Tacoma is shaking at highway speeds
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jonathannn05, Jun 9, 2020.
  1. May 28, 2025 at 10:51 AM
    #61
    Sungod
    Sungod Well-Known Member
    St Augustine
    Where are you feeling the vibration? Typically at speed is a balance problem. Road force is an absolute joke, it could still be the tires.
  2. May 28, 2025 at 12:01 PM
    #62
    ControlledChaos
    ControlledChaos Member
    What I'm experiencing is identical to what OP describes. Cabin shaking left/right, most visibly seen by the passenger seat, but no vibration in the steering wheel.
    I haven't really noticed the kind of rhythmic vibration people get with the needle bearing but I don't think that bearing would shake the entire cabin at 75 mph.
    The truck had a 2" lift put on by the first owner so maybe the needle bearing does need to be replaced.
    Another possibility I've considered is the drive shaft, but with only 7,000 miles?? I guess anything is possible.
  3. Jun 8, 2025 at 5:10 PM
    #63
    duncanaustin1211
    duncanaustin1211 Well-Known Member
    Austin
    2019 Tacoma TRD sport
    Man I’m having the same issue vibrations around 50mph-75mph if you have a drink in the cup holder it shakes like crazy. It’s in the seats and floorboards. It’s not a balance issue so I’m not sure what it could be.
  4. Jun 10, 2025 at 11:57 AM
    #64
    MGMTOR22
    MGMTOR22 Member
    2022 TRD Pro
    My 2022 had multiple issues that ultimately led me to sell it, but before I did, I was able to solve the highway vibration issue (pass seat shaking, etc). I tried 4 sets of tires and the AG leaf hangers. New rotors and drums. I had the tires balanced at multiple Discount Tire locations and my local Toyota dealership, all using road force machines. They all said the tires were balanced, but the vibration continued. I also thought about the driveshaft. Eventually a friend recommended a local shop that does wheel/tire ‘match mounting’ so I decided to give that a shot. This shop was able to tell me exactly what was off with balance and runout and had it all fixed within an hour. Cost $250 (they did all 5), but the truck, with 275/70/16 K02s, was as smooth as a Camry at 90 mph. Crazy the difference it made. Almost too civilized to be a Tacoma. Hope this helps.
