Tacoma is tracking all over highway after adding 285's.. Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clh850, May 22, 2015.
  1. May 22, 2015 at 6:51 PM
    clh850
    clh850 [OP] Well-Known Member
    Cody
    PCB, Florida
    '14 TRD Sport
    I just went up to 285's and now the truck wants to track all over the highway, following the ruts developed by traffic. Anyone else having this issue? Is there anyway to help alleviate the problem???
  2. May 22, 2015 at 6:52 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    How's your alignment?
  3. May 22, 2015 at 6:53 PM
    clh850
    Cody
    PCB, Florida
    '14 TRD Sport
    Had it aligned about a month ago and they said it was in spec.
  4. May 22, 2015 at 6:55 PM
    VolcomTacoma
    Jeff
    NorCal
    I'd contact your city council about road ruts then lol. Tire size should have zero issue with road tracking. Just maybe the wider tire is just barely the size of the ruts and causing some tracking, but I never had an issue with my 285s
  5. May 22, 2015 at 7:01 PM
    clh850
    Cody
    PCB, Florida
    '14 TRD Sport
    Gonna get them to check my alignment again next week to see if that helps. What lift, ect are are you running? Could changing to after market uca's help this?
  6. May 22, 2015 at 7:08 PM
    VolcomTacoma
    Jeff
    NorCal
    Nah, tracking is usually an alignment issue or just shitty roads. If your alignment is in spec, then it's just roads and you're SOL lol
  7. May 22, 2015 at 7:10 PM
    canonmutant
    canonmutant Well-Known Member
    Kansas
    02 PreRunner TRD
    What size are your rims? Tread too wide for rims will cause tracking problems.
  8. May 22, 2015 at 7:13 PM
    VolcomTacoma
    Jeff
    NorCal
    He's fine, those SCS are 16x8 or 17x9 iirc so 35's are still fine lol. You can run 33's on just about any rim for the tacoma.
  9. May 22, 2015 at 7:15 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I had mine road force balanced at full pressure (65), then dropped back down to normal pressure (50~55) after balancing, made a world of difference. Also, it takes a couple hundred miles for the plies to set as the rubber outgasses. Best to only rotate back to front if they are squirrely and settle.
  10. May 22, 2015 at 7:18 PM
    VolcomTacoma
    Jeff
    NorCal
    Whoa! 65 is like max pressure lol? I usually ran 45-50 in my BFG AT 33's and even that made them pretty stiff.
  11. May 22, 2015 at 7:25 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Your caster is too low. "in spec" can mean it's crappy but passable. It's probably like 1.6 or something low and still in the green. Aftermarket UCA's will definitely get you more caster. I had the same lift height without UCA's and it was in spec but wandered all over the freeway. It sucked!
  12. May 22, 2015 at 7:30 PM
    Pigpen
    Dan
    Northwest Montana
    UCAs are the only answer. Get up over 2.0 caster and you'll be fine. 2.5, you'll be glued to the road.
  13. May 22, 2015 at 7:34 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I have Cooper Discoverer S/T, D Rated, max pressure 65 psi.
    E rated max at around 80 psi.
  14. May 22, 2015 at 7:34 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    It's likely the tire width. My in-laws' FJ used to have 285's on 20" rims and it was all over the place on uneven roads or specifically roads worn in the tire paths. Putting 265's on (and 235's in the winter) totally alleviated the problem.
  15. May 22, 2015 at 7:34 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Before my uca's my truck did the same thing. As said before get uca's and as close to +3 caster as possible. I'm running 295's and track straight as an arrow.
  16. May 22, 2015 at 7:35 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    True!
  17. May 22, 2015 at 11:43 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Its probably an alignment issue but when I got my new wheels and tires mounted I had to go back twice to get everything rebalanced because I threw a weight, two days in a row.
  18. May 22, 2015 at 11:52 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I would drop your PSI too, whoever told you 65 PSI is crazy and probably eats gas like none other. I ran 35 psi on my nitto 285s, most guys do the same. As another mentioned your caster could play a part, most guys get everything in spec minus caster running stock uca's, I was one of them, but I only had a tiny bit of highway wandering with it. Good luck op.
  19. May 25, 2015 at 5:32 AM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    The max pressure is printed on the sidewall of all tires. You want to road force balance at maxpressure to stretch the plies and minimize bump steer. Every manufacturer publishes the load rating per inflation pressure, and you want to match your inflation to the weight of the vehicle. Too much pressure makes it squirrely and just burns the middle of thread off the tire, too low and the outer edges wear first.
  20. May 25, 2015 at 5:49 AM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I did this on my old tacoma and had the same issues. Chased allignment and pressures for years. Put on a normal set of tures for winter and problem mostly vanished. The problem is the roads not your truck. Its just with those tires and the design of our trucks combined with the road grooves you get that effect. When i moved away from home i stopped getting that problem because the roads were not rutted.
