Tacoma Key Programming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seric007, Sep 8, 2012.
  1. Jan 21, 2013 at 6:33 PM
    #41
    seric007
    seric007 [OP] Well-Known Member
    can i get a little info, year, model, ect...
    key on - door open - then inserting keymaker device into obd port.. correct?
    if you've tried that then try:
    try inserting obd keymaker divice into port, door open - turning key to on position.
    and if that fails i would try to see if leaving it plugged in will ever yield a single long chirp then silence... proceed with step 7 if it does
    its also *very* possible with mass produced AMAZING china quality that you simply got a defective unit.... if all else fails, contact shipper for replacement. i order stuff from china all the time and they usually just send you out another
  2. Jan 28, 2013 at 5:01 PM
    #42
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    Well, I ordered a 2nd obd key programmer. I order my first one from different source than yours and the beeping was crappy so I suspected a bad unit. Te second one is from your source and it seems to work well S far as the beeps and such..... But I still couldn't get mine to program. Tried both methods you just suggested on last reply to no avail.
    It basically beeps once when I plug it, about 45secs to min later it just starts beeping on/off non stop, it takes a brake about every minute or so and continues.... My dog hates me btw.
    2012 Tacoma 4 dr 4x4 off road pkg v6 jbl/navy (in case that would matter ?)
  3. Jan 29, 2013 at 6:39 AM
    #43
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2013 Super White Baja
    Most home improvement stores cannot not even cut a key if is not a blank they have in the computer. Just find a good old fashion hardware store like Ace. That is where I got my extra Polaris keys done.
  4. Feb 24, 2013 at 10:18 AM
    #44
    badtoytrd
    badtoytrd Well-Known Member
    Brock
    Northern VA
    Tried this and the extra key works but now the anti theft light stays on all the time and blinks when the key is in the ignition. Any ideas? Its almost like the truck is stuck in programing mode.
  5. Feb 24, 2013 at 10:58 AM
    #45
    badtoytrd
    Brock
    Northern VA
    So i was able to get the light to go back to normal by inserting the original key and turning back and forth from lock to on 10 times but it won't let me program more than 1 extra key. Again, any ideas?
  6. Mar 5, 2013 at 8:32 PM
    #46
    madxman21
    madxman21 New Member
    So Cali
    Prerunner
    Got 3 blank keys off of Amazon, and the programmer off of Ebay. It works! Thanks so much!!!!!!!
  7. Mar 6, 2013 at 12:13 AM
    #47
    Bhwang
    Bhwang Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    Could you explain this more, I have my key cut and it will fit into my ignition, but wont turn, so I need the smart key programmer thing to make it able to start the truck ? Correct ? Also I had the key cut at a lock smith.
    BTW great info and thanks
  8. Mar 6, 2013 at 7:00 AM
    #48
    madxman21
    So Cali
    Prerunner
    When you have your key cut at the lock smith it should already be able to turn in the ignition from on to start position. When you try to start your taco it just won't start the engine because its not programmed yet. If it wont turn in the ignition, you had it cut wrong. Have them check the key again.
  9. Mar 6, 2013 at 10:19 AM
    #49
    Bhwang
    Josh
    Canada
    Tacoma
    Ok will do, I have had it checked again already and dee burred again so i guess that key is SOL. Thanks
  10. Apr 29, 2013 at 2:15 PM
    #50
    RollingRocker
    RollingRocker Active Member
    Clay
    Wyoming
    ToyTec 3" lift kit with Bilstein 5100 Height Adj. Coilovers, Dick Cepek DC-2 18" Wheels, Michelin LTX A/T 2 LT275/70R18 Tires, Alpine IVA-W205 DVD receiver, Alpine PDX 4.100 Amp, Alpine PDX 1.1000 Amp, 2X JL Audio 10W3V3 Subs, JL Audio C5-650 2-Way 6.5" Front, JL Audio CX5-650 2-Way 6.5" Rear, SnugTop XTR,
    I'm having the same issue with only being able to program one extra key. Works perfectly for the first not for any of the rest. Did you ever get an answer to why it won't let program more than one?
  11. Apr 29, 2013 at 7:46 PM
    #51
    stump jumper
    Bill
    Texas
    Lowe's and Home Depots have computerized key cutters that only work with certain blanks. All they can cut jn my area are house keys. Ace Hardware is where I went to get keys cut for my Polaris ATV. They also do chip keys for vehicles.
  12. May 14, 2013 at 10:04 AM
    #52
    Max5150
    Max5150 Member
    Mark
    Corpus Christi, Texas
    09 SR5 DC 4x4
    Eibach Springs, Billies set at .85, 2" AAL Audio System: Pioneer AVH-X4600BT, Polk DB 6501, Polk DB 651s, Rockford Fosgate R2SD4-10, Alpine MRP-F320 Amp, Dynamat Sound Dampening
    Received my programmer from Ebay and bought keys off Amazon. Worked great! Appreciate all the help...
  13. May 22, 2013 at 11:55 PM
    #53
    Andy Standard
    Andy Standard Well-Known Member
    California
    TRD Sport 4x4
    Westin Nerf Bar, OEM Roof Rack, LEDs from Chrisjumper, Weathertech digital floor mats, FX-R retrofit projectors with 6000k HID, G4 Elite cover, OEM Mat, Wet Okole seat covers, Flyzeye LED light, TRD skid plate, Bed Light LED kit, All in one key from Neneago
    Is there any way to program a flip key fob so you can just have all-in-one key instead of having the transponder key and separate remote? It adds a bit of bulk to my keys and I'd like to minimize it if I can.
  14. May 23, 2013 at 6:13 AM
    #54
    oldstick
    oldstick Middle Age Member
    GA
    + 1 on the ACE Hardware.
    They cut a blank Mitsubishi key for me one time, but I first had to explain that I knew it wasn't going to work without programming first. That car had a programming procedure that worked without using any extra plug in devices.
  15. Jun 17, 2013 at 7:58 PM
    #55
    Huntsonora
    Huntsonora Member
    Windsor, CO
    Will this work for a 2011 4Runner?
  16. Jun 18, 2013 at 7:19 AM
    #56
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    some
    These keys suck, computer this and that.
  17. Jun 18, 2013 at 7:41 AM
    #57
    Huntsonora
    Huntsonora Member
    Windsor, CO
    I agree!
  18. Jun 21, 2013 at 5:04 AM
    #58
    Sant919
    Sant919 Member
    Santo
    New haven ct
    12 trd sport lb
    this will work on a 2012 TRD?? lost one set of keys soooo pissed!! thanks!
  19. Sep 13, 2013 at 4:33 PM
    #59
    Ritsui
    Ritsui Member
    Sean
    So Cal Mountains
    Mostly stock
    CB, tailgate lock, bed lights, hood lights, console (back seat) 12v outlet, mtb mounts in bed.
    More thanks to the O.P. :thumbsup:
    Did this today. Instructions worked perfectly on my 2009 Tacoma TRD.
    Followup edit: After successfully programming a third key, the theft light began blinking with the engine on (no ignition kill, everything working). Searched and found that turning the ignition on/off 10 times fast (1 second or less per turn) as mentioned in this thread reset the theft indicator.
  20. Nov 3, 2013 at 6:04 PM
    #60
    gxman22
    gxman22 New Member
    Seric007,
    What part of Arizona you are from? I am in metro Phoenix. I saw this unit for sale shipped from NJ for $16.99. I was wondering if I use or buy your unit. Thanks
