Tacoma Hammer Hangers - SOA + SUA - Archive Garage
Discussion in 'Archive Garage' started by ARCHIVE, Nov 13, 2017.
  1. Jan 30, 2019 at 9:46 AM
    #821
    90yota
    90yota Instagram: 90_yota
    Great Falls,MT
    16 DC OR 88 T4R
    Stock....ish
    I'll have to check my allpros but I've never had those issues with mine. Guess I'll have to get under mine and check. Been running allpros for a year and half now with HH for a about a year. Only issue I had was running stock length shackle with stock bushing, the shackle wouldn't rotate as much and allow for droop. Once I replaced with Archive bushing it rotated.
    ARCHIVE [OP] and mr.trd like this.
  2. Jan 30, 2019 at 9:56 AM
    #822
    VE7OSR
    VE7OSR 'interfering with Natural Selection since 1990'
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    What about using AllPro Expo leafs with these hangers? any feedback on the pairing of your hangers with those? (SOA configuration.) Use stock or Hammer shackles? What would be the difference between the stock and aftermarket shackles?
  3. Jan 30, 2019 at 9:59 AM
    #823
    90yota
    Great Falls,MT
    16 DC OR 88 T4R
    Stock....ish
    That's what I'm running with stock length. Stock vs aftermarket shackle differemce is length and bushings. But Archive sells the bushing to replace the stock ones. I like my setup. I didn't see a need to buy aftermarket shackle unless you dont have the tools to replace the bushing.
    ARCHIVE [OP] likes this.
  4. Jan 30, 2019 at 10:16 AM
    #824
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Ok, so stock bushing needs to come out of the stock shackle. I'm running extended length shocks (2" non resi Walker Evans that AllPro used to sell with these springs) in stock mounting points for the extra 3" lift from the Expos, and have parts on the way to rebuild those shocks. I was thinking doing the hangers next, then maybe upgrade the shock mounting to allow for new 12" travel shocks to take advantage of the increased droop travel.
    90yota likes this.
  5. Jan 30, 2019 at 10:21 AM
    #825
    90yota
    Great Falls,MT
    16 DC OR 88 T4R
    Stock....ish
    For stock mounting the best shock would be the bilstien b110s. They are a pretty long shock. Not sure the specs on your Walker Evan's but I would consider those if you dont want to do the work involved with running a 12 or longer travel shock.
  6. Jan 30, 2019 at 10:39 AM
    #826
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, OME Dakar w/ AAL, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, original bronze 16x8 Konig Countersteer off-road wrapped in 285/75R16 GoodYear MT/R's and 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI Ditch Light brackets w/ Rigid D2's, FYRLYT's on the front, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust behind URD equal length headers.
    Update after driving it for a couple of days. WOW. Huge increase in how smooth the truck is. Although I might have lost just a hair of height in the rear end. But that could maybe be because I went with the shackles also and not just reused my factory one. But it is super smooth now. The rear end in not getting jarred going over bumps like it was before. The rear used to hop pretty good when I hit a speed bump at 30 (the speed limit) and now it just takes the hit and soaks it up like the front end has done for years. But also pretty sure my rear Dakar's with the extra add a leaf are totally shot. They are flat with just my rear bumper with swing away and camper shell. Overall, I love the Hammer Hangers and they are built very well!
    Murphinator, 90yota and ARCHIVE [OP] like this.
  7. Jan 30, 2019 at 10:45 AM
    #827
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 DCSB 6spd, '05 Seq, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Deaver SUA
    Thanks Brant!
    90yota likes this.
  8. Jan 30, 2019 at 10:46 AM
    #828
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Yes, already have the Walker Evans shocks (10" travel) with the Expo leafs, and been running that setup for the last 5 years. Shocks need a rebuild now, and parts for that are enroute; expect to be able to do that work myself. Because of monies, looking at doing the Hangers first, then possibly new mounts for 12" shocks in the future while I continue to work with these shocks. I was very happy with the ride change when the spring & shock upgrade was done. Washboard forestry roads at speed take their toll though. Collecting the parts. budget to upgrade gearing from 3.91 to 4.30 and put in limited slip torsen carrier up front, and rear as well.
    TD90S and 90yota like this.
  9. Jan 30, 2019 at 11:25 AM
    #829
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    I was thinking limit straps for my 5160's but the B110's are 30$ cheaper.
  10. Jan 30, 2019 at 3:39 PM
    #830
    Supra4x4
    Supra4x4 No longer 2WD O_O
    Andrew
    SoCal
    Now running a MGM 2011 DCLB 4X4
    A whole lotta parts that are not on the truck.
    5160s are only really good for stock height on stock leafs. 5165s however, are the same shock but you can order specific stroke-travel lengths. All depends if you want a reservoir or not. I don’t think it does that much in a 2.0, especially with monotube-gas shocks.
    IwasDacapsterAz and ARCHIVE [OP] like this.
  11. Feb 1, 2019 at 4:13 PM
    #831
    St.Germain
    St.Germain Sport truck!
    NTX
    thanks @ARCHIVE
    Eric, this is a great improvement, and had i known i never would have waited so long. goodbye jitters. i run E tires in the stock diameter, 265/65-17, and those tires are like driving on 4 little rocks. this has really smoothed it all out. the quality feel is now complete with the rear catching up to the front now regarding ride quality. :thumbsup:
  12. Feb 1, 2019 at 5:56 PM
    #832
    ARCHIVE
    Eric
    Awesome! Thank you for your feedback
    St.Germain likes this.
  13. Feb 5, 2019 at 2:37 PM
    #833
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    So I would like to place an order on these but wanted to see if these potential issues would affect the hangers negatively. My current rear suspension set up is tsb rear leafs, defined engineering rear brace, and Bilstein 5160 rear shocks. I plan to add energy suspension bushings for the rear leafs and a rear sway bar. Maybe a panhard bar but very unlikely. I would also like to keep my banks catback unmodified from clearance issues. Any insight is appreciated.
  14. Feb 5, 2019 at 2:43 PM
    #834
    ARCHIVE
    Eric
    Hey Robert
    The stock springs are great with HH, the 5160 are fine. The Defined bar wont fit, but I offer a cross tube option. Sell the Defined bar. And you should not need to trim the exhaust if similar to stock. Pan hard bar isn't needed, sway is reduced by HH. PM'd you TW discount
    Eric
  15. Feb 5, 2019 at 3:14 PM
    #835
    hoarder23
    hoarder23 Truck fell over
    Shay
    San Diego
    11 Black DCSB TRD OffRoad
    Scratches
    @ARCHIVE I'd like to add the crosstube to my setup, but I don't see an option to only order the tube. How can I do this?
  16. Feb 5, 2019 at 3:23 PM
    #836
    Lucario Runner
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    Thanks mate.
  17. Feb 5, 2019 at 3:45 PM
    #837
    ARCHIVE
    Eric
  18. Feb 16, 2019 at 10:36 AM
    #838
    TD90S
    TD90S Got two legs of chicken and half pint of gin
    GA
    ‘18 TRDOR 6MT
    Anyone try these on a stock height Pro?
    I switched to fox pro shocks and they definitely eliminated most of the rear chatter, still have some if the surface conditions are just right.
    Also get a condition when at times it feels like the rear isn’t planted.
    This isn’t when the rear is chattering, more on smooth surfaces. Transition changes, winding mountain roads. Get a vague not planted feeling for a second and then it is fine.
    Anyone else?
  19. Feb 16, 2019 at 1:32 PM
    #839
    ARCHIVE
    Eric
    Sounds like you're describing sway during transition changes and it is due to the stock hangers flexing
    TD90S and kakwvu like this.
  20. Feb 16, 2019 at 1:37 PM
    #840
    kakwvu
    kakwvu Almost Heaven
    Kyle
    Morgantown, WV
    2016 OR 4X4 6MT BBP
    I don’t think there’s any circumstance where these aren’t a huge upgrade. I’m saving up for these, new leafs, and brake lines. Look forward to a more stable rear end :rolleyes:
