Tacoma J-arm kit & swingset steering
Discussion in 'Long Travel Suspension' started by 906taco, Mar 12, 2024.
  1. Mar 12, 2024 at 8:46 AM
    906taco
    906taco [OP] Well-Known Member
    Cory
    08 Taco
    Hey guys, my name is Cory.
    I have been a fabricator for the last decade of my life. Recently “finishing” my first off-road truck build. Just kidding, it’s never really finished.
    I am currently at the tail end of designing a swingset steering setup that I hope I am able to bring to market eventually. But anyways, back on topic.
    Let’s face it. The direct bolt on long travel kits leave a bit to be desired across the board.
    Packaging, well it sucks. With stock coil buckets and upper arms we are only able to fit so much.
    The stock shock tower/UCA mounts are weak. There are stories all over of folks bending towers etc once they start getting pushed hard. What’s the fun of Longtravel if you can’t push it?
    Bumping off of the LCA has never been an ideal method. With the motion ratio of the bump down low, you are engaging them 1/3 the way through the range of travel.
    My idea is to begin the design phase of a J-arm kit. Much like what you see on the big boy trucks. This would allow for several things.
    First, the factory coil tower is gone. It would now be a fully fabricated piece with significant strength gains.
    Second, Big shocks. Instead of the normal 8” stroke. We would be looking at a 10” or maybe even a 12” stroke shock. This would allow for a dual rate spring setup on the coilover. This brings the ability to really fine tune your ride quality via dual springs. Next, the goal would be to fit as large of a bypass as possible. Ideally a 3.5” body.
    Third, the bump stop would be located up high. This means you would be striking the bump pad with the UCA vs the LCA. Meaning you would only be striking the bump as necessary, not over every little hole you come across.
    Fourth. The factory spindle is weak. You can gusset it all you want, but fact of the matter is, it’s still weak in comparison to a fabricated upright. This kit would utilize vertical uniballs in double shear fashion.
    I would love to hear some input from some fellow enthusiasts to see if this venture is worth while. If it is, I would really love to see a kit ready for production by fall of this year. Let’s redefine what these trucks are capable of.
    Here are some pictures of my build and some of the things I do. You can also follow along on IG @906taco & @subzero.fab
    dk_crew, sparkystaco, mjp2 and 18 others like this.
  2. Mar 12, 2024 at 9:26 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Been following you for a minute, and really excited about the steering upgrade.
    Are you designing a solution that can be welded/installed on a "normal" truck frame, or would this require a fully tubular frame/rebuild?
    906taco[OP] likes this.
  3. Mar 12, 2024 at 9:32 AM
    906taco
    Cory
    08 Taco
    The j arm would be designed around the factory frame.
  4. Mar 12, 2024 at 9:34 AM
    Naveronski
    Fort Worth
    Fuck it, let's go then. :thumbsup::popcorn:
  5. Mar 12, 2024 at 9:36 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Here for a good time not for a long time
    :bananadance:
  6. Mar 12, 2024 at 10:27 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Trash….better start over….lmao
    honestly probably come up with the best geometry of any off the shelf kit…
    906taco[OP] and Ricardo13x like this.
  7. Mar 12, 2024 at 10:54 AM
    906taco
    Cory
    08 Taco
    One could only hope….
  8. Mar 12, 2024 at 11:30 AM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Here for the goods…
  9. Mar 12, 2024 at 12:54 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I’m in for a j arm kit.
  10. Mar 12, 2024 at 1:00 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
  11. Mar 12, 2024 at 1:51 PM
    Tenmile Tacoma
    Tenmile Tacoma IG: tenmile_tacoma
    Nate
    Colorado
    2016 DCLB TRD Sport 4x4
    F&R locked on 33s
    Dude, this has to be one the best looking 3 gens I have ever laid eyes on. Beautiful build. Will definitely be giving you a follow on IG.
    You probably are very aware of this, but you might think about also posting this thread / the same content to the long travel BS thread. I'm sure lots of guys on that thread would love to hear your idea.
    nv529 and 906taco[OP] like this.
  12. Mar 12, 2024 at 1:52 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    its the best looking 3rd gen because its a 2nd gen underneath
    bhigbee, JordanTaco6, dk_crew and 9 others like this.
  13. Mar 12, 2024 at 1:53 PM
    Tenmile Tacoma
    Nate
    Colorado
    F&R locked on 33s
    Holy sheesh, didn't even notice that! That's so sick.
  14. Mar 12, 2024 at 1:58 PM
    906taco
    Cory
    08 Taco
    Thanks man! But yes, it is a 2008!
    I did stick the link over on the BS thread as well! Hopefully we can pull enough interest to make this happen!
  15. Mar 12, 2024 at 2:37 PM
    sicki
    sicki Well-Known Member
  16. Mar 12, 2024 at 2:45 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    How do you plan on funding this experiment? Pre-orders are one way to go but could end up like RCLT taking years to deliver kits to upset customers
    Superdave1.0 likes this.
  17. Mar 12, 2024 at 2:53 PM
    906taco
    Cory
    08 Taco
    Its far from an "experiment". Nor am I asking for money up front, so funding isn't really a topic of discussion as it is irrelevant. But I do have the backing to make this happen if interest is shown. Ideally, I would like to see 10-15 on board.
  18. Mar 12, 2024 at 6:14 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  19. Mar 12, 2024 at 8:09 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Theres the quixotic setup available. I could see you making a solid setup for sure but a 12” shock is gnar
  20. Mar 12, 2024 at 9:00 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    10” dual rate isn’t ideal - 12” is shortest with a really useable coil combination to not waste having a dual spring - wouldn’t make any sense with a big 3.5 secondary at all.
