Tacoma Horn randomly goes off
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheBlackTaco01z, Mar 17, 2021.
  1. Mar 17, 2021 at 9:25 AM
    TheBlackTaco01z
    TheBlackTaco01z [OP] Active Member
    2001 Black Tacoma TRD
    My 2001 Tacoma recently started setting the horn off randomly. It’ll go off in the middle of the night, and keep blaring for ten minutes, and I have to pull the fuse to stop it. Other wise the horn works normally when I need to use it. I tried looking for the relay, but from my understanding it’s integrated into the ECU. Anyone have any suggestions on what I do to fix this? Thanks!
    PennSilverTaco likes this.
  2. Mar 17, 2021 at 9:31 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Welcome to TW!!! :hattip::wave:
    Just out of curiosity, did your CEL (Check Engine Light) come on when you pulled the fuse? My horn was damaged in a rear-end collision back in August 2015, but the problem didn't manifest itself until about a month later; I beeped at a guy who ran a stop sign and the horn stayed on. I ended up having to pull the fuse, and when it did, the truck totally shut down; When I started the engine back up, the CEL was on. I have had my truck since it was new (more than 11 years) and am getting ever closer to 130K miles, and I am proud to say that is the only time my CEL has ever been on!
  3. Mar 17, 2021 at 9:37 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The horn return spring is probably worn out, possibly broken it's just a thin piece of cheep stamped flat steel.
    Sometimes you can get away with pulling your airbag and rebending the spring.
    It's also possible the contacts are arc'ed up and it's sticking (welding) together until current is removed.
    You can fix that by again pulling the airbag and sanding the contact pads back to smooth clean copper.
  4. Mar 17, 2021 at 9:47 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I dunno? That doesn't sound quite right. I could understand that happening when you press on the horn on purpose. Randomly happening at 3 in the morning sounds more like an alarm issue.
    The clock spring could be bad, but I've found that usually means a horn that does not work at all.
    Does this truck have a glass break sensor? Maybe disconnect that?
  5. Mar 17, 2021 at 9:48 AM
    TheBlackTaco01z
    No check engine light ever came on
  6. Mar 17, 2021 at 9:49 AM
    TheBlackTaco01z
    I’ll give that a shot! Thanks!
  7. Mar 17, 2021 at 9:51 AM
    TheBlackTaco01z
    The truck doesn’t have any security system I don’t believe. I only use a key to lock and unlock the car, no alarm system.
  8. Mar 17, 2021 at 10:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Perhaps you have parts of an alarm system it happens all to often.
    Neighbors messing with you?
    The horns works normal at all times.
    When it goes off in the wee morning hours the only way to shut it off is remove the fuse?
    Then when the fuse is replaced the horn starts up again or everything is normal to the next Morning at 0300??
    The horn never goes off at random while driving??
    Sure points to an Alarm or parts of one or someone Having Fun. I would have loved to have done this to the Sperm Donor as a Kid.
  9. Mar 17, 2021 at 10:49 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Things cooling overnight may have something to do with why it does it in the middle of the night. I'm with the return spring/contact arcing crew on this one.
  10. Mar 19, 2021 at 12:14 PM
    TheBlackTaco01z
    Well I went ahead and sanded and cleaned all the contact points of the horn. So far so good! I guess I’ll update in the future, thanks for the help!
  11. May 9, 2024 at 5:36 PM
    Koolman_Taco
    Koolman_Taco Well-Known Member
    Scott
    Bozeman, MT
    2020 Black Tacoma TRD Pro
    SSO winch bumper, UpTOP overland racks, Baja design lights, Switch-Pros 9100.
    Has this continued to work? My 2001 just started blasting the horn in the middle of the night and had to pull the fuse.
  12. May 9, 2024 at 8:01 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
  13. May 10, 2024 at 6:42 AM
    Koolman_Taco
    Scott
    Bozeman, MT
    I was going to. Just wanted to know if it was still working for him before I went through the trouble. He said he would update in the future, so I was just asking for the update. :notsure:
    ztwatson likes this.
  14. May 11, 2024 at 10:17 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Your truck is horny. Find a 4 runner to solve the problem. Waka Waka Waka.
