Tacoma Horn Issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachPrerunner, Jul 27, 2015.
  1. Jul 27, 2015 at 6:58 PM
    ZachPrerunner
    ZachPrerunner [OP] Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I'm not sure if this is more of a problem or question. My Tacoma's horn doesn't blow when I lock my doors. Is this normal? It works when I blow it from inside the cab, but doesn't sound when I lock the doors.
  2. Jul 27, 2015 at 7:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  3. Jul 27, 2015 at 8:06 PM
    ZachPrerunner
    Southeast TN
  4. Jul 27, 2015 at 8:10 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No it is not only the VIP systems. I have a plain SR5 Prerunner and it chirps once for locked and twice for unlocked. It can be turned on or off in the ECM. See my link above.
  5. Jul 27, 2015 at 8:12 PM
    ZachPrerunner
    Southeast TN
    Yeah I looked at the link, so you use the remote key fob to change between the on and off setting? Does it matter between the lock and unlock button?
  6. Jul 27, 2015 at 8:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    From the Link:
    1.) Step one: Open the drivers door and insert the key into the ignition.
    2.) Step two: Remove the key from the ignition and, within 5 seconds, reinsert the key back into the ignition and switch to the on position.
    3.) Step three: After 10 seconds, the system enters the answer-back mode.
    4.) Step four: Within 10 seconds of the answer-back beep the switching mode is started, press the remote twice and the system will turn off or on based upon which the system is set. ( if it was off it will turn on, if it was on it will turn off ).
  7. Jul 27, 2015 at 8:19 PM
    ZachPrerunner
    Southeast TN
    Yeah I understand all of the steps until the "press the remote twice". Which button do I press twice on the remote? Both of the buttons or just the lock/unlock?
  8. Jul 27, 2015 at 8:21 PM
    ZachPrerunner
    Southeast TN
    Mine doesn't even do that. It just flashes the lights with no sound whatsoever.
  9. Jul 27, 2015 at 8:24 PM
    ZachPrerunner
    Southeast TN
    No sounds when locking or unlocking. Just the lights and the door clicking sound. If it was a teenager, they took excellent care of it!
  10. Jul 27, 2015 at 8:27 PM
    ZachPrerunner
    Southeast TN
    Haha I suppose so. I'll have to check everything tomorrow when I can see what I'm doing. I bet they turned it off, but we will find out soon enough.
  11. Jul 27, 2015 at 8:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  12. Jul 27, 2015 at 8:42 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Pretty sure you can press either the Lock or Unlock button twice. Not both.
  13. Jul 27, 2015 at 8:48 PM
    ZachPrerunner
    Southeast TN
    Oh okay thank you. I'll try in the morning and post back the results.
  14. Jul 28, 2015 at 12:09 PM
    ZachPrerunner
    Southeast TN
    I tried to see if the alert was disabled, but nothing happened when I clicked the button twice.
  15. Jul 28, 2015 at 1:41 PM
    Gatordog
    Gatordog Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    ^^^^^^^^^^^ this
    100% disables the chirps...and horn signal if you double hit the lock. LOVE it being quiet and did it with a dress shirt and tie on. Easiest mod there is. Can be reversed following same directions I believe
  16. Jul 28, 2015 at 1:45 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Hell yeah, love that it can be disabled. The chrip/beep F that noise. I come home late sometimes and the last thing I want is to have my neighbors hear my Taco chirp beep honk etc. Lame.
