Tacoma hard start after warmed up
Discussion in '1st Gen. Tacomas (1995-2004)' started by mebedave, Jul 14, 2010.
  1. Jul 14, 2010 at 5:19 PM
    mebedave
    mebedave [OP] Member
    Dave
    Kansas
    basic truck
    I have a 1996 Tacoma 137,000 miles 5 spd. 4 cyl. I just bought the truck yesterday and I have discovered that after the truck warms up just a little it becomes real hard to start. I have to hold the key in start for a very long time engine spinning and then it starts to come alive very slowly and then it starts, and then it run's very good. I let it set over night and all day in the hot sun, and it started right up no problem what so ever. I then drove it about two blocks turned engine off and it did it again. I gave it a little starter fluid but that did not help at all, I think its not getting spark.
    Can anyone help me out!!
    Thanks
  2. Jul 14, 2010 at 5:26 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It could be a number of things. Has it been a while since the last good tune up?
  3. Jul 14, 2010 at 5:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what all has been done lately?? sounds like one of two things for me...........either the iac valve needs cleaned/replaced...or the tb needs to be cleaned.
  4. Jul 14, 2010 at 5:51 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    I had this problem on a 96 2.4l. I don't know the exact way it's explained, but it wasn't using all of the gas fumes in the throttle body when I shut the truck off. Then it would be partially "flooded" when I went to start it before the fumes escaped. Cleaning the throttle body/ intake manifold and changing the spark plugs fixed mine.
  5. Jul 14, 2010 at 6:39 PM
    NickJ*97756
    NickJ*97756 Well-Known Member
    Nick
    La Grande OR
    95 Red Ext. Cab
    Black Ultra Type 175 Rogue wheels, 33x12.50's, exhaust, sony deck,JL tweeters, hella 500ff's, painted rear bumper, brush guard, tail lights, kc's, custom tube bumper,5100's w/trd springs, toytec aal, custom tire carrier
  6. Jul 15, 2010 at 2:38 AM
    mebedave
    Dave
    Kansas
    basic truck
    What’s the best way to go about cleaning the TB, and what/where is the IAC valve?
    I just bought the truck so not to sure about what’s been done to it. The seller told me they just put a fuel filter, air filter, and oil change. I called him back today and he did admit that this has been a problem for a few months now.
    I think I'll go buy some tune up parts for it plugs, wires and cap. Is there anything else I should get at this point?
  7. Jul 15, 2010 at 4:56 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  8. Jul 15, 2010 at 5:48 PM
    humtaco
    humtaco Well-Known Member
    Be sure not to depress the accelerator when starting. The couple of times I spaced out and did "give it gas" it made the truck more difficult to start. This is when the engine was at operating temps already.
    96 2.7
  9. Jul 16, 2010 at 1:51 AM
    mebedave
    Dave
    Kansas
    basic truck
    Thanks 98tacoma27 for the files and yes it's a 4 banger
  10. Jul 16, 2010 at 1:55 AM
    mebedave
    Dave
    Kansas
    basic truck
    NickJ Have you had a chance to try that temp. sensor yet, let me know how that goes
  11. Jul 16, 2010 at 5:40 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Put a meter on your coolant temp sensor. Check the readings cold and hot. No change=bad sensor. Same can be said for the intake air temp sensor.
  12. Jul 16, 2010 at 10:34 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    x2
