Tacoma issues are going to make me cry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by creep741, Mar 2, 2015.
  1. Mar 5, 2015 at 8:18 AM
    #101
    la0d0g
    running for the hills
    For crawling not hauling
    We are professionals damnit!
  2. Mar 5, 2015 at 11:34 AM
    #102
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    It's a TRAP!
  3. Mar 5, 2015 at 12:40 PM
    #103
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    So I'm curious as well.
    Per the original post, he charged the battery and it cranked. He hasn't mentioned charging the battery again. How are we (the professionals) so sure it isn't the battery?
    Has it been charged again? Has it been swapped recently? He mentioned testing the alternator at AutoZone, but not the battery. I'd start there, but that's just me.
  4. Mar 5, 2015 at 12:47 PM
    #104
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Ditto, go get it load tested. He did mention earlier that it was cranking and cranking but wouldn't fire up.
  5. Mar 6, 2015 at 2:01 PM
    #105
    creep741
    creep741 [OP] Active Member
    diamond ohio
    08 tacoma
    alright alright my butt was a little hurt but heres where im at there fellas I put the battery back on charge meanwhile I took the alternator out and took it to the pros at auto zone- tested it its good!!! ya! let my battery charge overnight put the alternator in and tried it again no spark = no run so I yanked my crank (sensor) all three pins are open- is this normal? is there an ohm spec?
    p.s. I sprayed ether in my minibike when I was twelve. I aint stopping now
  6. Mar 6, 2015 at 2:05 PM
    #106
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Please tell me that you have an automatic battery charger/maintainer... If not you are cooking your battery everytime you leave it charging overnight. It's also recommended that you unhook the negative from you battery if charging it while it is installed in the vehicle.
  7. Mar 6, 2015 at 2:06 PM
    #107
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Took it out for a test? Really?
    I'm thinking an alternator needs to be installed and spinning for a test.
  8. Mar 6, 2015 at 2:13 PM
    #108
    creep741
    diamond ohio
    08 tacoma
    no im cooking my battery, yes I should have left it in- you guys gonna help or just be knowitalley
  9. Mar 6, 2015 at 2:15 PM
    #109
    creep741
    diamond ohio
    08 tacoma
    the truck doesn't run and I have a tender sheesh
  10. Mar 6, 2015 at 2:17 PM
    #110
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    So you're cooking the battery? Just kidding man, where's chris4x4?
  11. Mar 6, 2015 at 2:20 PM
    #111
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
  12. Mar 6, 2015 at 2:26 PM
    #112
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    http://youtu.be/4yd-wW2Jhaw
    I found this, it turned out to be his fuel pump, someone else in the comments said he used sandpaper to rough up the contacts on the fuel pump relay and that was his problem(poor relay connection).
  13. Mar 6, 2015 at 2:29 PM
    #113
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Always a good idea to check for fuses that are dirty yeah but his truck is fairly new and i would hope it wouldn't be so nasty under his hood where he lives that could even happen.
    I would check all visible cables that run power and ground under the truck like the ones that go to the starter, alternator and frame ground ect too. those would have a higher chance of corrosion from weather.
  14. Mar 6, 2015 at 2:31 PM
    #114
    degu2000
    degu2000 Well-Known Member
    LOL
  15. Mar 6, 2015 at 2:34 PM
    #115
    creep741
    diamond ohio
    08 tacoma
    thank you but I done did it, Im pretty sure its the crank sensor I need to know how to test it with a meter!!!!!!
  16. Mar 6, 2015 at 2:35 PM
    #116
    creep741
    diamond ohio
    08 tacoma
    its hilarious when your truck is running, your turns a comin!
  17. Mar 6, 2015 at 2:36 PM
    #117
    degu2000
    It's amazing what Google can find on the internet..
    http://www.1aauto.com/content/articles/crank-sensor-testing
    I wasn't laughing at your truck not running. I was laughing at referring to people at auto zone pros.
  18. Mar 6, 2015 at 2:36 PM
    #118
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    We've all been there, it sucks but it'll be ok.
  19. Mar 6, 2015 at 2:38 PM
    #119
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I thought....[​IMG]
  20. Mar 6, 2015 at 2:48 PM
    #120
    creep741
    diamond ohio
    08 tacoma
    my autozone joke made you laugh?
