Tacoma Hybrid is Possible: 31MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomanto, Jul 8, 2014.
  1. Jul 9, 2014 at 4:22 AM
    #41
    beondwacko
    beondwacko Well-Known Member
    West Palm Beach, Florida
    08' X-Runner , Sirius radio, fog light mod. Much more to go.
    One possible option that Toyota might use in the next Taco might be from the new Lexus 200T. It's got a 2.0L turbo 4 banger rated at 235hp/258 ft/lbs. That engine with the 8sp already in the IS might be an optional power train combo that would be effective with the correct gearing. It's not the optimum choice for our off road crowd and no mention if a manual trans will ever be hung off the back of it. The damm turbo is integrated into the cylinder head for reduced lag and thermal efficiency.
    I have no idea if this would be all that much better than the current 4.0l in terms of mpg,but with the 8sp trans, if it were correctly geared, would be a better overall performer than the 4.0.
  2. Jul 9, 2014 at 4:33 AM
    #42
    jharkin
    jharkin Well-Known Member
    Jeremy
    Massachusetts
    14 DCSB TRD OR
    12volt/20amp bed outlet access tonneau
    I suspect the writers of that article dont know much about automotive engineering.
    First off, why do they think Toyota would want to build a Tacoma, even a hybrid one, as FWD? There is a reason why 2wd trucks, save for the Honda, are always RWD. Its not simply for traditions sake to put the drive wheels under the payload - its to make them drivable. Trucks are nose heavy, and our plastic bed Tacomas make that even worse. Ive read in reviews the DC 4x4 is 55% front/45% rear which is damn good for a truck, a reg cab 2WD is probably more like 60-65% front / 35-40% rear. Put all the drivetrain up front and add the weight of hybrid gear and you are probably giong to be pushing 70% or more front (unless they stuck the battery under the bed). Thats undrivable, the rear end would get air over bumps and you would be spinning out all over the place.
    Not to mention that the Lexus 300h drivetrain is a transverse mounted engine. They would have to significantly redesign the front end to replace our existing longitudinal drivetrain with that. I cant really see it making sense for them having a design that would take a transverse engine in the hybrid edition and a longitudinal in the conventional. Which means itf they did it, the new truck would have a Honda Ridgleine like drivetrain, FWD biased with a power takeoff to the rear end on '4wd' editions.
  3. Jul 9, 2014 at 5:01 AM
    #43
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Something is not quite right here...
  4. Jul 9, 2014 at 7:32 AM
    #44
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Hybrids are just that , hybrid , not fully electric
    That would be like this , Formula E
    http://youtu.be/IptBVdys-mo
  5. Jul 9, 2014 at 8:02 AM
    #45
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    A hybrid Tacoma that provides reasonable performance when used like a truck and is priced advantageously for consumers is obviously still in the distant future. When they build it, i will come(insert joke here).
    The Tacoma is a slug in the city anyway, so just enough power to tool around is really all that is necessary. That said 31 mpg isnt exactly an earth shattering figure. I imagine thT figure suffers greatly when the truck carries moderate weight.
    I will be sceptical for some time.
  6. Jul 9, 2014 at 9:23 AM
    #46
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I like the idea, but doesn't that full-size dodge v6 diesel (allegedly) get 40mpg? Shouldn't a smaller hybrid truck do better than 31mpg?
    Wonder how a hybrid would work in the woods....
  7. Jul 9, 2014 at 9:23 AM
    #47
    oldswab
    oldswab Well-Known Member
    Jonathan
    Kansas
    14 dbl cab TRD OR 6MT
    My last unit had a Ford Fusion V6 hybrid on lease.
    Handled great, plenty of pickup, and got above 38mpg combined on various road trips to different campuses. People tend to walk out in front of you in parking garages because it was eerily quiet.
    Having said that, you can pay up to $8K or or $10K more for the hybrid than a 36 mpg 1.5L, which is about a third to a half again over the cost of 1.5L. That's a lot of gas tanks for a car that doesn't hold its value all that well...
    My 2014 DCSB already has about the shortest bed I can stand and still be functional as a truck. Batteries would substantially cramp it even more. They would probably need to be "in" the bed somewhere, if only to make sure they were the driest thing on a wet truck.
    What we need is a diesel or a more effecient V6. A hybrid Taco would be interesting, and would let the engineers get their feet wet, but wouldn't be for me right now.
  8. Jul 9, 2014 at 9:23 AM
    #48
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    I think trucks could benefit more from a diesel electric drive system where electric motors drive the wheels full time and are powered by a diesel generator. Electric motors have gobs of torque and provide max torque all across their rpm range. Seems like that would be ideal in a truck configuration.
  9. Jul 9, 2014 at 9:42 AM
    #49
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Weird
    http://www.ramtruck.ca/en/2014/1500/overview
  10. Jul 9, 2014 at 9:50 AM
    #50
    TrdSurgie
    TrdSurgie revised
    Oahu
    According to the article, a base tundra has less than 200hp and a 4x4 tacoma weights 3700 lbs...
  11. Jul 9, 2014 at 10:07 AM
    #51
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I said "allegedly". I don't take the advertised number from the manufacturer as truth, I just remembered the commercial on TV touting 40mpg. Having said that I wouldn't take the advertised 31mpg from this hybrid as truth either since real-world numbers would probably be less. Getting 30mpg (at best) after the extra costs of buying a hybrid would make it a tough purchase considering lots of full-sized gas trucks are getting north of 25mpg these days.
  12. Jul 9, 2014 at 10:21 AM
    #52
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Outside of the start stop tech.... toyota already has this... i have said it before and will stay it again... the next tacoma will have something VERY similar or identical to the toyota 2GR-FSE motor they already have.
  13. Jul 9, 2014 at 10:35 AM
    #53
    oldstick
    oldstick Medicare Member
    GA
    Hey, makes perfect sense to me. There is that whole 6 foot bed space just begging to be filled with batteries...
    :D:D
  14. Jul 9, 2014 at 10:38 AM
    #54
    OZ-T
    Peter North
    British Columbia
    Not sure how you guys figure the batteries would have to take up so much room
  15. Jul 9, 2014 at 11:03 AM
    #55
    oldstick
    GA
    That's true plenty of room for sure. Another plus is maybe we will finally start getting the bigger rear leaf springs standard from the factory. Can't wait...
    :D
  16. Jul 9, 2014 at 11:33 AM
    #56
    SilverGraphite
    SilverGraphite Expat Aussie
    California
    2011 TRD 4x4 bog standard
  17. Jul 9, 2014 at 12:17 PM
    #57
    matt4778
    matt4778 Member
    Blacksburg, VA
    14 DoubleCab SB
    I don't know how I feel about this. I guess it's just opening the market for the tacoma even further. It's making it less of a truck since the rated payload will be a lot less due to added battery weight. Unless they beefed up everything else to compensate.
  18. Jul 9, 2014 at 12:25 PM
    #58
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    So I e-mailed a friend of a friend at Tesla. Roughly, to move a 5000lb vehicle with the range of 100 miles, battery only(NOT HYBRID), would roughly require at least a 24 cu ft battery. He could not give me a weight of the battery. Joked that the heat sink would need to be in the 4 to 6 sq ft range. I'm guessing the battery would be L_A_R_G_E if it was a hybrid, and there was payload beyond the weekly groceries..
  19. Jul 9, 2014 at 12:46 PM
    #59
    OZ-T
    Peter North
    British Columbia
    A hybrid is hybrid , not electric only , hence the term hybrid
  20. Jul 9, 2014 at 12:47 PM
    #60
    OZ-T
    Peter North
    British Columbia
    *160hp
