Tacoma issues are going to make me cry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by creep741, Mar 2, 2015.
  1. Mar 3, 2015 at 3:53 AM
    #61
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    So the 2012 Tacoma owners manual does in fact show keys both for vehicles with and without immobilizer systems! Learn something new everyday.
    Anyone know what vehicles don't have immobilizers? Based on engine or something?
  2. Mar 3, 2015 at 4:18 AM
    #62
    Clearwater Bill
    Billy
    Largo Florida
    No, thank goodness.
    My '13 base AC just has a plain 'ole key. Exactly what I want.
  3. Mar 3, 2015 at 6:19 AM
    #63
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    While waiting to determine if there's an immobilizer, issue -
    There is an 'amplifier ring' just behind the keyway to pick up/transpond to/from the key chip, and pass the chip information to the computer.
    If that amplifier is on the fritz it won't recog. any key.
    It's known to go intermittent in at least another post. Unlikely to set any code, just let it crank....
    From oem parts supply; info.
    ELECTRICAL / BODY ELECTRICAL / ANTI-THEFT COMPONENTS / AMPLIFIER 8978304010 - amplifier
    TRANSPONDER KEY amplifier; Tacoma
    MSRPCore ?Online Price$151.48$0.00$113.61
    OBTW: X4 on the ether; nix using that old-school carburetor-era fix to avoid f-up of your o2 sensors and catalysts.
  4. Mar 3, 2015 at 6:25 AM
    #64
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    X2. Less problems when things are simple.
  5. Mar 3, 2015 at 7:43 AM
    #65
    DVexile
    Ken
    If the OP ever comes back...
    If you have a V6 engine then you do have an immobilizer and that could be the problem as others have suggested.
    If you have the 4 cyl then you do not have an immobilizer and you can ignore everyone saying it is the immobilizer ;)
  6. Mar 3, 2015 at 8:24 AM
    #66
    Pigpen
    Dan
    Northwest Montana
    Did you check your battery??
  7. Mar 3, 2015 at 8:48 AM
    #67
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    X2
  8. Mar 3, 2015 at 8:59 AM
    #68
    BamaToy1997
    Bill
    Navarre, FL
    No.
    A bad starter would either turn over slow, or not turn over at all. That's it. a bad starter is not going to cause the fuel pump to not run, or the spark plugs to not fire.
    A crank sensor, or something in the connection, could be one of several options. Having a scan tool, or an ultragauge to look at the engine data would be very helpful.
  9. Mar 3, 2015 at 11:54 AM
    #69
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    Oh. You're right. That must be it.
  10. Mar 3, 2015 at 11:59 AM
    #70
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My 09 Regular Cab doesn't have an immobilizer and the keys aren't chipped.
  11. Mar 3, 2015 at 12:01 PM
    #71
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    V6 thing
  12. Mar 3, 2015 at 12:13 PM
    #72
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    Stop saying it's the battery.
  13. Mar 3, 2015 at 12:14 PM
    #73
    la0d0g
    running for the hills
    For crawling not hauling
    It's the battery.
    just kidding its something else
  14. Mar 3, 2015 at 12:16 PM
    #74
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Make sure insurance is paid up and strike a match? All kidding aside, good luck op.
  15. Mar 3, 2015 at 3:22 PM
    #75
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Did you check for Codes?
  16. Mar 3, 2015 at 6:45 PM
    #76
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Bad ECM
    Low Tire Pressure
    Low Blinker Fluid
  17. Mar 3, 2015 at 7:17 PM
    #77
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Piston return springs?
  18. Mar 3, 2015 at 7:56 PM
    #78
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nope. Don't have it and don't want it. Expensive pain in the rear. I get keys cut for a buck fifty anywhere. I don't think any of the 2.7 liter 2TR engine models have the immobilizer.
  19. Mar 4, 2015 at 5:44 AM
    #79
    Canufixit
    New England
    IF you bought the "Courtesy Pkg" (i.e. alarm + other stuff) would it be in there ?? Just a thought but I may be wrong.
  20. Mar 4, 2015 at 7:59 AM
    #80
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Inertia switch ? Do our trucks have those?
