Tacoma in great shape, hole in frame :( Fixable? Sellable? Worthless?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hollytacoma97, Jan 19, 2016.
  1. Jan 19, 2016 at 5:46 PM
    hollytacoma97
    hollytacoma97 [OP] Member
    1997 Gray Tacoma
    I have a 1997 Tacoma with only 173k. The truck itself is in fantastic shape and the engine is a dream. It passed inspection in August, but I have since learned mechanics never really check underneath. I have just discovered a hole in the frame on the drivers side right in front of the back rear wheel, not a good spot. My mechanic told me it could snap in two and I should not drive it! The rest of the frame is solid with only superficial rust. I went to two welders, and they both said they could fix it but with no guarantee. Help! Is it worth it to fix? Is it sell-able, (with full disclosure). Is it junk? Everyone says something different I need advice!
  2. Jan 19, 2016 at 6:03 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    If it was mine i would have it fixed. Welder/fab shop should be able to cut out the rusted area and weld in new metal.
  3. Jan 19, 2016 at 6:09 PM
    Assforkr
    Assforkr Well-Known Member
    MA
    03 taco
    If you weren't planning on selling and the truck runs well, doesn't require a ton of work to keep it going then get it fixed by a competent welder. Great little trucks are irreplaceable.
  4. Jan 20, 2016 at 6:11 AM
    hollytacoma97
    1997 Gray Tacoma
    Thank you for your replies! I am also wondering, if the frame is going in one spot does that mean it is about to go elsewhere too? I know for Toyota frames this is a common issue. I have been quoted $1000 to repair it. Which is worth it if it is just the one time. Everyone I brought the truck to, including Toyota Dealer, say they cannot be sure that it won't start having frame issues everywhere. It is 3 years beyond the recall, ( I live in the north east), so that is not an option. It looks sturdy elsewhere, with only superficial rust, but unless I took a hammer to it there is no way to really tell... Also I am a landscaper, use my truck to haul heavy soil and plants. If I fix the frame will it be able to take the weight still?
  5. Jan 20, 2016 at 6:33 AM
    Assforkr
    MA
    03 taco
    I'm in Boston driving an 03. So much salt on the ground!
    A welding shop can cut out the rot and fit healthy replacement metal. As long as the welder is competent he should have proper penetration and the frame should be solid. There are always reinforcement plates if you're really worried
    Regarding rot elsewhere, if you have rot in one spot you likely do have some rust elsewhere. No guarantees but it's safe to assume. You should clean the surface rust with wire brush or knotted wire wheel on a grinder and explore the carnage. Thin metal will sound different or pierce through when you use the pin end of a slag hammer. If nothing shows and you're still paranoid Home Depot can rent you an orthoscopic camera that you can use to scope the boxed sections of the frame. If you see scale investigate. If you see surface rust then hope for the best and douse the everloving shot out of your truck with fluid film. I take a bath in the stuff yearly when I butter my
    Truck with the gallon bucket and a brush and then finish off with way too many spray cans and applicator wand. Because I'm paranoid. Very paranoid.
  6. Jan 20, 2016 at 6:48 AM
    hollytacoma97
    1997 Gray Tacoma
    Ha! Yes one has to be paranoid when it comes to these darn frames....I realize now I should have been coating it every year, might not have this problem now.....ugh.
  7. Jan 20, 2016 at 7:04 AM
    Assforkr
    MA
    03 taco
    When I moved to Boston 2 years ago I bought a 14 double cab because I was so paranoid about frames. Then I saw that newer tacos were experiencing the same issues. So I spent 4-5 months locating a first gen taco with specific features and a brand new frame. Drove from Maine back to NYC. Found one, sold the 14 and a week after I got it I took my first bath in fluid film. I'll let you know if it's just a placebo but I really hope not. Regardless, good luck to you. Sometimes the extra labor and lack of features seem like too much work, and then you look at how awesome the first gens still are and that you can always add features. I have backup cam, seat heaters and built in radar. Love his thing! Keep her going if that's what you want.
  8. Jan 20, 2016 at 7:17 AM
    FOXY 367
    FOXY 367 " PAIN IS LIFE'S GREATEST TEACHER "
    2016 Tacoma DC Long Bed TRD Sport 4 X 4
    None
    Take it to Toyota Dealer there was a recall on this issue they replace my 2002 Prerunner frame and with 134000 miles at no charge and gave me a free rental car for the 7 days it took to replace it.
  9. Jan 20, 2016 at 7:19 AM
    FOXY 367
    None
    If they refuse to do anything tell them you intend to contact the State Attorney's office and the NTBS.
  10. Jan 20, 2016 at 7:26 AM
    hollytacoma97
    1997 Gray Tacoma
    My truck is a 1997. From everything I have researched the frame recall is only good up to 15 years, so I am 4 years too late. I went to a dealer here, they said they could not do anything, that my truck was past the recall date for my year. Is that not correct?
  11. Jan 20, 2016 at 7:27 AM
    Assforkr
    MA
    03 taco
    It's a 97. I don't know if they do buyback anymore on anything pre 2001
  12. Jan 20, 2016 at 7:28 AM
    Assforkr
    MA
    03 taco
    15 years from date of it rolling off the lot. The pre-2000s mostly got bought back by Toyota so I don't think frame or buyback are options. It'd be great if I was wrong but I don't think I am.
  13. Jan 20, 2016 at 7:29 AM
    hollytacoma97
    1997 Gray Tacoma
    yeah, I am pretty sure its too late for that. I am thinking that a mechanic/welder should own my truck. Then they can repair and maintain the frame if anything comes up. I am neither unfortunately.
  14. Jan 20, 2016 at 7:56 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Get it fixed and then get it inspected,cleaned,and coated with something like Rust bullet.
  15. Jan 20, 2016 at 8:07 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If worst comes to worst, you could part it out and make your money back. There's plenty of folks around here that wouldn't mind saving the good parts from a crusher.
    hollytacoma97[OP] likes this.
  16. Jan 20, 2016 at 9:57 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
  17. Jan 20, 2016 at 10:08 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    It's probably just above the leaf spring hanger? Yeah, it's a pretty heavily loaded area.
    Just go to a welder and get a doubler plate welded over the hole. The factory welds are done mostly by robots and are actually pretty crappy (but qualified with extensive durability testing). The frame rusts from the inside (one of the drawbacks of a boxed frame), so you won't see anything until a hole develops. When another hole forms, go to the welder and repeat the process.
  18. Jan 21, 2016 at 1:15 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    OP where do you live ??Any where close to Allentown Pa ??
    Maybe time for a New Mechanic (Moot Point) who if working on 4x4 should be able to fix minor problems like this.
    Since your going to pay someone for this work you might want to think long and hard about selling this now as is
    The thing about no guarantee is most customers would think a repair covers the rest of the frame not just the area just fixed.
    This is something that needs a constant checking as other spots may come out .
    As the rust comes from the inside out it is hard to see till it needs attention.
    If you can`t work on your own truck they get expensive fast
  19. Jan 21, 2016 at 2:41 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Sell it.
  20. Jan 21, 2016 at 7:08 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
