRD Off- Road Access Cab
    I wanted to do something somewhat cheap and easy to do to my Tacoma. I want to put in those LED grille lights but I wasn’t sure what the best ones are? Also how easy is a add a fuse to power it? I don’t want to drill a hole in my fuse box, so what would be the best installation process for the lights? Thanks!
  2. Aug 16, 2020 at 1:39 PM
    Shellshock
    Iowa
    I got mine from yotaleds. Comes with everything you need and the install takes about 5 minutes.
    you can get into the fuse box following the factory harness if you don’t want to drill a hole
  3. Aug 16, 2020 at 1:39 PM
    Tacospike
    Two Trucks
