Tacoma hates cold weather
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Jan 23, 2013.
  1. Jan 23, 2013 at 3:35 PM
    inouk
    inouk Well-Known Member
    I just started my Tacoma at -25F today (true temperature, no windchill factor). It stayed outside without running it since three days.
    Engine was turning square. It started like this: "WOF ... WOF ... WOF ... WOF" and then it turns over.
    My clutch pedal was hard to push.
    I have a block heater but it's on the table in my garage.. Just didn't have time to put it on :facepalm:
    P.S: I use synthetic oil only.
  2. Jan 23, 2013 at 3:42 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Mine has been a little rough to start a couple times with the cold day lately. No other issues. Temps are great for business though so I won't complain.
  3. Jan 23, 2013 at 5:13 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well it got to a balmy 3.4F today in the afternoon sun Only thing I noticed was the idle was a little higher then normal till it warmed up.
  4. Jan 23, 2013 at 6:16 PM
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    well this morining it was 2 degree in NY.. certainly my taco was stiff. took a few min to warm up and let her roll down the road before hitting the highway. With the manual shift stick. man.. it like pushing in jar of honey. Once I get to 40000 mile mark, it going to change to sythic oil all the way thru. on the gearboxes.
  5. Jan 23, 2013 at 6:27 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If it started up, its doesn't hate the cold too much. The things you mention are not tacoma specific, as the laws of physics apply to all vehicles in cold. If it gets that cold often in your area, I wouldn't be without a block heater and a timer. Set it to turn on about 4 hours before you're planning to start the truck, and it will save a lot of wear & tear and warm up time. The toyota cartridge style block heaters run about $60 ish from the dealer, and pretty easy to install.
  6. Jan 24, 2013 at 4:30 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    That's the shitty thing to when it comes to owning a standard. Over the last decade I've had many vehicles and they were like how you described in the winter time. When it would be -30C with a -40C wind chill, they didn't like it very much. I noticed with my automatic took a minute or two to start. But once it started, we were good to go. I do miss driving standard sometimes, I am just glad that I don't have the cold issues that come along with a standard since I have an automatic now.
  7. Jan 24, 2013 at 8:37 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    For the Love of Tacomas if nothing else, move to warmer climates ASAP! :D
  8. Jan 24, 2013 at 8:41 AM
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    Workman's Tacoma loves sub zero temps. Whenever he starts it below zero, his engine makes a high pitched squeal. A squeal of happiness!
  9. Jan 24, 2013 at 8:44 AM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Mine has been hard to start. I stuck my foot in my mouth earlier in this thread. I think it needs a heating blanket.
  10. Jan 24, 2013 at 9:21 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Never had any problems with mine until the last few days. It's been below 0 at night, my clutch gets stuck when I first start the truck in the morning,turns over slow,makes some weird sounds like the starter sticks for a split second.
  11. Jan 24, 2013 at 9:34 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    My automatic has loud piston slap which is very noticeable in the winter for the first 6-8 minutes- dealer said it's normal! Maybe normal for the 4.0 'cause my Camry 2.5 doesn't do it and neither has any other vehicle I've owned...
  12. Jan 24, 2013 at 9:48 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    What viscosity grade of engine oil and gear oil are you using? Try 0W20 for the engine and 75W-90 for gear if you haven't already.
  13. Jan 24, 2013 at 10:27 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Workman's post just crack me up everytime.:rofl:
    When it is -30 -> -35C outside, the cluth is really stiff and not responsive, takes like 5 seconds to come back after beeing pressed. A few minutes of idling and truck is drivable again.
    I do plug it in in temperatures below -20C. All fluids are changed at the dealer at recomended intervals.
  14. Jan 24, 2013 at 9:48 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Same here, I like to just stay indoors on subzero days. Even the dogs don't wanna go out in that weather which says something, because they love being outdoors for the most part! My 2.7 does clatter as well, but stops after a few seconds. Clutch pedal and tranny is stiff too but I let it sit and warm up good before I take off. Starting up and taking off in bitter cold like that is really hard on a rig.
  15. Feb 1, 2013 at 11:47 PM
    #35
    florze
    florze Member
    canada
    2010 sr5 4door
    Factory xm Blu logic
    My Tacoma takes forever to warm up during the winter. Will never get to operating temperature in the city. Gas mileage is horrible. Seriously thinking about getting a winter front.
