Tacoma issues are going to make me cry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by creep741, Mar 2, 2015.
  1. Mar 6, 2015 at 2:51 PM
    #121
    creep741
    creep741 [OP] Active Member
    diamond ohio
    08 tacoma
    the sensor is a halleffect sensor that very helpful google search was for a inductive sensor
  2. Mar 6, 2015 at 2:51 PM
    #122
    creep741
    diamond ohio
    08 tacoma
    crank position sensor is a halleffect sensor
  3. Mar 6, 2015 at 3:04 PM
    #123
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    When your truck is cranking does the tach register an rpm reading?
    It probably won't on the dash, do you have access to a obd2 scan tool or ultraguage?
  4. Mar 6, 2015 at 3:14 PM
    #124
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    These need to be here... :D
  5. Mar 6, 2015 at 3:18 PM
    #125
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Half the time I go to the dealer parts dept its the same thing... where do they get these yahoos....
  6. Mar 6, 2015 at 4:24 PM
    #126
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Yahoo search :rolleyes:.
  7. Mar 6, 2015 at 4:40 PM
    #127
    creep741
    diamond ohio
    08 tacoma
    fixnfly never fixed anything obviously
  8. Mar 6, 2015 at 4:40 PM
    #128
    creep741
    diamond ohio
    08 tacoma
    don't be mad fix we can all see what you have contributed
  9. Mar 6, 2015 at 4:45 PM
    #129
    creep741
    diamond ohio
    08 tacoma
    the tach does not register a reading like I thought it should that kinda aimed me at the crank sensor my question is does your Tacoma s tach register rpm before it starts 4x4? if it does ill replace the sensor tomorrow
  10. Mar 6, 2015 at 4:48 PM
    #130
    creep741
    diamond ohio
    08 tacoma
    don't have any special tools
  11. Mar 6, 2015 at 4:49 PM
    #131
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    On my tach it doesn't, my ultraguage shows 235 rpm just before it fires.
  12. Mar 6, 2015 at 4:52 PM
    #132
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    But to be honest though my truck starts fast enough that it doesn't have time to register, it usually fires as soon as I hit the key. Occasionally it will have to crank for a few seconds though...haven't payed the rpm guage much attention before when starting it.
  13. Mar 6, 2015 at 4:52 PM
    #133
    creep741
    diamond ohio
    08 tacoma
    not even a little bounce?
  14. Mar 6, 2015 at 4:55 PM
    #134
    creep741
    diamond ohio
    08 tacoma
    man mine will crank and crank and not register a thing, my theory is that the ecu will not send fuel or spark to an engine that it doesn't see rpm for. its 170$ part I got kids a morgatge and that's a pricey gamble, I may roll em though
  15. Mar 6, 2015 at 4:56 PM
    #135
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Nothing man, I have I think in the past seen it move when I occasionally experienced an intermittent no-start condition common among the 1gr-fe engines... That was suspected by many to be the result of the fuel pump not priming quick enough or losing prime upon shutdown. I never did anything about it and haven't had it happen again in years, my brothers 2010 has done it before as well. She's never stranded me though, bought her new 8 years ago.
  16. Mar 6, 2015 at 5:04 PM
    #136
    File IFR
    Central MA
    You may be forced to drop it off at a Toyota dealer, or a reputable independent Toyota shop. Throwing parts at it and washing the intake with starting fluid is not good.
  17. Mar 6, 2015 at 5:18 PM
    #137
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  18. Mar 6, 2015 at 5:24 PM
    #138
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Idk man, thats a pretty big gamble... I do all my own work that I can but there comes a point that you've gotta take it in.
  19. Mar 6, 2015 at 5:39 PM
    #139
    medic2230
    Murph
    Bama! Roll Tide
    I didn't think you could just swap ECU's on these trucks? Thought there was a programming issue with them.
  20. Mar 6, 2015 at 5:48 PM
    #140
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    So what do we know so far:
    1) Not a bad Battery
    2) Not a bad alternator
    3) Not a bad fuel pump
    4) Not a bad ECM
    5) Not a bad crank sensor
    6) Not bad gas
    Could it be:
    1) An issue with the mass air flow sensor
    2) bad plug wires
    3) girlfriend put sugars in gas tank
    4) short
    What do we know?
    1) Truck did turn on after some tweaking
    2) Truck won't turn on once it sits for a while
    This sounds like my old 85 carbureted accord. Sucker would not start cold.
