Tacoma Horn randomly goes off part 2
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheBlackTaco01z, May 3, 2021.
  1. May 3, 2021 at 3:42 PM
    TheBlackTaco01z
    TheBlackTaco01z [OP] Active Member
    2001 Black Tacoma TRD
    Well last night I was woken to my trucks horn blaring at 2 in the morning. I once again had to pull the horn fuse to stop it.So I come here to once again ask for help.
    As a recap my truck is a 2001 3.4L Tacoma. It does not have any sort of security system. The horn relay from my understanding is integrated to the ECU. I went ahead and took the airbag out, and sanded the horn contact points down and made sure the contacts weren’t sticking.
    It seems like the horn only goes off randomly when I’ve been driving in wet conditions. This weekend I’ll be spending my time looking for a short in the wiring harness which should be “fun”.
    I hope I find something thats wrong this weekend because at this point I’m about to tap into the factory wiring harness so I can install a switch, which I really would rather not do, but I’m desperate.
    I love my truck and all, but after last night I’m about ready to drive the thing into the Grand Canyon. So any advice would be much appreciated!
  2. May 3, 2021 at 6:05 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Have you ever taken the time to figure out why it is on?
    then it stops all by itself and works for a few days.
    about the only thing is something energizing the horn relay.
    Are you driving in Salt Water Fresh water is a very poor conductor and most likely cause it to not work at all.
    Maybe you have pissed off someone who likes to blow your horn
    The Horn Relay is incorporated with the body ecu.
    Most times these thing
    gs are caused by Alarms but you don`t have any.
    good luck
    TheBlackTaco01z[OP] likes this.
  3. May 4, 2021 at 5:15 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    So when this is happening, is the horn just constant ON, or is it "honk, honk, honk, honk"
    Constant on would be something grounding the horn circuit.
    Honk, Honk, Honk, Honk would be an alarm system.
    Prior to 01, the horn was just triggered by the switch grounding the horn relay. In 01 toyota integrated it with the body ECU (which is essentially a smart relay). It doesn't actually have a separate relay, at least from what I can tell on the wiring diagrams.
    Either something is going on in the body ECU, or the Green-Red from the horn switch which connects to pin 13 on the body ECU is getting grounded (most likely case).
    I have attached the horn circuit for a 03 truck. It really isn't much help other than giving you the wiring colors and pin numbers.
  4. May 4, 2021 at 5:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do you have cruise? Does it work?
    whatstcp and TheBlackTaco01z[OP] like this.
  5. May 4, 2021 at 10:19 AM
    TheBlackTaco01z
    When the horn goes off, it’s a constant noise. Thanks for the wiring diagram! So I’ll go ahead and look at the wiring going to the body ECU.
  6. May 4, 2021 at 10:20 AM
    TheBlackTaco01z
    The cruise control does work.
  7. May 4, 2021 at 10:23 AM
    TheBlackTaco01z
    It’s only ever exposed to fresh water. So I guess the water wouldn’t be setting it off.
    Wyoming09[QUOTED] likes this.
