Tacoma issues are going to make me cry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by creep741, Mar 2, 2015.
  1. Mar 6, 2015 at 5:51 PM
    #141
    creep741
    creep741 [OP] Active Member
    diamond ohio
    08 tacoma
    the programming issue is, they are programmed by the vin number, ill figure it out and when I do ill tell you all what the issue was- and file ifr, I put a fuel pump in it,thats it, ever done that job?- and ill wash as many of my intakes with ether as I choose- it worked for my briggs when I was twelve and it works to this day, it seats tubeless tires, it starts wet wood, on fire itll get you high and its a great mouthwash in a pinch- I love starting fluid-your opinion aint gonna change it
  2. Mar 6, 2015 at 5:53 PM
    #142
    creep741
    diamond ohio
    08 tacoma
    I still think it may be the crank sensor im researching how to test it...could still be ecm
  3. Mar 6, 2015 at 5:53 PM
    #143
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    If the ECU does not want to enable the Fuel and Spark - why would it bother to allow the starter to crank?? I'd check the Wire from the ECU to the fuel pump for a starting point.
  4. Mar 6, 2015 at 5:58 PM
    #144
    medic2230
    Murph
    Bama! Roll Tide
    I believe I read before that's how the anti theft works to keep someone from starting the truck without the key with the correct code in it.
  5. Mar 6, 2015 at 5:59 PM
    #145
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Did you take a look at the pdf I posted on post #146? It gives the specs(in ohms) for the cps.
  6. Mar 6, 2015 at 6:05 PM
    #146
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Does anybody think that when he unplugged his battery the ECU unit had a capacitive discharge resetting the unit. It wasn't until he drove that something triggered a sensor (or a bad sensor somewhere) causing the ECU to revert back to not starting?
    Hope you get this fixed.
  7. Mar 6, 2015 at 6:06 PM
    #147
    creep741
    diamond ohio
    08 tacoma
    thanks blake, i just went thru it, I believe im going to replace the crank sensor bro- mine reads open on all three pins thanks for hanging with me you have been a great help- ill let you know
  8. Mar 6, 2015 at 6:06 PM
    #148
    medic2230
    Murph
    Bama! Roll Tide
    Your key hasn't been around a magnet or anything like that has it? Did you ever try it with another key?
  9. Mar 6, 2015 at 6:07 PM
    #149
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    2.7 base tacomas apparently don't have an immobilizer as stated earlier in this thread.
  10. Mar 6, 2015 at 6:07 PM
    #150
    medic2230
    Murph
    Bama! Roll Tide
    Good luck OP. Hope this gets it.
  11. Mar 6, 2015 at 6:08 PM
    #151
    medic2230
    Murph
    Bama! Roll Tide
    Gotcha. Haven't looked on here for a bit so I didn't know if that was ever cleared up.
  12. Mar 6, 2015 at 6:09 PM
    #152
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Please do let us know, I'm hoping that's all it is. You gonna get Toyota parts or just get whatever the parts house has?
  13. Mar 6, 2015 at 6:10 PM
    #153
    Canufixit
    New England
    Well I'm not going to say you are wrong - but If I was programming the unit I'd think that by doing this will just let the customers (or thieves) just burn out the starter and trash the battery. (That Toyota many have to pay to fix if under warranty) I'd just kill the whole thing if there is a security issue.
    As a second thought - I thought I'd hear the fuel pump click on when I turn the key to on (Not start) ?? Or am I wrong??
  14. Mar 6, 2015 at 6:14 PM
    #154
    medic2230
    Murph
    Bama! Roll Tide
    https://parts.olathetoyota.com/engine-immobilizers.html
  15. Mar 6, 2015 at 6:16 PM
    #155
    creep741
    diamond ohio
    08 tacoma
    start at the beginning of the thread canufixit read it all
  16. Mar 6, 2015 at 6:16 PM
    #156
    MikeDeason
    MikeDeason Well-Known Member
    It wont start at all if theres a security issue.
    The problem is the ECU or, if your lucky, a wire to the ECU.
    Either way the ECU needs to be replaced.
  17. Mar 6, 2015 at 6:17 PM
    #157
    creep741
    diamond ohio
    08 tacoma
    probably Toyota parts if i can...
  18. Mar 6, 2015 at 6:18 PM
    #158
    medic2230
    Murph
    Bama! Roll Tide
    You're still spreading that propaganda around? I'll let you know when my truck nukes the neighborhood from the ECU.
  19. Mar 6, 2015 at 6:18 PM
    #159
    creep741
    diamond ohio
    08 tacoma
    my truck doesn't have an immobilizer!!!not the ecu
  20. Mar 6, 2015 at 6:19 PM
    #160
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I'm ordering twelve ECU's to keep in the truck, 'cause impending doom.
