Tacoma hesitation acceleration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 999TRD, Apr 18, 2024.
  1. Jun 20, 2024 at 4:07 PM
    #41
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    If 10 seconds isn’t an exaggeration then idk what to tell you other than take it to a mechanic.
    My 2016, prior to getting it tuned, would bog down and have a delayed response on the throttle for a few seconds max….but 10 seconds, if not an exaggeration, is dangerous
    BillyE likes this.
  2. Jun 20, 2024 at 4:18 PM
    #42
    BillyE
    BillyE Well-Known Member
    ok. Something is broken. 10 seconds means you could push the pedal down, get out of the truck and run a Chinese fire drill, and climb back in before it goes anywhere.
  3. Jun 20, 2024 at 5:31 PM
    #43
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Yep…….ai shit you not. But no code, no check engine light. It’s going into limp mode……
  4. Jun 20, 2024 at 5:34 PM
    #44
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
  5. Jun 20, 2024 at 5:41 PM
    #45
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Side note: I was running KD Max 9.0 and loved it, until I got the upgrade to the Black Hawk tune that YotaWerx offered to bring KD Max people over. Worth a look.
    Road_Warrior[QUOTED] likes this.
  6. Jun 20, 2024 at 5:50 PM
    #46
    czukie
    Colorado
    Bro if it’s legit going into limp mode then some major is wrong with it, like that’s not just being bogged down or a delayed throttle response.
  7. Jun 20, 2024 at 5:52 PM
    #47
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2019 TRD-OR AC
    ACIS plenum
  8. Jun 20, 2024 at 6:01 PM
    #48
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace.
    When is the last time you changed the spark plugs? If you haven’t, I would start there.
  9. Jun 20, 2024 at 6:25 PM
    #49
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You need to datalog with techstream or some other high refresh rate scanners.
    Limp mode is triggered by specific codes.
  10. Jun 20, 2024 at 6:32 PM
    #50
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    I only ever encounter the bog coming out of a "rolling stop"...lasts about 2 seconds I would say for my 3rd gen AT
  11. Jun 20, 2024 at 6:37 PM
    #51
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Ok, so no codes. So it’s not in limp mode?
  12. Jun 20, 2024 at 6:38 PM
    #52
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    when it acts up, it’s much worse than the standard Tacoma hesitation
  13. Jun 20, 2024 at 6:39 PM
    #53
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    just over 20k
    It’s not plugs
    It’s some completely random crap
    Intermittent
  14. Jun 20, 2024 at 6:53 PM
    #54
    Vlady
    Issy, WA
    Correct. No codes, no limp mode.
    If you have access to Service manual, there is a section (fail safe) with all codes.
    Accelerator and throttle body codes are there.
    On new tacomas, torque converter lock solenoid is engaging in 2nd, in older models in 3rd.
    When it happens, the throttle plate is getting closed while maintaining the same accelerator input. Usually It lasts for about a sec. You mentioned 10sec,which a lot.
  15. Jun 21, 2024 at 3:25 AM
    #55
    BillyE
    Trade it
  16. Jun 21, 2024 at 5:51 AM
    #56
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    honestly, if the Tundra engines didn’t start Spinning, I probably would have
  17. Jun 21, 2024 at 6:13 AM
    #57
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It doesn’t always happen when driving from a stop. It’s completely random.
  18. Jun 21, 2024 at 6:18 AM
    #58
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I’ll make that my next update when I get around to it, thanks!
    usmc2msu[QUOTED] likes this.
  19. Jun 21, 2024 at 6:18 AM
    #59
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    If you have not done so recently, do the simple stuff first.
    Clean the throttle body. A dirty throttle body can have a huge impact on performance and idle.
    Put in a new PCV. They are dirt cheap. Forget the “rattle” test. Just put a new one in.
    If you are running an afermarket air filter, dump it and put Toyota OEM filter in. I tried 3 different aftermarket filters, and all 3 caused the truck to seriously struggle going up a long steep highway incline. Brutally starving for air. On the flats those filters were fine. Not until pushing it up a 20 mile steep climb did the issue become apparent. Same hill I drive for fishing trips, same weight and fuel type in truck each time. OEM filter returned performance to normal. I was shocked those filters had such a negative impact on real performance.
    Clean your MAF.
  20. Jun 21, 2024 at 6:39 AM
    #60
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I have zero issues with my 2023 I use 93 octane which I’m sure that helps. I don’t drive my truck like it’s a sports car so I’m happy with it just the way it is.
    bkhlrTaco's likes this.
